Goldberg Tiger 60
RE: Goldberg Tiger 60
I have a Tiger 2 so can't answer about the wing. On the fuel tank, I usually go bigger engines so I usually go to a bigger tank. Ie, for a 60 plane I put a 75 or 80 engine on the front. To decide what tank to use I look for the same type such as slante, round, or square and then look for ones that are longer instead of wider. If you find one that is a bit wider you usually only need to dremel out the edges of the former usually Former 2, where the tank pushes through to the front of the firewall. Make sure that you give it a bit extra so that you can still get some foam between the tank and the former. Some sites give the dimensions of the fuel tanks so you can measure what you have and then see which brand will work. Hope this helps, Fast...
I'm going to maiden mine tommorow morning.
I used the supplied fuel tank, may change that latter.
Yes the wing is 2 piece, with 2 tubes.
