Ultra STick .60........91 fx
I just got my Ultra Stick .60 done and finished it with a .91fx and a 9C radio the Plane flys Great it did need about 3 oz. of tail weight but other wise the .91fx works GREAT!!! just remeber to reenforce the firewall if you plan to put a larger engine on. and the new 9C futaba radio is great!
Jason, if you ever decide to rework it, mount the rudder and elevator servo's in the tail, using pull/pull. That way you can get rid of the tail weight. Also mounted a 1,100 MaH nicad just in front of the servo's. Do a search, someone put a picture of the instalation on here and it works great.
Ed M.
Ed M.
My Feedback: (12)
MO
The OS60fx and the OS91fx weigh almost the same. I agree with moving the battery and servos to reduce the dead weight . If you need weight a larger battery is a great way to do it.
I have a 91 FX and it took 7 oz to get the US 60 to the AFT limit. It still flies like a baby on landing. It has unlimited vertical. I added 1 washer for right thrust which helped greatly. I would move the battery and servos aft, but I am selling it. Good plane but I want bigger. Mine does not 3D very well.
