If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 11 of 11 FirstFirst ... 91011
Results 251 to 254 of 254
  1. #251
    dgliderguy's Avatar
    Join Date
    Dec 2001
    Snohomish, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Corby Starlet
    I realize this is kind of a dead thread, and the little Corby is no longer in production, but I had to revive this thread for one last post. After sitting on my kit of the 60" Corby Starlet for way too long, to the point of even considering selling it, I finally pulled the kit out from under my teetering stack and opened it up and just started building it. A little more than a week later, I had a finished and ready-to-fly Corby. It was a piece of cake to build, and the kit quality was top drawer all the way.
    MAN, am I GLAD I finally decided to build it! This thing is FUN!! I barely got it off the ground and trimmed before I was doing avalanches, snap rolls, inverted circles, vertical rolls, hammerheads, you name it. What a pleasure this airplane is to fly! Not to mention cute as a bug, with its short-coupled fuselage, perky tail, and big bubble canopy. As some have said, it flies like a Pitts S-1 Special. And every landing is a float-and-flare three-pointer. What a great little plane!
    My OS FS-70 is the perfect engine, and after years in storage it runs great. My all-up weight is right at 6.5lbs, with no need for any balance lead. I modified the wing joiner and root ribs, to add dihedral back to the same angle as the full-scale Corby, because I think the dihedral adds to the perky looks. I didn't notice any big yaw-roll couple problems with the added dihedral, and it makes me wonder why Chris White reduced it so much in the model. Flies just fine at 6 degrees (snap rolls are crazy fun!). I did add in some elevator dual rate, per the advice of just about everybody in this thread, and I am glad of it. I can fly the Corby with the elevators at full throw, but switching on the dual rate after lift-off keeps the pitch inputs smooth and predictable. I did leave the ailerons at full throw, though, and the roll rate is fast but no dizzyingly so. Rudder mix is not required, and I don't find I need to add rudder in the turns, for the most part, though I do have a lot of aileron differential in my throws. Inverted flight requires only a minimal amount of down elevator to keep the nose level. Sure flies inverted well! Makes me look good!
    Anyway, just wanted you all to know that I am really enjoying this airplane. I've always loved the full-scale Corby Starlet, and now I have one in quarter-scale to get my weekend jollies with. Yeah, baby.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1836630   Click image for larger version.
    Glider junkies creed: No glider, no lift, no reason to live.
  2. #252
    redball8's Avatar
    Join Date
    Dec 2003
    Naperville, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Corby Starlet
    The 52/70 Starlet is the best-kept "secret" in the ARF world ...
  3. #253
    Join Date
    Feb 2007
    victoria, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Corby Starlet
    the third pic in your post was taken by me (pinched from the BMMAA web site, as i put it there). these two corbys are the sportsman aviation ARFs. the blue and whit one behind is mine, painted the same as my fathers full size corby. as for the dihedral, the model doesn't have as the full size. there ar plenty of other slight differences, but they are good models, excellent behavior in the air and on the ground. Good luck
    PvA
  4. #254
    Join Date
    Feb 2007
    victoria, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Corby Starlet
    great to see you have it in the air. I haven't flown mine for about a year. originally it had a magnum fs70, now it has a saito 60 twin. less power, but very scale. and absolute joy. here is a pic of my father with both corbies, and another with the corby and his es60 Boomerang. (you may notice a slight missing left arm. he fitted a motorbike twistgrip throttle on the joystick.)
    PvA
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
