Great Planes PT- 17 Stearman ARF
#601
My Feedback: (54)
CT
You're welcome. I felt the wood screw was a weak point in the attachment method shown. I went with blind nuts, much more secure IMHO.Maybe a little harder to install but worth the effort.
#602
Trust me. it wont be overpowered. The saito 325 is no stump puller in any sense of the word. It pulls the plane around at a perfect speed. I love throttling back and doing low and slow passes with that radial just grunting along.
Umfortunatly i royally thumped mine last week and I am waiting on replacement parts.No fault of the plane. My stupid goof.
#603
Flew mine yesterday and had a great time. It had been a few months. To long. Nothing fancy about my setup. A simple OS .91 with the best doctoring of the dummy engine I could muster. I love to do rolls, loops, stall turns, spins and whatever else strikes me. I always enjoy this plane.
#604
VT
bird.
#605
TX
Got the radial monunted, cowl fitted, fuel tank, throttle linkage, onboard glow wired, looks pretty good (I think), also fitted the cabanas with machine screws and blind nuts, fronts are a pain to get in but worth the effort, rears enter into front cockpit so easy there. Also made hatch for installing my 5000 mah glow battery and 2 ft extension 12 awg wire to carry the 15 amps or so for the 5 glow plugs !!.
should be flying either this weekend or next.
#607
VT
Stevelesl, one thing you might do is put a 3/4" rocket tube from back to front to keep the wiring from flapping around. It sure makes a difference!
Looks great!
Take care buddy.
bird.
Looks great!
Take care buddy.
bird.
#608
TX
Well she's finished bar the decals, came out at 17lbs 3 Oz, needed 1lb 3 Oz in the tail but the good news is my onboard glow and receiver batteries + 3 Oz of lead did the trick so really only added 3 Oz over the actual weight of the plane. May fly it this weekend, we will see.....
#609
My Feedback: (12)
AZ
I also found the springs to the rudder not great either so I ended up with a dual push rod set up from the rudder servo to one side of the tail wheel/rudder.. The side force from a cross wind on all that wing and rudder area put quite a bit of side loading on the tail wheel. Just my 2c, and something to put in the back of your mind come maiden time.
Best of luck, and if you get any video I would sure like to see (and hear!) that radial go!
#610
TX
yes, I can see that the tail wheel assembly may be a weak point, I have two of these tails wheels you show in your post, one on my all aluminum Affordaplane ultra lite and one on my Honda powered Put Put as I call it, they are very strong and work well. As you say, the springs are weak but that's the design of the wheel so that it doesn't overstress the servo.
#611
TX
Well it flys !, and it flys very well, take off was pretty much straight and after climb out only some down elevator trin was needed, the engine just sounds amazing in the air, not too over powered but it can fly nicely at about 1/3 throttle.
it does fly heavy but landing saw the plane float in wit no issues for almost a three pointer.
very, very happy with it, it,s a keeper for sure. Short video on Alvin RC Facebook page, sorry, no idea how to direct you to that page.
thanks for the tips and communications.
#612
My Feedback: (12)
AZ
This I feel is one of those times its safe (and a positive thing) to say "Told you so!" This is one of those moments I'm sorry I sold mine! (remembering how it looked and felt nailing the landing-not telling anyone it was the plane making me look good, not the other way around)
#613
VT
Very impressive plane. I love mine too.
bird.
#614
TX
Look at both pictures and tell me which one is wrong, left or right?, you will find they are both correct, it is the angle of the struts and the angle of the picture that may make you think one is wrong. How would they line up with the holes if one was backwards?.
Anyway, thanks for looking
#615
VT
Thanks buddy;.
bird.
#616
TX
Not sure if you are still saying you think one is backwards, if so, consider the fact that the struts are not vertical between the two wings, they are angles outwards, so when the picture is taken from one side and from slightly above the nearest one looks completely different than the furthest one away from the camera.
Also consider this, if one was backwards, how would the holes in the wings line up as the struts are also angled forwards, they would not fit that way.
Anyway, thanks for your concern
#617
VT
Yes Steve, I do believe you! I was only perplexed as to how it could look backwards in a photo. As I said, I have never seen a picture of a biplane and the struts look different than what they really are! In your two pictures, the first one has one strut looking backwards and the second one is the opposite one looking backwards! I have never noticed such a thing in a photo, and I do notice detail.
Just sayin'.
bird.
#618
Bird, are you over here causing trouble ... I did the same thing on another thread a got the back of my hand slapped ... I think what your seeing is the camera dyslexia.. its always the N strut closest to the camera that looks wrong, but I think its an optical illusion.
John M,
John M,
#619
VT
John M,
John M,
see you bud.
bird.
#620
saito fa 170 r3
Hallo
I Fly Mine with an saito fa170 r3.
Want to know what's the biggest tank who fit in the fuselage.
I use the original and my first flight end with a empty tank after 4 minutes.
The saito is not running perfect right now but I work on it.
Someone here who fly also this radial and can say some to the fueluse?
Greets
Maikro
Greets
Maikro
#622
VT
John M,
John M,
Hope to hear from you soon.
bird.
#623
The cabane struts LXGDA5 white and GPMA2810 US$6.69 both are shown as available early February '15. The interplane N struts are in stock in both colors US$23.99 a set.
If you want the grey landing gear and the grey cabane struts from Tower you will probably have to order them to see if Tower will supply them as back order items.
hope this helps - cheers - maxiemac
smile it don't hurt.
#624
stevelesl - in your above post 611, the left photo shows the starboard strut is fitted upside down - then in the right photo it shows the port strut fitted upside down - this probably happens when assembling the wings and struts - easy to do - in looking at each photo the numbers on each side of the fuselage are reading correctly - on page 14 of the instruction manual it shows where the red arrow stickers on the ends of all the struts are supposed to go - hope this helps -cheers - maxiemac
