Cermark Pitts tail wheel assembly
My Feedback: (10)
TX
I recently started assembling a Cermark Pitts and noticed that the tail wheel assembly seems weak. I have not heard anyone mention problems with the stock unit, however, I would like to replace it with something more substantial. A tail wheel assembly that does not put direct shock loads on the rudder and looks scale would be preferred. Any suggestions?
My Feedback: (265)
RE: Cermark Pitts tail wheel assembly
Hi Texan:
I just bought a Cermark Pitts already finished but not flown yet my Pitts also has the stock Tailwheel on it but it also looks week I'm going to replace mine with a Sullivan Tail wheel bracket model #S861 this one is good for 10 to 22 lb size planes & also matches up with the white Color on the bottom of the pitts Fuse I paid $7.29 for mine I have used these Sullivan Tail wheel bracked before & have Not had a bit of problem with them what engine are you using on yours I have a New Zenoah 26 on mine ? hope this helps & Good Luck with your Pitts I love mine Now if I only get enough time to fly it Carey
KY
Texan
try this tailwheel assembly, works great on the Cermark Pitts and looks pretty scale. I have one of these on both of my Pitts.
hope this was some help.
pittsman.
http://www2.towerhobbies.com/cgi-bin...?&I=LXBN41&P=7
pittsman.
My Feedback: (10)
TX
ORIGINAL: Sea_Planes
Hi Texan:
Hi Texan:
I am using a Moki 1.35 spinning an 18x8 prop. I'm also running onboard glow.
Good luck with your Pitts,
Scott
My Feedback: (10)
TX
ORIGINAL: pittsman
Texan
pittsman.
Texan
pittsman.
Regards,
Scott
