Reload this Page >
Great Planes Giant Ugly Stick
Old 05-01-2016, 07:37 AM
  #751
underh2o2long
Originally Posted by bluefin021
How much weight are you guys having to add for a DLE 30 ?
I have the DLE35R. I did not have to add any weight and my rudder & tail servos are in the back. Hope this helps.
Old 05-01-2016, 07:58 AM
  #752
Super08
Super08's Avatar
Is yours a trike? All of ours have taken a ton of lead in taildragger configuration.
Old 05-01-2016, 11:30 AM
  #753
underh2o2long
If you look good in the picture you can see where I put the rudder servo so there is more weight in the back. I also put the elevator servo toward the rear of the plane also which allowed me to balance the plane without extra weight.
Old 05-01-2016, 12:53 PM
  #754
Twin_Flyer
Did you build that from the article in Model Airplane News a year or so ago?
I plan on doing the same except for the landing gear. Not sure i want to go through that much work!
Planning on using a G45 in it, think that's too much??
Bill S>
Old 05-01-2016, 01:11 PM
  #755
underh2o2long
No, I built it over 3 years ago... still flying strong and is one of my favorite planes to fly. I think the G45 will be too much and will shake the plane apart give it enough time. DLE 30 or 35 is perfect for this plane.
Old 05-01-2016, 02:01 PM
  #756
Twin_Flyer
OK, I will rethink my engine choice....
Old 05-01-2016, 02:48 PM
  #757
bluefin021
bluefin021's Avatar
If you put the servos in the rear around 26 ounces. That is why I modified my last one and moved the rudder servo up under the wing. My next one will have both the rudder and elevator servos under the wing.
Thanks for the feedback. I have my servos in the rear but put my batteries and the ignition system in the engine bay and it still needs a lot of weight. I’ll give 26 oz a try…
thanks
Old 06-28-2016, 07:07 PM
  #758
omnt815up
Preferences
1
2
3
4
5
6
7
8
9
0
Backspace
Tab
q
w
e
r
t
y
u
i
o
p
Return
capslock
a
s
d
f
g
h
j
k
l
shift
z
x
c
v
b
n
m
shift
English
Deutsch
Español
Français
Italiano
Português
Русский
alt
alt
Preferences
THIS MAY SOUND STRANGE BUT THE INSTRUCTIONS DO NOT SAY ANY THING ABOUT GLUING WING TOGETHER. NOT FOR SURE WHAT TO DO.
Old 06-29-2016, 06:13 AM
  #759
Twin_Flyer
You don't glue them together.
They slide onto a wing tube then bolt to the plane for use.
after flying, unbolt them and separate them for easier storage,
i was common with older designs to have a one piece wing but today most large planes are designed with a two piece wing for easier transportation and storage,
Watch the video here: http://www.greatplanes.com/airplanes/gpma1224.html
Do a search on YouTube for $20 wing bags and make a set to store/transport them in, or simply buy a set ready made online...
Bill S,
Old 11-23-2017, 11:02 AM
  #760
rcguy!
My Feedback: (69)
rcguy!'s Avatar
Has anyone put floats on their Great Planes Giant Big Stik?
Dave Rigotti
Old 11-28-2017, 06:15 PM
  #761
rcguy!
My Feedback: (69)
rcguy!'s Avatar
Default Rudder Pull Pull
I see ALOT of recommendations on moving the rudder servo forward and using pull-pull to help with the tail heavy condition when using a DLE30.
Can anyone who has done this post some pictures of their setup?
Dave Rigotti
Old 11-29-2017, 04:02 PM
  #762
Super08
Super08's Avatar
Dave I went with a push pull on mine.
ID:	2246522   Click image for larger version
ID:	2246523   Click image for larger version
Old 12-15-2017, 06:08 PM
  #763
rcguy!
My Feedback: (69)
rcguy!'s Avatar
Smile
Just finished up MY version of the Giant Big Stik! The DLE30 uses the stock aluminum mounts. I got a header and canister muffler off of ebay that weighs 4 oz more than the stock one. I moved the rudder and elevator servos forward as far as possible. 3/16 carbon fiber pushrods with 4-40 rods was used. I did support the pushrods mid way aft. I used 2pcs 5 cell 2,000Mah NiMh packs mounted right behind the firewall, one for RX and the other for ignition. A Sullivan 12oz tank fit perfectly in the bay right behind the wing dowel attach bulkhead. I did upsize the wheels to 4 1/2" Sullivan SkyLites. I also used DuBro giant scale hinges instead of the CA ones supplied. I did NOT use the cotter pins supplied with them. Instead I use big DuBro T pins and cut off most of the top. This "L" section then got glued into the surface. This gives a MUCH tighter hinge gap between the surfaces.
She weighs 13 pounds 8 ounces and needed NO additional nose weight. Balances at 6".
Dave Rigotti
ID:	2247758   Click image for larger version
ID:	2247759   Click image for larger version
ID:	2247760   Click image for larger version
ID:	2247761   Click image for larger version
ID:	2247762   Click image for larger version
ID:	2247763   Click image for larger version
Old 12-15-2017, 07:18 PM
  #764
Super08
Super08's Avatar
Fantastic!! That should be a winner for sure.
