Great Planes Giant Ugly Stick
#701
I appreciate the offer and shipping probably would be pricey. I called Fults and they are operating till they sell their current inventory then they will close up the shop.
Any idea what which sturt i should get? I was looking at the class II model # 610.
http://www.fultslandinggear.com/RFseries.html
#707
The manual will give he torque requirement for servos. Myself and friends have just found the Hitec 645's bulletproof in the Stick. You can go with which ever brand you prefer. If using a gas engine stay with a metal geared servo and be leery of using ca hinges and the included pushrods. They tend to fail from the vibration. If you go back in the thread there is lots of good info b
#708
Giant Big Stick
Thanks Super08. What Brand and kind of hinges and pushrods would you think? most of my planes are 40 size and this will be my first large plane and I want to go with good parts that want fail me in the air.
#712
I need to fuel proof my firewall and I want to change the color of the firewall. What options are you guys using to fuel proof and apply some color to the firewall? I know many folks like epoxy thinned out with alcohol to fuel proof and use Monokote for the color. What about using LustreKote to fuel proof and paint? Other options?
cheers
cheers
#714
The last time I used them on a Stik I used a mix of 3/16" and 1/8". There are places the 3/16" are a bit thick, like towards the ends of the ailerons. That is why this time around I used large HD flat nylon hinges I bought from SD Hobby. Or was that on my Super Sportster? I will look at my Stik in the morning and let you know. The more I think about it I think it has Robarts.
#715
cheers
cheers
#717
I like to put a coat of thin epoxy or CA on the firewall and then before it is fully cured apply a piece of color using trim sheet, not monokote or luster coat. The trim sheet color is really tough when applied to fresh CA or epoxy. After it cures a bit more you can cut necessary holes in the trim sheet with an exacto knife.
#720
Looks good and I’ll give this a try! I just pick ed up a roll of Monokote.
#721
So I am going to be building my first stik. I must say I have enjoyed reading through all of the material in this thread. I am going to use a dle 40 cc twin and I am curious if you guys are using the stock tank or putting in a larger one. The stock tank is about 14 oz. is this sufficient for this engine
#722
My Feedback: (12)
AZ
The stock tank will get you to New Jersey from where you are! Mine had a 44 twin and I never ran out of gas, and that was flying twice between fill ups and mostly full blast. You will be fine, unless you are making a drone to pick up some cheese steaks from Philly (man I do miss those, dont have 'em out west) just check between flights the first few times, but truthfully you can even drop down a size if you want. You are going to like this plane, esp. with the twin. It just looks cool (and "right" - you'll see what I mean once its on there).
