hanger 9 cap 80"
TX
hanger 9 cap 80"
I do, I do
Just kidding guys, actaully I was standing right by him the whole time. Spectacular airplane! Blenders, Walls, Harriers, Lomcevaks, Elevators, Flat Spins and stuff I don't even know what you call all on the first flight. All that and it slows down and lands like a trainer. He was hovering around 1/3 throttle and climbing out of sight at half.
Uh, yeah, I want one!
My Feedback: (107)
hanger 9 cap 80"
ok fox 3.2 PK plus 22x8 mpi 870mg on ail and elev jr 4721 on rudder jr 4735 on throttle 16# with no mods sealed gaps . Never went to full throttle strait up at 1/3 to 1/2 hovers very easy with out a lot of movement, blenders were violent,harrier was rock steady with no wing rock ,elevators were flat and strait down with no forward movement,ver very tight waterfalls actually I think the rudder touched the prop,knife edge was almost hands off exept for the coupling to the belly,knife edge loop no problem, one bit of advice use a 50oz tank it was somuch fun i didnt want to land after 18 minutes i had a teaspoon of gas,the landing went like expected very slow and easy settled down without hardly touching the elevated!!!
Oh iI didn't think it would be proper to do a harrier landing on the first flight Kenneth
My Feedback: (107)
hanger 9 cap 80"
the assembly was fast ,with only one miner problem with the wing and horizen solved that by sending me another wing it didn't have any backing on one side for the ail hinge to glue to,I also used heavy duty dubro instead of the ca hinges,i moved the throttle servo cause i thoght it might be to close to the engine and it was hard to get to with the fuel tank seting on cg.The engine was new it was the first flight so i didnt do any adjusting and tack readings i will leave it a little rich for a while.The cowl mounting seemed a little odd at first but as it turned out it worked very well.The paint looked real good and matches.
MO
hanger 9 cap 80"
Thanks for the report!
Did you mount the cowl as suggested? I does seem a little odd. Also how did the plane balance?
Rein,
The ole' Aerostar is a 3D'n fool. Much better than this cap I would guess
Dave
Rein,
Dave
My Feedback: (107)
hanger 9 cap 80"
yes I mounted it as instructions and it works fine it actually holds the cowl out so it doesnt rub the covering,don't ad any weight to the tail,i used a haigh style tail wheel,and put the receiver batts over the main gear and it balances perfect
H9 232 cap
Originally posted by KenLambert
it is an 80" one peice wing very light .it is simular to the MidWest,a bit larger though,I have both and the 9 smokes the MidWest in 3d
Thanks Ken for all the infromation i have a PW 300 25% it flies great. I was at the Waco Hobby Shop a H9 80" came in i got to looking at it and it looked good to me so i brought it i'm gald to here it flys good. I didn't know it was a one piece wing till i got home with it, but i can live with that if its a good flyer, gald to here it does Thanks Again Happy flying James
