New Giant GP Super Sportster!!!!!
Reply
Old 07-23-2018, 05:40 AM
  #3051
Joystick TX
Joystick TX's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Tom Nied View Post
OK Steve that pretty much explains all. Hope you're feeling fine. I don't get nearly any kind of time like that on an engine. What you describe is pretty intense. But from what you tested, what did you learn? Can you disclose what you did learn from your testing? Like what are the things that help an engine prolong its life? I'm running a DLE 35ra on my GP GSS and if I get 4 flights an outing, I'm doing pretty good. Thanks for sharing.
Tom Nied, Carol Stream, Illinois
I liked the Stihl Ultra 2-Cycle engine oil. No particular reason. I didn't do enough testing on different oils to determine which oil was best. I only used high quality oil, so there may not be a huge amount of difference between them. The engine bearings seemed to fail at about the same number of hours regardless of the oil used. I never tested Amsoil, or any ratio less than 30:1.
The only thing I really learned is that when you hear a clicking sound when rocking the prop back and forth, or if you feel a roughness when turning the prop over slowly, your bearings are bad. If you keep running your engine until the bearing race breaks apart, your engine will not be worth repairing.
Joystick TX is offline
Old 07-29-2018, 05:00 PM
  #3052
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, I guess we expected this. Tower has discontinued the Great Planes Giant Super Sporster.
Tom Nied is offline
Old 06-15-2019, 06:46 AM
  #3053
Joystick TX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I added another LiFe battery to my GSS, I never had any problem with having one battery, but there have been a few people at the field who have had one battery fail in flight. I now have two 2,200 mA LiFe batteries and two switches to power the receiver. The ignition is still powered from the Tech Aero IBEC plugged into the receiver for control and power.
I changed the fuel tank from 16 oz to 12 oz and replaced the fuel tubing.
Also, had a lot of problems with the tailwheel springs over the years, so I replaced them with a rod. It gives way better ground handling in the grass.
