New Giant GP Super Sportster!!!!!
Reply
Old 01-29-2011, 01:05 PM
  #1451
Joystick TX
Joystick TX's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New Giant GP Super Sportster!!!!!
A guy in our club has had one for over a year; it is still in the box. I keep bugging him to put it together.
Joystick TX is offline
Old 01-31-2011, 07:10 PM
  #1452
Joystick TX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Since I like to fly early in the morning and the winter time light is not all that great, the white wings blended into the the early morning white clouds when I was landing making them hard to see. I made another mod to the GSS; added some orange day-glomonokote to the wingleading edges.
Tried it out this morning and it works great. Got another hour and a half of flying time logged. A winter storm will be here tomorrow, expect to get one to three inches of snow, may have to make up some skis for the old GSS.
Also, on the post flightcheck, Inoticed one servo had a couple of loose screws. That has never happened before. Last month the control horn screw was loose on that same servo. Must be some odd vibration going on in that area. I need to keep an eye on it.
ID:	1556608   Click image for larger version
Old 01-31-2011, 08:09 PM
  #1453
Super08
Super08's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Put a small drop of thick ca on the tip of the screws and they won't back out again. They are still easy to break free witha screwdriver if needed.
Super08 is offline
Old 02-15-2011, 05:25 AM
  #1454
redbiscuits
redbiscuits's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have mine for sale if anyone interested. It's in the giant section.
RED.
redbiscuits is offline
Old 02-15-2011, 05:42 AM
  #1455
Joystick TX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good tip, thanks.
The servo screws have been doing okay for the last twenty flights or so, no more problems.
I found out why one of my elevator servo control horn screws came loose. A buddy crashed his big warbird due to the screw and horn coming loose on his elevator. We were talking about it in our peanut gallery. When I switched to the MG servos, the screw and gear are both metal, sothey are more likely to come loose than the servo with the nylon gears. Simple solution is to use some blue locktite. Duh.
There is a learning curve when going from glow to gas and bigger planes. These forums help a lot.
Old 02-15-2011, 05:58 AM
  #1456
Joystick TX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great looking plane Red.
I like the gear. Mine is just plain aluminum; functional, but not good looking.
Wish I could get it; the way I fly, I could use a back up GSS.
Got to go out right now and put an hour or two on mine while the weather is good.
Old 02-15-2011, 11:42 AM
  #1457
redbiscuits
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, I've had a great time with it and now it's time to pass it along to someone else. I need to free up some cash so I can move onto a warbird project that I have been daydreaming of.
Red.
Old 02-25-2011, 11:58 AM
  #1458
tail heavy
tail heavy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone fly the GSS with a CG 6" behind the leading edge?? That is where my bird balanced at.
Al
tail heavy is offline
Old 02-25-2011, 12:22 PM
  #1459
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't remember where the book tells you to put it. Many that have flown it where suggested comment about the plane floating the entire length of the runway. 1/2" or maybe a little more to the rear of that will help that big time, without creating any bad habits.
ahicks is offline
Old 02-25-2011, 12:27 PM
  #1460
tail heavy
tail heavy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks ahicks!
When the weather warms up here in Iowa, I'll give it a try. I kinda like my planes to fly with a nuetral or slightly aft CG. Sounds like I should be good.
Al
Old 02-25-2011, 12:54 PM
  #1461
hauckf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The manual says to balance it at 5.25", and then, if you want, move it up to 1" forward for more stability and smoothness or up to 1" aft for more aeroabatic performance.
hauckf is offline
Old 02-25-2011, 01:42 PM
  #1462
tail heavy
tail heavy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. Sounds like 6" is the right spot for me.
Al
Old 03-03-2011, 03:43 AM
  #1463
Howard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did not think that I would have any issues with the wing mounted main mounts but I made several bad landings in a cross wind and ended up punching holes in the wing bottom with the back of the wheel pants. I too can still learn so I ordered Super Stearman gear from Tower about two months ago and they were placed on back order with expected delivery in late Feb. Just the other day they changed the delivery date to late April. Bottom line anyone have experience fitting the GSS with landing gear other than that from the Super Stearman or better yet does anyone have a Super Stearman gear they want to sell? Thanks
Howard
Howard is offline
Old 03-03-2011, 04:20 AM
  #1464
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Howard
Howard
I've been running mine "wing mounted" without issue (other than the occasional having to straighten the gear!) and I like them out there. It hadn't dawned on me others might not for the reason you've given! I'm sure if I were using the wheel pants I'd have done the same thing many times over!
ahicks is offline
Old 03-03-2011, 04:29 AM
  #1465
Joystick TX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used the landing gear from the .120 sized Spacewalker, PN SEA3507, cost was $16. It is a little too flexible for the GSS with a big 30cc gas engine up front, but I put some springs on it to stiffed it up a little and it works great.
It has plenty of flex for our rough grass field and is very forgiving on those not so gentle landings.
I use the 4" wheels without wheel pants because I fly from a lot of fields that have tall grass or weeds.
The two piece design bothered me at first, but it has worked out great. I also put about 2 degrees of toe-in.
ID:	1572568   Click image for larger version
ID:	1572569   Click image for larger version
Old 03-23-2011, 06:17 PM
  #1466
blackmonte
blackmonte's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well after 2+ years in the box i'm starting to put mine together. I've read about the issues that ppl have had. Has anyone had plenty of stick time on this plane without using flying wires and not
had any issues? I think I will use the 4-40 rod but will thread the non-threaded end and use dubro heavy duty ball links & clevises.(I don't have any luck using solder). And I will use hitec 5645mg
servos and robart 3/16th hinge points. Power will be DLE 30 with pitts muffler and plan on doing the gear mod using the GP Super Stearman landing gear. And if everthing goes well may add a
smoke system later on.
blackmonte is offline
Old 03-23-2011, 06:41 PM
  #1467
azalner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't waste your time trying to thread the rod. The threads on the other end are rolled, not cut. Thjis raises the thread and makes a tight fit. Trying to chase the threads with a die doesnt work. Been there and done that. Use 4-40 fully threaded rod.
Strongly suggest you use flying wires. I used the Great Planes Flying Wire set (GPMA2844). Send me a PM and I'll e-mail you a write-up with photos on how to do it.
azalner is offline
Old 03-23-2011, 07:00 PM
  #1468
blackmonte
blackmonte's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bought the same fly wire kit.....should be here Friday. I havent tried using the die to cut the 4-40 threads yet. So if that wont work I may go with carbon fiber rods or all thread.
Old 03-23-2011, 10:33 PM
  #1469
Kostas1
Kostas1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: blackmonte
I'm flying mine without wires and -No- issues at all...
Go for it..you'll love the stability and gliding potential of the airframe.
Also check here : [link=http://www.rcuniverse.com/forum/m_9886731/mpage_1/key_/tm.htm]Giant SuperSportster ARF / Saito FA-150S[/link]
Kostas1 is offline
Old 03-24-2011, 05:42 AM
  #1470
Joystick TX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is no way I would fly this plane without flying wires if you use a 30cc gas engine. The Syssa and DLE both have way more power than the engines recommended for this plane. You will be able to hover at less than half throttle. I had over 300 flights onmy first planebefore the stab folded. On my #2 plane, I have the carbon fiber rods on the top and bottom of the stab. More details are in my gallery and my models section. I have about 50 hours of time on GSS #2 now with no problems.
Old 03-24-2011, 05:50 AM
  #1471
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would offer that anyone seeing the tail feathers shaking like they do on this gasser while on the ground/bench, won't (shouldn't?) need much convincing to do something about it. I liked the solid rod method, found some where I had no trouble making threads after cutting it to the right length, no clue on the source. I just had them laying around. Mine has a ton of time on it as well, with Quadra 42 and Syssa 30 for power.
ahicks is offline
Old 04-15-2011, 04:45 PM
  #1472
Joystick TX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another windy day today, gusts up to 50 mph. I'm getting tired of being grounded by winds. We may get a break tomorrow and then they pick up again.
Old 04-15-2011, 09:56 PM
  #1473
Kostas1
Kostas1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, using a gas engine requires stiffening the tail !!!
Kostas1 is offline
Old 04-16-2011, 07:54 AM
  #1474
Joystick TX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally got in some flying this morning. Winds were light. Had an odd thing happen with my TX, so it will go in for repair.
Old 04-17-2011, 05:35 AM
  #1475
Joystick TX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TX is okay, my boo-boo. Accidently switched the stick mode when changing the models. Never did that before.
Reply
Display Modes
