Creek Staudacher radio switch installation
My Feedback: (14)
Been looking at the fuse for this bird and can't seem to find a place to mount the switch on the side of the aircraft. Where are you guys mounting them? There doesn't seem to be enough solid wood anywhere in there.
My Feedback: (12)
IL
Yep Joe I ran into the same problem. I glued in a piece of balsa in the open web to install the switch and charging jack. I mounted it between the wing and canopy.
My Feedback: (14)
Yeah, I may have to do that, too. I did find a spot just below the canopy cutout that is just big enough to fit the switch/charge jack into, but I'll have to cut away most of the lite ply in that area and am unsure if it would weaken the structure any.
Another point I was wondering about is how much the cowl overlaps the fuse. It looks like it's only about 1/4" or so. Is that how yours came out?
I'm thinking of using pull-pull on the tail surfaces to keep the servos inside and help with the balance. But it looks like a chore because of the foam turtledeck. I'll need to come up with a good way to cut a tunnel in there for the top elevator wires.
How do you like yours, flying wise? This looks like a really nicely put-together plane so far. The covering job is top-notch. I've been building models for over 20 years and there's no way I could even come close to matching the quality of the covering job.
Jim
Re: re staudica
Originally posted by john sands
My first staudica crashed when the wing spring let loose
Sorry for your loss. Man I hate to hear that!
My Feedback: (20)
PA
"Another point I was wondering about is how much the cowl overlaps the fuse. It looks like it's only about 1/4" or so. Is that how yours came out? "
I have a kangke, and that is where i mounted mine. Worked out great. Same amount of space, 1/4 inch or so.
Did you guys ask how to make tunnels in foam?? Its pretty easy just fin a suatable metal object the length of the tunnel you need to go through the foam and the diameter you desire and just heat it up and start burning away! :devious:
My Feedback: (12)
IL
My cowl overlapped about 1/4" and so far its fine. The bird flies great and you'll surprise how slow it can landed, its a real floater. Definitely install all the tail servos in the fuse, I had to add alot of weight to balance it out.
My Feedback: (14)
Oops!
I opened the wing servo cutouts today and on the right wing, the hole for the servo lead was cut into the OUTBOARD side of the opening!? Had to probe around and find the tube and cut a new hole.
John Sands
Can you tell me more about your fix for the spring? It seems pretty weak to me, too. I've never had a plane with plug-in wings, but it seems they should be held on a little tighter that the spring holds them. Also, it's a pain to hook it up unless you remove the bottom hatch. Unless I'm doing something wrong...
John Sands
My Feedback: (14)
Cooling air question
To anyone flying the Staudacher---
With the OS 1.60, did you have to cut any more openings in the cowl other than the ones already there to help with cooling? I was very pleased to find out I didn't have to cut a hole for the cylinder head to stick out, and only a small square on the bottom for the muffler pipes. But, I wanted to make sure there was going to be enough cooling air with this configuration.....
My Feedback: (12)
IL
I have the Saito 180 in mine aside from the muffler cut out and the rocker arm cut outs I didn't add any more holes. The one they provide at the bottom is pretty big, So far no cooling problems.
I'm using an Irvine 140 ,I cut a 2'' hole at the cylinder head , evgine is mounted sideways , I had to get at the plug anyways tiis gets me access and cooling,No problem John Sands
