Seagull Yak?
Reply
Old 11-10-2012, 05:27 PM
  #1526
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Seagull Yak?
Quote:
ORIGINAL: Sourkraut
Sorry for your loss.....mine is still flying great. I am into my second season with her and the Saito 180 is a puuuurrrrffffect match for this airframe.
Did you beef up your airframe or use different hinges? Thanks Capt,n
captinjohn is offline
Old 11-10-2012, 05:53 PM
  #1527
Sourkraut
Sourkraut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: captinjohn
Quote:
ORIGINAL: Sourkraut
Yes the 150 will be fine....mine has gobs of power with the 180
Sourkraut is offline
Old 11-10-2012, 05:57 PM
  #1528
Sourkraut
Sourkraut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Sourkraut
Yes, I beefed up the landing gear plate and the firewall with tristock/epoxy wherever I thought it needed it.
Still using the stock CA hinges and still holding in there BUT if I was putting another together I would probably go with Robarts or Dubro pinned hinges just because some others have been having trouble with the stock CA hinges.
Old 11-11-2012, 07:23 AM
  #1529
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SourKruat...thanks for the good advice. Capt,n
Old 11-13-2012, 09:11 AM
  #1530
badazzgti03
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey everyone. I picked up one of these on a trade with a Zenoah G20...It doesn't have a spinner on it does anyone have the recommended spinner size for this? let me know.
badazzgti03 is offline
Old 11-14-2012, 02:58 PM
  #1531
Jerry-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: badazzgti03
spinner size is 2.75
ID:	1820333   Click image for larger version
ID:	1820334   Click image for larger version
Jerry-RCU is offline
Old 11-15-2012, 06:18 AM
  #1532
badazzgti03
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awesome!!! thanks so much Jerry!
Old 12-27-2012, 12:42 PM
  #1533
OliverJacob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anybody here sell a spare set of tail feathers for the black/yellow version?
OliverJacob is offline
Old 03-14-2013, 11:55 AM
  #1534
lopflyers
lopflyers's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This thread is being inactive fir 3+ months, I have 7 acrobatics planes and this is my preferred by far. I have the yellow/black version with a TT 120
lopflyers is offline
Old 03-14-2013, 01:40 PM
  #1535
OliverJacob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had mine sitting around and just about finished.
Hope we can start flying soon here, we had enough snow for the year..
Where do you have your CG? I know there were some issues and going by the manual will turn out to be tail heavy.
I have a 20cc gasser on mine, hope that's enough power
Old 03-14-2013, 01:56 PM
  #1536
lopflyers
lopflyers's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its very tail heavy, the manual doesn't help a lot. Ill have to measure mine and get back to you.
When I was flying her w the Saito 100 I had to add a lot of weight to the cowling,
Yes a 20cc is plenty. I have a friend flying her on a 20cc and she is fast
Old 03-14-2013, 04:38 PM
  #1537
OliverJacob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have my CG close to the wing tube.
And I have another Yak and a 1.20 Magnum FS sitting around.
Not sure if i should build it or keep it for spares...
Old 03-14-2013, 05:47 PM
  #1538
Sourkraut
Sourkraut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: OliverJacob
My YAK balances spot on at 5 1/4 inches back of the leading edge at the wing root .... the manual is/was wrong.
Old 03-14-2013, 06:15 PM
  #1539
lopflyers
lopflyers's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just checked mine, 5 inches from the leading edge at the root.
Old 03-14-2013, 06:31 PM
  #1540
rebranger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check with Horizon for parts.
My balances dead on the wing tube with a ST 90 & battery (a123, 3000mh) up front under the cowl.
rebranger is offline
Old 03-14-2013, 06:43 PM
  #1541
OliverJacob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the suggested CG just didn't look right, it should be close to the wing tube.
I have ignition and receiver batteries right behind the wing tube, but the gas engine is a little heavier and the ignition box is right behind the firewall
Old 03-15-2013, 05:57 PM
  #1542
Slow and Steady
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The manual CG is off as I believe the correction notice on the Horizon web site. I think in the beginning of this thread there is a photo of someone who crashed on their maiden, likely due to their CG. Haven't flown this plane in years, but it was one of my favorites, although mine really pulled to the gear in knife edge.
Slow and Steady is offline
Old 03-18-2013, 11:05 AM
  #1543
proteus_X3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have just started my Seagull Yak-54 and I have a question for those who have in stalled the zenoah G-20 .Since this model comes out tail heavy  most of the time and from posts I have read that the G20 is mount directly to the firewal with no stand-offs l,why hasn't anyone used stand off's and move the engine forward? The manual states engine mount distance of  140mm or 5.5"  from  Firewall to prop hub.The   G20 length   is 4.70 for the correct position of a G20 you should have a stand-off of .800"
The reason I' m asking is because I have a J-Tec pitts style  muffler for the G20 and I would like to use it,if I use Hangar 9 Taylorcraft  G20cc
stand-off 's  which are 1.080" long this plus the engine length comes out to 5.82" .320" further forward  of manual recommendation I don't see  a problem doing this,did I miss something I welcome you input and advice. Thanks and Cheers: Rich
proteus_X3 is offline
Old 03-18-2013, 12:49 PM
  #1544
OliverJacob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have an Aerovate 20cc, made my own stand offs. The engine is right where the manual wants it to be, but there's no problem
changing the stand off length.
Mine came out almost perfect. I use 2 light batteries (LiFe) and just moving them would be enough to get the CG right.
I think your Zenoah might be a little heavier then mine, you shouldn't have to move it forward.
Old 03-18-2013, 01:52 PM
  #1545
proteus_X3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OliverJacob,
Thanks for your reply, I need the extra length on the stand-offs for the J-tec muffle. If I made .800" stand-offs it would be to tight and the muffle would rub against  the firewall, the 1.080 stand-off  are just about perfect and I paid  $8.59 for them at the LHS.thanks for your input. Cheers: Rich
Old 03-18-2013, 03:42 PM
  #1546
OliverJacob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had the same problem, I changed the stock muffler to a pitts style and since everything else was perfect I decided to
modify the firewall instead using different stand offs. Then I strengthened the box from the inside, came out very nice.
Old 03-18-2013, 04:01 PM
  #1547
RCVFR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: proteus_X3
I have just started my Seagull Yak-54 and I have a question for those who have in stalled the zenoah G-20 .Since this model comes out tail heavy most of the time and from posts I have read that the G20 is mount directly to the firewal with no stand-offs l,why hasn't anyone used stand off's and move the engine forward? The manual states engine mount distance of 140mm or 5.5" from Firewall to prop hub.The G20length is 4.70 for the correct position of a G20 you should have a stand-off of .800"
The reason I' m asking is because I have a J-Tec pitts style muffler for the G20 and I would like to use it,if I useHangar 9 Taylorcraft G20cc
stand-off 's which are 1.080" long this plus the enginelength comes out to 5.82" .320"furtherforwardof manual recommendation Idon'tsee a problem doing this,did I miss something I welcome you input and advice. Thanks and Cheers: Rich
I flew the G20 on mine. I used short standoffs to position the prop where it is called for. No balance issues; mine flew best balanced just behind te wing tube.
RCVFR is offline
Old 03-18-2013, 05:00 PM
  #1548
proteus_X3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: RCVFR
RCVFR,
Thanks, so your CG is 5.5" from leading edge of the wing? BTW I like your name,you a pilot? RCVFR Radio controled visual flight rulesCheers: Rich[/i]
Old 03-18-2013, 05:04 PM
  #1549
orthobird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i had this plane, it was a beauty, i put an os 35 cc nitro engine, and it destroyed the airframe in 5 flights time, she fell apart during flight, fell from the sky like a raggady ann doll.  i replaced it with a GP Yak 54 and using the 35 cc nitro engine, she has had about 20 flights, but the seagull Yak black and yellow was a much nicer looking plane.  enjoy the plane guys, do not put anything bigger than 20 cc.  reason i am telling you all this is so that no one else makes the mistake i made.
orthobird is offline
Old 03-18-2013, 05:12 PM
  #1550
proteus_X3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jacob,
Iconsider that option....But the older I get the lazer I get,patch least resistance and all that ,moving the engine fwd on a know tail heavy plane seems logical with little on the down side. I'm only using a single 6.6v 3000mah Life battery with a UBEC for the ignition modual.The ignition modul has been replaced with RCexl modual so I can run it unregulated if I want.
Reply
Display Modes
