If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 16 of 24 FirstFirst ... 61415161718 ... LastLast
Results 376 to 400 of 578
  1. #376
    SteveD-RCU's Avatar
    Join Date
    Jan 2002
    Sault Ste Marieont, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: New Pacific Aeromodel Clip Wing Monocoupe
    Nice panel and engine setup TooLow,I see your a Nosen 310 member,I'd sure like to build one someday.
    Steve Daly
    MAAC #14007
    Challenger2 C-IECP
  2. #377
    Join Date
    Dec 2001
    Snohomish, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I used the stock muffler also and it works just fine. Fits in the cowl easily also. Using an APC 17x6 prop. Plenty of power. For the elevator servos, I used two seperate channels on the receiver and just mated it to the Elevator channel in the 9303 Wing Setup window. I'm using a 9 channel JR PCM receiver and found that at certain RPM's I was getting jitter on the elevator servos (this was at a low rpm). Kind of surprised me. I ended up buying buffered extensions from Electrodynamics and all of that went away. Using the G26 with a CH Ignition conversion. Works very well but if I had it to do over again I might just forgo the ignition system and use the magneto setup as it came from the factory.
  3. #378
    Join Date
    Dec 2001
    Bemis, NM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    " Anyone running the G26 want to offer an opinion/advice on what exhaust they liked (or disliked)?
    Jeff "
    I'm using an all welded aluminum muffler from Abell. It's a high quality muffler that's good for 200 - 300 extra RPM. Ralph Cunningham put me on to it !
    Ed
  4. #379
    Join Date
    Apr 2003
    Hope Mills NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    GBR2,
    Is there a reason that you would stay with the mag set up on your G26? Have you had any bad experiences with ignition? I'm running 2 G23's and one G26 on mag. They run good but really hard to flip start. I've got the prop/mag set per instructions, but still hard to start. I've about given up and now use a starter. I've got a new G26 that's going in my Pacific Aero Clip Wing Monocoupe. I'm thinking seriously about sending it to RC Ignition and let Ralph do his magic. Any helpful info, let us know.
    Enjoy the 4th.
    Richard
    Richard
    Monocoupe Brotherhood #36
    Full scale aerobatics is like having sex and being in a car wreck at the same time.
  5. #380
    Join Date
    Dec 2001
    Snohomish, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The CH ignition system works very well and I haven't had any problems with it. The only reason I wouldn't do it again is because of the extra wiring, battery, etc. that it takes to set the whole thing up. The Monocoupe has lots of room and I had no trouble installing everything but I'm not convinced that it delivers any greater performance than the original mag system the engine came with. So just from the point of view of keeping things simpler is the reason I wouldn't do the ignition thing again. As to hand starting, I never ran the G26 except with the ignition system, so perhaps I might find it unacceptable if I did want to do hand starting but I'll find that out with another engine. I'm not opposed though to using an electric starter.
  6. #381
    rcar4's Avatar
    Join Date
    Dec 2007
    champaign, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Had a great day this morning, finally got to maiden my monocoupe. It was up in the air in no time and the landing was awesome! Will try to post a video in a couple of days. Off to work I go.
  7. #382
    rcar4's Avatar
    Join Date
    Dec 2007
    champaign, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Short video clip of maiden,
  8. #383
    rcar4's Avatar
    Join Date
    Dec 2007
    champaign, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    [link]http://www.rcuvideos.com/video/monocoupe-wmv-3[/link]
  9. #384
    Join Date
    Dec 2005
    Torrance , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Was it a link to FlyingBigGuys?
    Jeff/LAX
  10. #385
    rcar4's Avatar
    Join Date
    Dec 2007
    champaign, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks like they don't like links to other sites
  11. #386
    Join Date
    Dec 2005
    Torrance , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Happens. Just reverse the name, or paraphrase it. Love it when the BBS is moderated by 12 yr olds.
    Jeff/LAX
  12. #387
    GaGeeBees's Avatar
    Join Date
    Sep 2004
    Fayetteville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Congrats on the maiden Nice landing!
    ...and then the unthinkable happened!
  13. #388
    Join Date
    Apr 2003
    Hope Mills NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    rcar4,
    Good job. Was that a G-26? What prop and fuel? I'm about half way with mine. Sent a G-26 RCIgnitions (Ralph Cunningham) yesterday for him to convert to EI. I'm also building a Spitfire, so the Clip Wing is not going together as fast as I would like. What mufflers are you guys using? I've got G-23's on two other airplanes with Bennette mufflers. They are ok, but I want a Pitts style wrap around for the Clip Wing. Any suggestions?
    Keepum flying.
    Richard
    Richard
  14. #389
    GaGeeBees's Avatar
    Join Date
    Sep 2004
    Fayetteville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: RHarding
    rcar4,
    Keepum flying.
    Richard
    Slimline makes a great product. http://www.slimlineproducts.com/onli...iant_scale.htm
    I've had one on a Pacific Aeromodels Gee Bee Y with a G-26 for about five years.
  15. #390
    rcar4's Avatar
    Join Date
    Dec 2007
    champaign, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RHarding,
    I put a crrc pro 40cc in it. It's a little tight put I wanted the extra H.P. I am running a 18x10 Xore prop, on regular pump gas and penzoil air cooled 2 cycle oil. I aborted my first flight off the runway, it got a little squirrely on me, I have only been flying a couple of years. The second take off and landing are in the video. The main problem with the runway takeoff was a fast idle. The motor is still breaking in and had to keep the idle up just a bit. When the thing hit the blacktop it was really rolling fast, on the grass I could get it lined up and stop rolling before I opened it up. I am running the EI and stock muffler that came with the motor. I could have bought the pitts and saved a little cowl, but the stock sounds good and doesn't look that bad. One thing about the EI is once I get the gas to the carb, it is choke on and a pop, then choke off and a couple of flips and she is running. after it has been running, one flip every time.
  16. #391
    rcar4's Avatar
    Join Date
    Dec 2007
    champaign, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    GaGeeBees,
    Thanks for your input, it has helped! Yes it is a GREAT flier!
  17. #392
    Join Date
    Apr 2003
    Hope Mills NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    rcar4,
    That's a lot of engine. I might have to rethink putting a G-38 on mine. Too much engine and required prop can create too much thrust at idle and not allow the plane to not move. On the grass you probably will not have this. Once again, great first flight.
    Richard
    PS; What tank and flight times?
    Richard
  18. #393
    rcar4's Avatar
    Join Date
    Dec 2007
    champaign, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That is probably the case, thanks. The thing about the motor I used was its light weight, with the servos in the rear I was able to balance it by moving battery packs around.
  19. #394
    rcar4's Avatar
    Join Date
    Dec 2007
    champaign, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    24 ounce Dubro tank, 15 minute flight and still had a half a tank
  20. #395
    Join Date
    Sep 2008
    Valencia, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Need some help.....I had a good pilot friend try to maiden my monocoupe, but on takeoff it veers drasticleynto the right. Tried twice then it flipped, No damage but the prop. Can anyone tell me what is wrong.
    Bob
  21. #396
    GaGeeBees's Avatar
    Join Date
    Sep 2004
    Fayetteville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Check your wheels/wheel pants. Sounds like the right wheel isn't turning freely.
  22. #397
    rcar4's Avatar
    Join Date
    Dec 2007
    champaign, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rawtry
    Bob
    I was having the same thing happen to me and it was the tail wheel. It may seem obvious but just because the rudder is straight doesn't mean the tail wheel is. The short amount of time the the tail is down during takeoff can really effect the take off IMO. My take offs are now nice and straight.
  23. #398
    Zippi's Avatar
    Join Date
    Jun 2004
    Evansville, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    There could also be a little to much throw in your rudder and as your powering up for take off your inadvertently giving a little right rudder. Also, what was mentioned by rcar4, make sure the tailwheel is straight. If your taking off from a hard surface the short wheel base of the Monocoupe gets a little squirrely at times like any short wheel base plane does. Try taking off from the grass. There is a world of difference.
    "It Ain't Lookin Good"
    http://www.evansvillercclub.net
  24. #399
    GaGeeBees's Avatar
    Join Date
    Sep 2004
    Fayetteville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was surprised to come across a photo of my Monocoupe in the latest issue of Model Aviation
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  25. #400
    Join Date
    Jan 2006
    Lexington, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Paul
    I thought that might be you when I read the engine description.
    Al
    MobyAl
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
