New Pacific Aeromodel Clip Wing Monocoupe
#451
Throttle and choke hookup. The choke goes back to a bellcrank on the firewall and then a carbon fiber rod goes down in the the area where the cutout is at the bottom of the firewall (where I assume a glow muffler would normally stick out).
#452
CA
I like both of those pictures. My carb is slightly different - but should be able to make your choke idea work. How did you support the bellcrank pivot?
#453
Anyone know the diameter of the inside of the cowling? I have a radial that needs 8 1/4" to clear.
Chris...
Chris...
#454
I actually used a standard control horn. Actually it was one left over from an Ultrastick 40 build as it was much stiffer than most of the nylon ones available. Hopefully the attached pictures give you the general idea. The only thing not in the pictures is the carbon rod that I reach up and grab but you can see the ball that the link attaches to.
#455
CA
Thanks!!
#456
My Feedback: (23)
GA
ORIGINAL: stuntflyr
Anyone know the diameter of the inside of the cowling? I have a radial that needs 8 1/4'' to clear.
Chris...
Chris...
#457
CA
Made a bit of progress yesterday - remembered to bring a second cigar
Fuel tank, lines, fuel dot, elevator servos and most of the langing gear (I know - it has to came back off, I forgot the fairings)
Probably can't see it - but I did GBR2's choke linkage (thanks - it works slick)
#458
CA
Did notice one thing when I put in the elevator servos (HS-645MG's) - 18" servo extensions only get you to the back of the plywood tray. I think I'll R&R them with some 24" ones.
#459
My Feedback: (23)
GA
I used 18" ones and the reversing Y harness took me the rest of the way to the Rx.
#460
CA
I won't have a Y harness (slaving the channels together in the 9303). Airwild needs my money anyway
#461
My Feedback: (19)
#462
My Feedback: (19)
ORIGINAL: OldFart1
What size wheels did this come with? The ones that come with it are foam, right?
Jimbo
#463
, AUSTRALIA
Hey TexasSkypilot, I was surprised to see you on this thread as I have been picking up your feedback on the H9 Taylorcraft. So tell me, do you like this plane more ?? Is it easier to build and fly ??
#464
My Feedback: (19)
Hi lotsofcrashes,
They're both awesome planes, and I've always been interested in the T-Craft as I occasionally fly in a full-scale T-Craft with a friend. To me, the Clipped-Wing Monocoupe wins out,although I have to admit I went back and forth about a hundred times before deciding. although I fly in a full-scale T-Craft, I'm a sucker for Golden Agers, and I'm a sucker for wheelpants and round engines. I mean, BAD......
I already have a Waco UMF-5.
As far as which of these two models builds up better, I haven't got my Monocoupe yet, it just shipped out to me yesterday (Yay!), and as you know, the T-Craft has been on backorder for some time and only seems to be released in small amounts.
So I'm going to go with what I know here. I've read through the threads for both of these and the Clipped Wing Monocoupe hs been getting GREAT reviews for the building, the manual (I downloaded it and printed it out so I could sleep with it at night, it really is a great manual), and the flight characteristics. Even with gassers much bigger than 30CC they are not having any real trouble with all the extra weight. 30CC and down they say it's perfect. I've been watching the videos, they're really stable on landings and approaches and they can really cut loose up there for aerobatics. Don't ask me about hovering, don't know about that and don't care. I'm into the older aerobatic birds, I always have been. The Monocoupe in its day won all the aerobatic shows. The landing gear on this has a few reports of "spreading", but I rarely have problems with that as I can grease almost anything almost all the time. But as it's a reported (small) issue I thought I'd mention it.
As for the T-Craft, the thread is full of people having this break off or that not holding together. It's a Hangar 9 product, and Hangar 9 products just seem to have a number of things wrong with each model, as though they know there's a handful of things but they don't want to take the time to iron them out. There's always a few weak items. Most of them don't bother me, but wing struts failing and flying braces breaking, those are disconcerting to me. It's a bit like having everything working good on your parachute but that little rip cord sometimes doesn't stay attached when you yank it
So, those are my observations and speculations. I'll be getting my Monocoupe within the next week, and I have promised to document my build on it. Just so you know up front, I'll be tossing the foam tires in the rubbish, making my own flying wires with something like a Sullivan kit, and changing the rear gear to a Sullivan standard one-piece steerable gear set, which looks much more scale than what comes with it and will work a hundred percent better! I'll be powering it it with a Syssa 30CC which is exactly mid-range by CC size, but by weight it's small and by power it's bigger than that, according to what I can glean from all I have been reading. Reality is another thing altogether at times! I will try to use some of the hardware if it's up to snuff, but my rod ends are almost always changed to the Sullivan black-plastic clevises with locks, and they are attached by using solder-on threaded rod ends. My planes don't crash from failures, so those are what I like to use. Being a good solderer is the biggie for this.
Well, I don't know if this helped, but I'm out of breath and I'm supposed to leave for work in 10 minutes and I still haven't showered!
Jimbo
#465
CA
ORIGINAL: TexasSkyPilot
Old Fart,
Jimbo
ORIGINAL: OldFart1
Jimbo
Woohoo - USPS finally managed to get my "carb insulator" to me - back to assembly tomorrow night. Off to watch the Kings play Philadelphia Flyers tonight.
#466
VA
Jimbo
Let me get over to the shop tomorrow and I'll tell you the size Sullivans I put on mine. I use the "Featherweights", I think they're called. Two-piece aluminum centers w/ a rubber tire. A bit expensive but a great tire.
Al
Al
#467
, AUSTRALIA
TexasSkypilot, you made me smile reading your feedback. Your obviously excited about the new plane and know what your talking about. I just posted a note on the tcraft thread saying similar things about H9 planes. If you claim to be first class, then go all the way. The guys are doing lots of repairs and they seem to be on top of things but the plane should not have obvious issues like those in the first place.
Can you tell me which suppliers carry the Monocoupe, its not on the Horizon or Tower hobbies sites. There is no info in Australia about the plane either.
#468
MI
Hi Guys,
I have flown my Monocoupe with a SV-26 rear carb (from Troy Bulit Models) 6 times now and it is a real pleasure!
The SV-26 provides plenty of power and it flys great on 1/2 to 3/4 throttle.
Take offs are easy - just make sure you have the rear wheel aligned with the rudder and some expo dialed in - I had a bit of trouble on the first few take-offs until I replaced the tail wheel springs with something a bit stronger.
Now -easy as pie - straight and true. Power up graually, the tail come up and away you go - in quick order!
Landings are simple too - chop the power - she comes down fairly quick due to the large cowl frontal area and the APC 18x6 Wide prop I am using -and then go up on the throttle 2-3 clicks for a smooth landing with no bad habits. Flairs nicely with a little power on.
I was paranoid about landing a clipped wing plane but this one is a *****cat. The designers at PA did thier homework.
Ken
Ken
#469
My Feedback: (19)
#470
My Feedback: (19)
#471
If the model flies with the tail down, why does it have to be tail heavy ? Why can't it be a decalage, or incidence problem ?
#472
FL
Tom,
It could be either or both. In this case, it's more than likely tail heavy. We had the same problem with the Waco's until we actually got to checking the Center of Balance by using the Mean Aerodynamic Chord measurement and found that we were all flying with the C/B too far rearward.
Bill, Waco Brother #1
#473
Thanks, Bill.
Looking at the above posted pic, it looks to me that the stab has negative incedence. That's why I asked.
#474
My Feedback: (23)
GA
By the way, I don't remember where many of my photos come from, but I think that with the pond in the background that this is probably GaGeeBees plane photo, I don't remember exactly what I saw in the video background but it looks right to me. Whoever took it, what a great shot....
Cheers,
Paul
#475
My Feedback: (19)
