Help with a H-9 Corsair rebuild
Stuffed my H-9 Corsair on maiden after a too early take-off leading to
tip stall crash. Plane suffered complete fuselage destruction from F-1
forward. Managed to rebuild the stringers from F-1 forward with spruce 1/4x1/4
sticks but need dimensions of F-1 to firewall. Any help would be appreciated.
I "had" a G20EI mounted..worked out just fine.
Wings and tail feathers are O.K. no damage, but the front end...gonzo
FL
RE: Help with a H-9 Corsair rebuild
Certainly not trying to prolong your agony by any means but can you provide pics? I'm nearly finished my H9 Corsair build and would like to see you bird. I need to set up CG and get the flaperons working but other than that it's ready to go.
I feel your pain because I know how much time you put into the build.
