Reload this Page >
Hangar 9 1/4 Scale Piper Cub ARF???
Old 01-02-2013, 08:31 PM
  #1401
nippaero
nippaero's Avatar
Default RE: Hangar 9 1/4 Scale Piper Cub ARF???
ORIGINAL: hidaven
Do you all think I can run the power 160 on 12s??
As long as you watch the amps and don't over prop it. There are lots of guys running a 12s configuration on warbirds. Check your configuration on ecalc first.
I am using the Tacon 160 in my cub on 10S with a Xoar 19x10. It will hover and go vertical straight up on takeoff. I have three of these motors is 1/4 scale planes and all are performing great.
http://www.hobbypartz.com/96m608-big...335-245kv.html
Old 01-03-2013, 05:33 AM
  #1402
hidaven
Yeah your numbers are exactly what I'm getting on the power 160. I want to run 12s on a 17x8 xoar so I can use my 6s 5000s in there. I have way more planes and helis on 6 or 12 s and don't need to keep 4 new 5s5000s for one plane. Only problem is with the 12s config. I'm def. going to be nose heavy and may need to move my 2s 1800 mah life RX pack to the rear as I don't see any other alternative.........anyone cut a air hole in the back under the tail area?
Old 01-03-2013, 06:09 AM
  #1403
ronwc
My Feedback: (404)
ronwc's Avatar
Does anyone know who makes this J-3 - I think it is the alternate covering version H9 did years ago, but not sure - bought it from a guy that had it thrown in a barn - never flown much, I am refurbishing it, took off 108 2C and putting on OS 120 4C - 86" wingspan.
ID:	1836392   Click image for larger version
Old 01-04-2013, 06:24 AM
  #1404
bikerbc
I am not sure but it looks like it could be a Sig clip wing 1/4 scale kit built J3 Cub....I have the 1/4 scale with the regular wing and it has about a 104" span . If it is the Sig Kit Plane you have a real nice plane to work with....I have an OS 120 four stroke on mine and it has lots of power...
Old 01-04-2013, 07:03 AM
  #1405
ronwc
My Feedback: (404)
ronwc's Avatar
ORIGINAL: bikerbc
I am not sure but it looks like it could be a Sig clip wing 1/4 scale kit built J3 Cub....I have the 1/4 scale with the regular wing and it has about a 104'' span . If it is the Sig Kit Plane you have a real nice plane to work with....I have an OS 120 four stroke on mine and it has lots of power...
I had assumed it was an ARF, mainly because I thought I had seen the color scheme somewhere. But now that I look at it closer, I think you are right - it may be a Sig clipped wing to 86" - going to get it redone in the next few weeks, will get pic up when done. Not going to completely redo all covering, but recover problem areas and repower with a OS 120. I have a few other Cubs including the one shown below -
Old 01-04-2013, 08:20 AM
  #1406
Lifer
Lifer's Avatar
ronwc,
I really like your twin Cub. Is there a video of it available?
Old 01-04-2013, 11:35 PM
  #1407
bikerbc
I have seen that pic so many times....
Old 02-08-2013, 12:54 PM
  #1408
winglift
My Feedback: (10)
I am going to get this ARF, mind you I usually build my airplanes, but this looks like a great plane to have. I am looking at the engines for this and really not sure were to go. Some of the engines might require adding nose weight others may require cutting more from the cowling. I will also be using this on floats from time to time.
1-Zenoah 20ccEI - $339.99 - 1.20 cu-in - 41.6 oz
2-Zenoah 26cc - $324.99 - 1.55 cu-in - 59.6 oz
3-OS GT-22 - $409.99 - 1.35 cu-in - 26.8 oz
4-DLE20 - $249.00 - 1.22 cu-in - 29.2 oz
5-DLE30 - $279.95 - 1.86 cu-in - 32.0 oz
6-Saito FG-21 - $504.99 - 1.26 cu-in - 31.2 oz
What would you choose?
Old 02-08-2013, 01:39 PM
  #1409
bucho
I have the os 160 gemini and is the perfect engine for this wonderfull ARF. you can buy it at rc universe for 450 usd
Old 02-08-2013, 05:29 PM
  #1410
rslstft
My Feedback: (10)
rslstft's Avatar
I have an Evolution 26GT in mine (which Horizon seems to have discontinued!?) and fly it exclusively off floats. Other than take off, I rarely fly about 1/2 throttle. Even at take off, I can usually get off the water at about 2/3 throttle. With the stock tank, I can get close to 30 minutes of flying time. Love the combination.
Old 02-08-2013, 06:50 PM
  #1411
cannonball200
My Feedback: (36)
cannonball200's Avatar
Winglift, I have the 1/4 Hanger 9 J-3 Cub with the DLE 20 installed. It is the perfect engine if you want gas. See post #1377 above. I misstated about the Jtek muffler, it is stock muffler. No added weight in nose and weighs about 14#.
It flys awesome and is not underpowered at all. I fly it about 1/2 throttle or less most of the time.
Eddie
Old 02-08-2013, 07:16 PM
  #1412
mobyal
ORIGINAL: rslstft
Discontinued? Must have been recently, as I bought one this fall for my H9 Tiger Moth.
Probably is true, tho. Just my luck.
Old 02-09-2013, 03:15 AM
  #1413
Lifer
Lifer's Avatar
Mine has a CRRC 26, which I had a lot of trouble with initially. Turns an 18x6 wood and flies very scale-ish. I have it on floats and it is adequately powered. It needed no nose weight to balance at all.
Old 02-09-2013, 08:55 AM
  #1414
ozief16
My Feedback: (13)
Wnglift,
I put he FG-30B in mine and love it. Like the guys have said, 1/3-1/2 power for cruising looks about right. I thought about the 21, but really enjoy excess power, just in case. Additionally I wanted to be able to slap floats on it without a second thought.
I really hate the sound of the gas two strokes and didn't want my Cub experience diminished by an annoying sound. The 30 is so quiet and scale sounding that it draws compliments every time it heads to the field. The other nice thing about gas is that I have about three to four hours on the plane and still am using my first gallon of gas. I set my timer for 30 min, and still land with a 1/3 tank...those gas four strokes are silly efficient.
The one thing to note is that the latest Saito instructions clearly say the motor does not need to be choked, and while that may be true if you use a starter, I find that with a simple choke tool I can easily hand-start the plane. I can explain more if anyone is interested
Dave
Old 02-09-2013, 01:07 PM
  #1415
winglift
My Feedback: (10)
ozief16
I also think that the 4 stroke sounds much better and Saito sure makes rock solid engines. They are a bit pricey $640 for the FG30. I also like the idea of reserve power, but I am still curious to know if the FG21 would do on this plane w/ floats since cannonball200 stated that he has plenty of power?
cannonball200
Have you flown this with floats?
bucho
I searched for this engine and found them going for $940 (Chiefaircraft & Tower). Where did you see this at $450? I am leaning to gas anyway, but was curious about the engine.
I also found a Mintor 33 engine at Chiefaircraft at $325. This is a beautifully made engine, 2.0 cu-in 33.6 oz, using a reed valve. The recomended prop is 19". Does anyone know about these engines?
Old 02-09-2013, 01:44 PM
  #1416
cannonball200
My Feedback: (36)
Winglift,
cannonball200 here, no, I don't have floats on my J-3. The Dle 20 I think would fly it however with floats. The guy's are right about the Saito 4 strokes sounding realistic. The gas 4 stroke would be awesome. I just cannot afford one though. In retirement, my pay check went down and cuts me out of some of my cadilac hobby wants!
Good luck on your J-3 Piper Cub adventure! They are awesome. My son & I bought one in 2006 in Feb and sold it in Nov same year. He is a jet pilot and really enjoyed relaxing flying the J-3 and gave me several hours on the stick too.
Eddie of OKC, OK
Old 02-10-2013, 11:45 AM
  #1417
winglift
My Feedback: (10)
ORIGINAL: cannonball200
Winglift,
Eddie of OKC, OK
Eddie,
I too am/was a full scale pilot, cfii, however have not flown for many years......way too expensive, so now I fly RC. I too am retired, but save my pennies until I can afford to buy the things that I want. In this case I will probably go for the Saito as it is an engine that will last and in the long run will save money.
Bucho,
I just cannot see spending $940 for an engine on this, which is the price at tower and chiefaircraft. Where did you get this for $450? Link?
Old 02-11-2013, 05:29 AM
  #1418
malitape
My Feedback: (213)
malitape's Avatar
["Bucho,
I just cannot see spending $940 for an engine on this, which is the price at tower and chiefaircraft. Where did you get this for $450? Link? "]
Winglift,
The way I read his statement, this is available on RCUniverse. It might have been in the clasifieds, being sold as used.
Old 02-11-2013, 08:03 PM
  #1419
BlitzPig
Been flying mine for almost a year now and the tailwheel is loosing effectiveness. Itightened the stock springs twice and lately replaced them with some stiffer ones from ACE Hardware but the tail wheel still doesn't move as freely and with as much authority as I'd like for taxiing.
Anybody else have this problem and a fix?
BTW, agree with cannonball about the DLE-20. Perfect gas engine for this model. More than enough power and can fly 40min. on a tank of gas with no added nose weight. Mine came in at just over #14 with 5in. Dubro tires.
Old 08-20-2013, 07:02 AM
  #1420
HELI-MECH
Hey Guys, new to this forum, I have just acquired a 1/4 scale hanger 9 J3 Cub, the price was right so i grabbed it, it needs a little work as it was stepped on, the engine firewall was broke off and the front window... as well the tail feathers were damaged but luckily the wings werent attached and the fusleage is easily repairable. What I am looking to do is convert this to the PA18. change the tail feather design so it has balance plates and also increase the size of the rudder to the pa18 size and add flaps to the wings. I would also like to change the engine cowl, so my question is, has anyone tried to retrofit the new hanger 9 piper PA18 super cub cowl to this plane? I would love to know if anyone else has done this conversion before either. CHeers guys!
Old 08-20-2013, 08:38 AM
  #1421
bsbauman
details
Old 08-21-2013, 11:20 AM
  #1422
malitape
My Feedback: (213)
malitape's Avatar
Deleted
Old 08-22-2013, 06:17 PM
  #1423
jmcowart
jmcowart's Avatar
Shifting to a slightly different area of interest I am wondering about the Robart Gear for the Hanger 9 1/4 scale J3 Cub. I have an H9 J3 Cub ARF ready to start assembly and was trying to decide about the landing gear. What is the benefit of the Robart system over the Hanger 9 stock landing gear? I was under the possibly mistaken impression the stock landing gear was an all metal scale version of the original Cub gear. Am I mistaken? If so, what's the difference? Would it be worth the extra cost to obtain the Robart gear? I'm willing, as I want not only true as is practical scale, but strength and reliability. Is that goal met by the stock landing gear that comes with the ARF? Or should I go with the Robart?
I would sure appreciate some insights on this question - and of course, some pointers on which way to go. Thanks for the help.
Mike
Douglasville, GA
Old 08-31-2013, 08:07 AM
  #1424
althepal88
My Feedback: (31)
I put the PA 18 cowl up to my J-3 and yes, it will fit perfectly. You will have to fabricate new mounting blocks. You are on your own if you are looking to match the paint. The closest commercially available color match is Parma yellow that I use on my rc cars. Prime the cowl in white, color with the Parma, and then clear coat to seal the finish.
Old 08-31-2013, 08:10 AM
  #1425
althepal88
My Feedback: (31)
That is cool. I like the open window. Did you fabricate all of the parts?
