Reload this Page >
Hangar 9 1/4 Scale Piper Cub ARF???
Old 03-06-2014, 05:46 PM
  #1526
sj3cub
My Feedback: (9)
You can never have too many Cubs. I'm sure they will bring a 1/4 scale J-3 back. I just don't see how they could top the last one. It was right on the money in every aspect. I have the new PA-18 Super Cub as well, and its right on the money as well. Little off subject, but I wish they would downsize the 1/3 scale Decathlon to 1/4 scale. (I don't have a trailer) They nailed this one to. It is absolutely scale and the best looking Decathlon ever produced. All the others on the market are plum silly looking. Pilot-1, RCGuys, ect ect....... Far Far from scale.
Old 03-07-2014, 08:43 AM
  #1527
motor12
motor12's Avatar
I hope replacement parts are available for awhile. There must be thousands of H9 cubs flying all over the planet...
Old 03-07-2014, 10:00 AM
  #1528
Lifer
Lifer's Avatar
I wouldn't count on replacement parts being available.
Old 03-07-2014, 04:43 PM
  #1529
motor12
motor12's Avatar
My Cub showed up today. Had fragile stickers, top load only stickers all over the box. I did see light damage on one corner but was not about to refuse delivery for that. I took the box inside, took photos just in case. Opened her up and started to inspect everything. All was good except the vertical fin had some damage. The repair should be simple, just glad it made it without serious damage. Now the fun begins, assembly is the time to do any mods/changes to improve on the design. Thanks to this thread for some great ideas...
Old 03-19-2014, 06:34 AM
  #1530
motor12
motor12's Avatar
The assembly of my H9 cub is just about complete. The only mod I did is adding the 6 inch Dubro tires, and convert to electric E-flite Power 160. I am waiting to see how the gear holds up with the large tires at zero pressure. I started to do the oring gear mod but am concerned about the welds that attach the 4-40 nuts to the gear leg. It seems like they could be twisted off easy then your screwed. Is this mod holding up or are there problems. Looking to maiden soon, just need the perfect day.
Old 03-19-2014, 07:25 AM
  #1531
GalenB
My Feedback: (18)
Did the O-ring mod years ago and it has held up well for many flights.
Old 03-19-2014, 11:02 AM
  #1532
Lifer
Lifer's Avatar
I have the big tires on miner as well. They absorb a lot of shock.
Old 03-19-2014, 05:18 PM
  #1533
cannonball200
My Feedback: (36)
cannonball200's Avatar
Same good luck as Galen, I did the O-ring mod 3 years ago and have no problems with many landings. If you use the existing springs that come on the gear, they will stretch out and your cub will get the sags. It happened the first few landings and they were not hard landings at all.
Eddie
OKC, OK
Old 03-20-2014, 03:27 PM
  #1534
motor12
motor12's Avatar
Eddie
OKC, OK
Did you guys do the gear mod as it is described in this thread. If so I may go ahead with the mod. thanks
Old 03-20-2014, 08:28 PM
  #1535
sj3cub
My Feedback: (9)
1/4 scale J-3 now shows back ordered, and not discontinued. All out of stock parts show back ordered as well, so maybe its not discontinued after all?
Old 03-21-2014, 08:58 AM
  #1536
cannonball200
My Feedback: (36)
Yes, I did mine as described and it has worked fine! By replacing the bungee covers it also keeps the O-rings clean and they seem to last longer. But,?? you also have to check under the covers to check sometimes too..
Old 03-21-2014, 09:02 AM
  #1537
motor12
motor12's Avatar
Thanks guys, guess I will do the oring mod as described on the thread.
Old 03-26-2014, 07:44 AM
  #1538
bikerbc
If you use 1/8" shock cord it will hold up better and last longer than O rings . I usually make one 16" band and wrap it around until it feels about right . One for each side . I found the o rings worked much better than the springs but they still cracked and broke all the time . The shock cord lasts forever.. You can usually get it at sports stores .
Old 03-26-2014, 11:25 AM
  #1539
motor12
motor12's Avatar
How are you wrapping the cord around the gear leg, photo would be nice. I just finished doing the oring mod but I am open to other ideas. If the orings are not working I would give the shock cord a try. Thanks
Old 03-27-2014, 09:56 AM
  #1540
HELI-MECH
Default Bungee landing Gear Mod and pa18 shock covers
I have just comleted the bungee mod, instead of the orings. I threaded small screws through the small welded nuts and then tied one end of small bungee cable (bought at walmart) and then did about 12-14 some what tensioned wraps on each side. So close to 24-28 wraps per leg total. I also fabricated shock covers like the PA 18 as this plane is being converted to the PA18 from the J3. The springs that were on it seemed super tight, i would rather have a more forgiving landing gear.
ID:	1982014   Click image for larger version
ID:	1982015   Click image for larger version
ID:	1982016   Click image for larger version
Old 03-27-2014, 11:16 AM
  #1541
HELI-MECH
Default Floats pa18 from j3 conversion
A bit early but still no engine in it either so why not have some floats on it too... lakes frozen!
ID:	1982065   Click image for larger version
Old 03-27-2014, 11:20 AM
  #1542
motor12
motor12's Avatar
Ya gotta love a cub on floats..
Old 03-28-2014, 02:59 PM
  #1543
bikerbc
I am sorry I am unable to load photo at this time but using the shock cord is the same as using o rings or rubber bands . You just make a big band and then wrap it around the same little catchers that catch the o rings . When you tie the knot in the shock cord to make the band ca the knot and pull it nice and tight . You can adjust your tension by adjusting how many times you wrap it around your catchers..They really work great.. Sorry I cant load some pics..I will try and get my buddy to take a few for me.
Old 03-28-2014, 03:09 PM
  #1544
HELI-MECH
I like your method better than mine. I may redo mine with your method.
Old 04-25-2014, 04:54 AM
  #1545
HELI-MECH
Hey guys, could some one do me a favor?? I'm missing my aileron to servo push rods, i need the length of the push rods only and then what size they are and the ends. Gotta order some and dont need to order the whole push rod set!
Old 04-25-2014, 10:11 AM
  #1546
bikerbc
What plane is this for ? the Hanger 9 J3 ? I only have the PA 18 .. I would just measure the distance and make some up out of 4 40 push rods . Solder clevises on one end and thread on on the other end
Old 04-25-2014, 10:27 AM
  #1547
bikerbc
Often the manual will give the exact length . If you don't have a manual you can down load one on line ..
Old 04-25-2014, 10:34 AM
  #1548
HELI-MECH
Thanks BikerBC, lookin like i'll go with your first idea, silver solder a clevis end onto one end and use the threaded portion to make the fine adjustment on the other end. THanks, and i did find the actualy length finally, 4.75" But i'm going the solder route as i have some 4-40 laying around. Cheers.
Old 04-25-2014, 11:44 AM
  #1549
Lifer
Lifer's Avatar
A big plus 1 on the silver soldered clevis approach. I also like to use the Sullivan Golden clevis with the keeper on the end of it. Zero failures.
Old 04-25-2014, 02:49 PM
  #1550
HELI-MECH
Done deal, will go this approach, need to buy some more clevises.
