Hangar 9 1/4 Scale Piper Cub ARF???
Reply
Old 04-08-2018, 06:35 AM
  #1726
cannonball200
My Feedback: (36)
cannonball200's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fred, I got it from Jerry Cotter in NJ. jerry@gcotter.com $125.00 shipped.
He was making these about 10 years ago and I messed up and didn't get one. I emailed him & he said he could still sell me one. Great quality.
cannonball200 is offline
Old 04-08-2018, 05:32 PM
  #1727
cannonball200
My Feedback: (36)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 04-12-2018, 07:40 AM
  #1728
cannonball200
My Feedback: (36)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 04-12-2018, 08:06 AM
  #1729
SKuhn68
SKuhn68's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by cannonball200 View Post
Jerry Cotter Maule type 1/4 scale J-3 tail wheel I just bought. It is awesome.....
That's fantastic! A bit above my pay grade, but beautiful.
SKuhn68 is offline
Old 08-13-2018, 01:26 PM
  #1730
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Picked up a NIB H9 cub. I'm planning to use my O.S. FT-160 twin. Was wondering if anyone has a picture of this plane and engine? Would like to see how much of the cowl needs to be cut away.
smkrcflyer is offline
Old 08-14-2018, 06:35 AM
  #1731
Jb Stearman
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Steve,
I fly my cub on a G 26 and have plenty of power even with floats. The original H-9 quarter scale J-3, when it came out, used a G-20. It equates to about a 120 size 4 stroke. I wanted a little more power for the float setup. I also fly my Balsa USA 1/4 scale J-3 with an OS 160 twin and have no issues with power. The 160 equates close to the G-26. The cutouts for the cylinders, exhausts and needle adjustment are not that hard. You will probably have to trim away the dummy jugs on the H-9 cowl. Use the cardboard template method and take your time. I split my cowl like the full scale cub to make it easier to get to the 160 for adjustments etc.
Jb Stearman is offline
Old 08-14-2018, 07:38 AM
  #1732
althepal88
My Feedback: (30)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't have a pic, but on my J-3 with the ASP (Mag) 160 twin, I just cut out the faux cylinders and kept the eyebrow air scoops in place, opening the scoop portion. I split the cowl horizontally from the middle of the opening for the prop hub, straight to the back. I used the four built in screw mounts at the rear and added small blocks of hardwood just aft of the rear cylinders and right in the middle between the prop hub and the front of the cylinder. I used the small #2 hex s/t hex screws and dabbed some cub yellow paint on them. The cowl stays firmly attached and the cut lines are fairly invisible. Not perfect, but it works for me.
althepal88 is offline
Old 08-14-2018, 07:44 AM
  #1733
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the feedback.
Old 09-04-2018, 07:00 PM
  #1734
LUDS96
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dle 35 ra
I have and Older Cub from Hanger Nine. The one before the current one. Running a DLE 35 RA balanced Perfect fly's scale or outrageous. Flys for 1/2 hour or more on a 24 oz tank.
Fly all day for a couple of Bucks. .
LUDS96 is offline
Old 12-20-2018, 04:09 PM
  #1735
crazystick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The cowl as it was being worked on
A day at the field
You can see some of the top details
Got my J 3 and started flying it in 2009 , about 200 flights that year . After that flew it often till 2017 , probably another 400 to 500 flights . On one flight wind changed 180 degree's while doing touch and go's ( thousands done ) lost control and damaged undercarriage and fuselage . Took about 7 months for the conversion to a NE 1 with much more detail . I filled in around the dummy motor ( warts ) and did some engine detail . Still not completely finished with the motor ( dummy exhaust pipes ) . It has flown and has @ 40 flight on it now .
crazystick is offline
