Installing Servos
OR
Installing Servos
Is there any trick to installing servos?? I thought that I once heard that the servo should be installed and fastened with the provided screws. Then removed, a drop of thin ca applied to the hole and then re-installed. Is this correct?? Any guidance would be greatly appreciated.
RE: Installing Servos
Yep
That's pretty much correct.
When I install them, I do the screw up into the hole but not completely tight - just snug
I then remove the servo and apply a drop of thin CA to each hole and let that fully dry. this hardens up the threads in the hole.
I then install the servo and tighten the screws to the correct tension.
I also use an unserviceable servo (which I have removed the wires from) as my drilling jig. That way I only install the actual servo once.
