Ultimate biplane, mid-sized arf.?
#51
AZ
RE: Ultimate biplane, mid-sized arf.?
I have the nitro model ultimate and it is a great flying plane. I beef up the firewall and put and OS 160. The only hardware I use from the kit was the gears. All the other stuff I changed out. I have the lastest ver. (yellow) and have about 80 flight on her with no problems
#52
ORIGINAL: patzane
best I can tell in this thread the next largest engine thats has been used has been a 150 four stroke which I think was a Saito
(and I think this is bored out Saito 130 so it weight is ~ approx 800 grams and my MVVS is 160 glow is 900 grams not counting tuned pipe )
So I very interested to get any info 160 and larger to see if there is any important issues
When you say OS 160 is that 2 stroke or four stroke? glow or gasoline ?
( as the only one listed at OS is FT160 twin but if my memory serves me there was a 2 stroke single cylinder some years back )
and what mix ratio fuel % nitro methanol oil type if its 2 stroke or four stroke glow type ? if possible
what propeller are you using ?
I didn't beef up the firewall although I considered it and did 5 tanks plus static test runs mostly at WOT to verify any signs of issues and saw non
I also fitted epoxy 1.5 mm sheets behind the engine mount as sorta big washers to spread the load and allow change of engine angles with insertion or removal of sheets
Also I did epoxy paint the whole nose region outside and inside the fuselage where tank was and it helped when tank sprang a leak in static tests
When you say you swopped out all the gear did you replace fuel tank with what and what other gear to swop out is there except engine mount and undercarriage
Interested to know these details as 80 flights later I want to be sure I didnt forget something important and figure these kits would be very similar in make up and might even be built at same factory who knows
I want to go for lower pitch prop like 18*8 or even 18*6 but none was available and later on even try out a 3 bladed 16*8 to see which works best at 3D hover work and general low RPM low speed maneuvers close to the ground and more in your face style acro and also slowest down line descents from vertical so biggest draggiest props would interest me even if it four bladed as gobs of power to spare
I know I am asking a lot from a low budget motor like 2 stroke MVVS 160 glow but budget for fancy stuff like four stroke or or high end isn't there yet !!
so suppose I got to ask the boss for a raise !!
balsaeater
#53
ORIGINAL: balsaeater
#55
Reatzane
Thanks for info
I have on order a 18*6 to replace the 18*10 as even on tick over its doing 40 mph plus due to the deep pitch so the maiden flight landing was done with deliberate engine cut off and glide in and the field I often fly from has a small landing zone and tricky landing with slope
I mounted the engine upside down for the tuned pipe issues so I cut the bottom of the cowling and have a tuned pipe running down on side of the fuse which doesn't worry me as I am not a scale type person but there wasn't a sports plane that suited so I got this one
If one needed to with the MVVS 160 there is a muffler that sould allow a side mounting or if the tuned pipe manifold was bent and modified to suit the angle a tuned pipe under slung version should be possible with motor at semi side mount angle
Balsaeater
#56
EEEEKKKKK tourque roll affects nearly got me close call
Spent most of the day flying the plane having fun acro and multiple landing takeoff touch and goes all the works to start sorting out all the gremlins with a 20MPH plus strong wind blowing onto the sloping club field peached on the side of the hill
Most take off's are down the runway well behaved no issues for thirty feet or less and then climb vertically often choosing to roll on the way up to 500 feet in seconds before leveling off and settling into other maneuvers
Acro manovers are usualy done 1/3 to 1/2 gas but can loop froma dive an less than 1/3 gas
Jaw dropping power with other club members commenting are you sure there is eneogh power to meet my needs ???
For landing the prop 18*10 is not so good as difficult to get the correct sink rates so often tends to be a sinky risy gentle undulating affair until touch down and hopefully next week changing to APC 18*6 will cure that with better RPM control affects
On one low level pass slash touch and go decided to do abort for practice two feet of the ground and decided to gun the gas while two feet up and then discovered the nasty torque roll affect [X(]which bites hard and dropped wing tip barely cleared scraping the deck but ended up in five feet doing a near 180 degree turn and pointing down wind climbing fast on full gas and wondering what happened to make such a handbrake turn event happen so fast [sm=red_smile.gif]
you cant beat power to extract the plane from a self induced mess
Hopefully the lesser pitch 18*6 APC will reduce the torque roll affect
Not a great fan of the Aluminum alloy U/C which splays out too easily in a half baked sink landing so for novice pilots will be better off with lighter motors and keeping weight down
I now use Brass bolts with notches cut so as to snap and that was tested and snapped according to plan when the motor quit on approach because I pushed the flight time too far [X(]and ran out of gas and landed short on rougher terrain [sm=red_smile.gif]
I will look for Suitable off the shelf replacement UC or if necessary make one with Epoxy Glass and Carbon as on windy days with the runway being on the side of a hill turbulence can make landing interesting rough especially if wind comes from the mountain side and creates down lift so landing tend to be hang on the prop and plop down
Later I will do a build thread for the Graupner Kit version but camera is broken presently
EDIT 6th April 2008
Severe crash but got lucky not too much damage
Flying in 25MPH wind did a low slow 30foot high pass for preparation for practice touch and go circuits opened the gas to climb to 500 feet to start circuit and motor started to sag and stupid kept into the turn hoping to compete the circuit and land and re tune motor but
motor continued to sag and now falling like a brick going fast downwind with only eneogh control to keep wings level so as to land flat and fast but a gorse bush caught the right wing when two feet of the deck and tore of lower right wing but did kill the fast landing speed so damage is the wing fix on system bolts and holders so a few hours work to repair
I am going to to fly without the engine cowling until I get at least 50 flights trouble free running so I can find this gremlin which I took to be idle jet too lean and thought i had cured it as last few flights were excellent tuning but it wasn't to be
Balsaeater
[sm=red_smile.gif]
EDIT 6th April 2008
Balsaeater
[sm=red_smile.gif]
#57
Well guys, I finally maidened my Ultimate by Carl Goldberg (post 10). I just couldn''t believe how well it flew. Being my first biplane, It was different but I really liked it. I don''t really care for how it is rigged though - it takes forever to put it together at the field. The Pin that holds the top wing on is really hard to line up. I had 3 flights on it and Saturday was a really nice day, sunny 70 degrees and no wind. I took off and just felt comfortable that day. I was doing all kinds of stuff, loops axial rolls (axial rolls are very fast - even on low rates!). So, about 1/4 way through the flight I went verticle (it has a TTpro1.20) and backed off the throttle, nosed over and did a beautiful blender, leveled off, I heard a pop, then seen the center of the top wing bow up a bit, two more pops, the cabine struts were fluttering to the ground like confetti and the top wing just blew off!!! The plane beat it to the ground by at least 3 minutes. I almost had it and at about 80mph, it snapped in, spreading debris for over 30''. I just stood there watching the top wing spinning and floating to the ground. It literally went to a thousand peices. What happened is the center wire slid out and the two struts couldn''t hold the weight.
There was about 25 people there watching and it was dead silence. So I said, (to try to cheer myself up) At least I don''t have to land it now!!! Anyone got a garbage bag!!?? I couln''t believe how fast this plane was though. I thought biplanes were suppose to be slow!?
Oh, well. Back to the drawing board.
Jeff
Jeff
#58
ORIGINAL: HUNTERANDJEFF
...edit ...
...edit ...
I don''''t really care for how it is rigged though - it takes forever to put it together at the field.
...edit ...
and did a beautiful blender, leveled off, I heard a pop, then seen the center of the top wing bow up a bit, two more pops, the cabine struts were fluttering to the ground like confetti and the top wing just blew off!!! The plane beat it to the ground by at least 3 minutes. I almost had it and at about 80mph, it snapped in, spreading debris for over 30''''.
...edit ...
Jeff
...edit ...
...edit ...
...edit ...
...edit ...
Jeff
I agree about the assembly on the field but I got a small car and need a compact plane for this car and for futur airliner travel so I put up with it and am also devising quick release solutions to speed things up
I suspected that the top center wing holding on solutions were not strong eneogh for my liking with the Graupner kit which is probably similar methods as the other make of Ultimate so I changed the system to my own solutions
I put a two thin 0.5 mm sheets of epoxy circuit board some two inch wide nearly the full length of the wing cord on top of the wing
( which for the scale guys looks bad if not painted correctly )
and had the 4 holding on bolts 3mm steel come out through the top wing with two bolts on mid front two bolts at the mid rearward section with heads of bolts on top of the wing ready to receive wing nuts for holding down the top wing
I have done severe manovers including fairly fast down lines to test the system and no sign of issues but my general theme is to fly slow to medium speeds on the level and down lines with only full fast for the uplines
Your motor a TT120 would if you put on a fast revving small prop at full tilt have the ability to reach not to exceed VNE speeds for that class of plane
My MVVS 160 has got on it the biggest prop possible to help reduce the risk of over speeding the air frame but the 10 inch pitch is a tad too deep so I have to ease back on the power a lot
I hope a 18*6 prop will reduce the risks of getting up too much speeds inthe level and down lines
If I put on a small fast revving prop like a 16*12 the risk to go too fast for the plane would be increased a lot
With these class of planes they will with over size engines using high speed props reach speeds that will break them up very easily
The trick is to use the extra large props for great handling and grunt tractor pulling abilities at half throttle and to know more than half gas at level or descending mode of flights risks overspeeding the planes
The Real Ultimates are actually very fast over 200MPH and no slow coach but they can slow down a lot to do slow acro as well and the pilots needeed to use the gas and not exceed the VNE speeds or design limits
I love blowing away the guys with my high speed climbing as that gob smacks them that my plane makes thier chug along get to 1000feet in ten minute weedeater engines look so so slow as I get to 1000feet in seconds maybe 10 seconds but coming down I have no gas input and use the big prop like a big airbrake as I want to arrive with all the wings still intact
If you can afford it get another Bi-Plane but don't be afraid to beef up anything your worried concerned about and go online and seek advise
The plane with my engine MVVS 160 engine can be made to fly real slow sub 20mph as it passes the runway gas at 1/5 th or less with less risk to be swatted down with down draughts as any drop in height I just pull a tad more up and apply a tad more gas and plough through the down draughts as if they dont exist not like a tepid 2 stroke 90 where the risk to be swatted down are higher as the smaller props cant grip the air so good
Later I will be prop hanging past the runway on the way to do 3D but I prefer to replace the 160MVVS with my new found expensive purchase 180 Saito
I have a graupner 1.8 meter CAP for the MVVS 160 to go into and the UlTIMATE biplane will get the Saito
Now I tested the facts with some 50 flights and the wings can stay on and the planes bugs are ironed out it seems that another engine that weight is the same some 950 grams which turn the same prop 18*6 at the similar speeds it seemed to me it offered the best solutions for me
It seems in my reasearch that all the 3d guys with the OS160FX 2 stroke motor need and all use a pump for that engine
If that is the case for that motor I supect its the same for the MVVS 160 and I wont cure the motor cut out incidents until I ether fit a pump or fit a motor that wont need a pump
I prefer for my Biplane to keep it simple stupid no pumps and went to buy a suitable Saito maybe 150 but the 150 these days is bored out to 180 and so I was even happier to get a more closely matched engine swop
Also I am anxious to keep noise levels low on the Biplane as I would use it most often visiting other clubs which sometimes sufffer more noise related issues so a big motor with big prop turning slowly on 1/4 gas will be fairly guite and quiter than the MVVS 160 although fairly guite at 1/4 gas but which unfortunately after half gas started to be a bit more growly than I expected
hope you come back and solve the wing losing problems HUNTERANDJEFF
balsaeater
#59
Oh, I may come back and solve them. The plane is a total loss, not rebuildable but I have another one identical to that one that needs rebuilding in the shop. I have 3 sets of wings for it. I may end up rebuilding that one for I really loved the performance of that plane with the Thunder tiger pro 120. I went to thunder tiger last year after being an os fan for over 20 years and never looked back. I just cannot believe how good they run and the power that they put out.
I was running a 14X8 master airscrew at the time of the crash and was going to change it out after complete break-in. The engine is fine but needs a good inspection and cleaning. When I pulled out of the blender I was not at full speed. I never pull out hard at speed - I broke a set of wings years ago and learned my lesson then. I did have two flights on it before this incident and on the last flight I was hanging it on the prop and harriering it around at slow speed alot. The wire pin just slid out. The next one will have the top wing bolted on.
Jeff
Jeff
#60
The biplane was really fast? Most biplanes require a bunch of excess horsepower to bust through that end of the envelope.
Since that airplane is actually a 60 weight airplane that''s designed to use a 60-90, it''s not really got a design that has a strength safety margin. You''re asking it to handle basically twice the engine for the weight of it''s structure.
Blenders are supposed to be pretty hard on airframes. And oversized engines are hard on airframes for sure. And you proved both in just one flight. Next one you build, make sure to strengthen it everywhere extra horsepower can overpower the airframe. Because you''ve proven beyond doubt what it can''t handle. Or maybe just put a 90 on it. You won''t get the awesome speed, but a 90 on an 8lb airplane WILL show good vertical.
#61
Da Rock, I did have the airframe totally beefed up - firewall, landing gear every joint in the entire airframe. what happened was the piece of wire that holds the center of the wing on to the cabine slid out. I forgot to put a rubber band on it to secure it. Stupid mistake on my part. The three flights that I had, I never had it at full throttle for very long - just long enough to know that it was about 90MPH straight and level. It would slow down to a very slow, stable crawl for the prettiest landings. This particular plane weighed in at 10.5 lbs and I was very surprised that in the balancing I didn''t need to add any weight to balance it anywhere. It had two servos for the elevator and two for the ailerons. On the directions in the kit it only calls for one for the elevator and 1 or 2 for the ailerons. that is why (with the larger engine too) it was just a bit heavier than stock.
I read alot of different forums on this plane before I built it for the engine and almost everyone that I read the pilots were starving for more power on this particular plane. So, I went with that TTpro 120two stroke - very strong and lightweight. If I do build another (I have one in the back room) I will put that same engine on it but atatch the top wing more securely and stronger with bolts instead of the cheezy wire.
Jeff
Jeff
#62
AZ
Does anyone know why the red, white and black 60.5" Goldberg Ult. was discontinued? I dont think I have even seen it before. I noticed it on towers site. It looks(ed) pretty nice.
Stangevil29
Stangevil29
#64
Busy installing the new Saito 180 into the Graupner ultimate
MVVS 160 will go into a Sokoi in few months
Found a video of a Ultimate type unknown with Satio 180
http://video.google.com/videoplay?do...LP-I3RCQ&hl=en
Nice fast vertical climb out after take off but looks a tad slower climb than the MVVS with 18*10 but still fairly fast
The video is from Germany and the one of tail planes falls off and but he lands OK
balsaeater
balsaeater
#65
Yesterday got in three good long flights and one short flight
Fuel used is run in type zero nitro and 20% EDL oil 80% methanol swinging a 18*6W rpm unknown no rev counter
Everything went well until the last flight when the fuel tank sprang a leak from cracked fuel tubing and made engine run burbly and quit lucky high up so needing to glide back
Lucky I always fuel proof paint inside the interior of the fuel tank region in epoxy paint to gaurd against fuel leaks
Fuel consumption on Zero nitro fuel with several tanks done on static infer the 20 onze tank will supply 20 minutes on half gas ~1 onze per minute and half the at again on full gas or ~2 onze per minute
With extrapolation 30% nitro I would expect full gas to be 50% more consumption than zero nitro fuel or ~3 onze per minute but half gas with same RPM would probaly mean the stick would be at 1/3 position and expect fuel consumption to be marginaly greater at say 1.3 onze per minute
more fuel tests will show up the real world results
Fly wise the uplines were good and so was slow flight
Sustained continious hover wasn't properly achieved due to my inabilty to do hover but seemed that 1/3 to 2/5 gas was hover point with 1/2 gas being a very good climb out of more than a ~100 feet per minute
full gas climbs were very fast and take off were short with unlimited vertical to speck in less than 30 seconds estimate vertical climb speed to be ~40mph plus
Landing were simple and very slow high alfa with such a big prop
Tourge roll with the low pitch prop seemed very non existant as compared to MVVS with the 18*10 which could on rapid spooling up cause serious torque roll issues
Spool up with the large prop heavy weight APC 18*6W was a tad slow so18 inch light weight prop or 17*8 prop and higher nitro like 10% would probably sort that problem
The only big disapointment was the down lines were still unuseble approx ~60mph and very fast even with the big low pitched prop and even a three or four bladed prop doesn't look to be able to solve that issue
Figure with the high wing loading the only way to slow the downline will be to to find a varable pitch prop and apply reverse thrust in the down line
The other suprising thing was how noisy the motor was at above half gas especialy considering the prop is the biggest propeller possible and so revs would be lowwer than say a 16*10
As most of my flying will be 1/4 gas to less than half gas it means most of the flight will be fairly quite but I will be looking to investigate and possibly use extra noise supression solutions
I am reposting this vidio from Germany of a similar slightly larger Ultimate plane with Saito 180 as I forgot to post it in the last post
this vidio the guy fly fast all through the flight where I only use full gas for the uplines
Balasaeater
Balasaeater
#66
AGGGHHH engine flame out thirty feet up and humungous crash
The previous weekend I did a few flights and everything went well and hover seemed to be at 1/3 to 2/5 gas and slow fly low passing rolling over the runway was fantaastic with landing a simple event of of getting the right RPM and landing gentle as a feather much as I can do with my electric fly which turn big props slowly
The only minor complaint when the engine runs is is it seems a tad too noisy for me coming from a mostly electric flying so I am going to look for better silencer solutions
As the engine is new I use 20% EDL zero nitro fuel and the engine is only ever going to 3/4 to full gas for short bursts on the up lines and it will go to over 500 feet in seconds
The next weekend my brand new Saito 180 was running real well with the 18*6 on 20% EDL zero nitro and was half way into the the 20 onz tank after ~10 minutes where mostly was flying in low level Lazy circular circuits for my friend with a Vidio camera in his 40 sized fun fly plane could fly behind me and film the Bi plane in the air ( the vidio didn't work out but thats another story )
Doing a Turn with a 10 mph breeze and down wind the engine flamed out and the plane as per Biplanes don't glide engine off nosed down a lot and lost a lot height fast with no possibility to flare
The off terrain 30mph 30 degree nose in impact broke a lot of wood mostly in the mid section of the fuse and one wing and it has taken me some 15 evening to repair the plane
If kits in Europe were as cheap as the USA I would have scrapped the plane and bought a new one
But in Europe we pay often the double the USA does for the same planes due to tax and other factors
Therefore buying replacement kits hurts too much and even the replacement fuselage would nearly cost the same as the full kit so balsa bashing is practiced a lot
The plane is now fixed but the fancy colors are gone so now it is all white wings and differnt shade of red for fuse
I might flyit today if I get my act together
I suspect the cuase of the flame out was the fuel tubing might have perished with time and broke apart close to the exhaust so I have gone out and bought new tubing to replace the several year old stuff ~2003 I had in stock in case I revived some dead glow stuff
(It seems the new tubing will perish as it is colored silicone or rubber and isn't like the old stuff a clear hard plastic that was for life unless you put fuel into it and then it hardened and would last a few years if left alone )
Also in case the tubing didn't break until after the crash I will add 10% nitro to the fuel in case the long running at 1/4 to1/3 gas made engine quit
I need a few big planes that use Glow fuel or gasoline when I go on holidays to Spain Italy Turkey Greece whatever
This is because I cant obtain a 3KW generator at a sensible price to recharge the large lipos packs at the holiday fly location and renting a Pruis 30KW generator is still too expensive ( also they don't supply tap into points to access the big NiMh reserve batteries )
Also airlines wont allow big quantities of lipos (some few lipos to do park fly is OK ) but 14s 10,000 mha is a non starter so the big packs have to go on cargo planes with huge costs for return flight (You could buy the packs at the destination cheaper than shipping them so often I buy new packs at holiday location and sell them off after the holiday to solve that problem )
All these factors mean where normally I would if power supply was available do electric my power source of preference especialy as the costs are dropping is due to my experience that most all my repair work with big Glow planes comes from some form of off terrain flame out ( less mechanicaly challeged could dispute that but electric cured those type of crashes for me and I tend to do a lot of low level hugging the deck in your face flying where flame outs don't allow much gliding )
Therefore I have to keep some few liquid fueled engines for a long time to come but this repair job convinces me more to invest as much as possible in Electric solutions
Hopefu;lly in ten years I can put my Saito 180 and MVVS 160 and Gasser 80cc into the same box of much smaller glow engines some 20 of them not used since ~1996 which I keep in my collection for museum pieces where the electric took over that sized engine
Balsaeater ( eating up lots of balsa recently)
