Great Planes Viper 500
RE: Great Planes Viper 500
I've seen a few in the air.
It is a Quickie 500 pylon racer, meaning it can go pretty fast and take hard turns. Looks like a pretty predictable "goes-where-you-point-it" plane when slowed down. It even glides...
I think some of the guys had trouble with the wheels: wheels falling off or not turning.
My Feedback: (8)
lol ah i had wheels falling everywhere on some of my planes before, easy to fix though. Looks like a nice fast plane.
I had trouble with my fast flying wing over 80 miles per hour but i wunder if its strong for doing crazy stuff. I wounder
if the wing is strong too.
TX
The plane is made for pylon racing. It can take extreme high G turns and is capable of going very fast. The control surfaces are very small and the ailerons are located inboard on the wing rather than outboard. This design allows for great stability at high speed but is not good for "crazy stuff" aerobatics. You can loop, roll, fly inverted and even knife edge, but that's about it.
MN
With a sport .40 / .46 the viper is capable of going 120 mph.
With a Nelson or Jett .40 racing motor, 160mph+ is possible (and the wing can handle it).
It is capable of extreme G hard turns or loops, but very limited with Ailerons authority, so rolls will be slow. The V-tail is effective, and I have seen them to something close to a snap (more like a barrel roll).
The plane was mainly for racing and just going fast, if your looking for something aerobatic, this probably is not what your looking for. The wheels are garbage (don't even attempt to use them, they will fall off), the covering on many that I have seen is VERY loose and wrinkled (so be prepared to iron/heat gun that), the fuse just in front of the V-Tail is structually weak in my opinion and needs reinforcing, things are tight in the fuse (Mini servos / receivers / batteries help, but it is tight), and lastly the incidence of the tail has been questionable on some versions. Shimming the tail is typically needed to fly it level without adding trim to the elevators.
Other than that, its not a bad plane, if you want to go fast.
Just finished mine got a OS 55 on and wil run a 8.75x7.5w APC prop. The wheels are crap wil get better ones from LHS tomorrow. The covering overall not to bad some loose points but not really bubbles- nothing searous. Needed to shift the battery forward + lead in nose to get cg correct. The tank is small so time in the air wil be limmeted to about 5 - 8 minutes I would gues, wil see tomorow how fast it can go cant wait for the maiden on this one
Maidened today this thing is an arrow tracs nice and straight only needed 1 click up elevator, very stable. I used high rates for take off and landing only on full throttle high rates is just to much. At low altitude its a blast screaming past and very stable at slow speed, landing is easy, had no wind today so wil need to see how it handles wind. If you are looking for some adrenalin pumping at a reasonable price this is defanatly a plane to consider
roofer
roofer
jservantes 11
Did not take a pic but take the link to greatplanes site
http://www.greatplanes.com/airplanes/gpma1265.html
My Feedback: (94)
I have one and love it.. goes together super fast... I put a ST 40 in it, as this was to be the standard motor in the club races we were going to have here locally (never got off of the ground). Anyway lots of fun if you want to go fast, and it's small enough to fit in most vehicles in one piece.. just don't expect any aerobatics out of it.
My Feedback: (94)
o yes, it's easy to fly.. and it can actually fly quite slowly. just follow the control throws that are in the manual and you should be fine. The only problem that I can think of is that with the thin wing the plane doesn't slow down very well for landing aproach, so you will probally over shoot your first couple of aproaches.... guys that race these planes usually just kill the engines and land them dead stick...but I would say get to know the plane first before attempting that... the only other thing is that the plane sits pretty low to the ground which doesn't allow for much prop clearance. I run a 9in prop and it always cuts the grass on take off, I would imagin taking off and landing from pavement can easily cause a broken prop unless you are extremely careful.
My Feedback: (8)
Probably good to hand launch into the wind. I flown planes for years, but haven't flow nitro for years, I have a flying wing (f27c stryker from parkzone). Pretty fast
also but around 80 min. So I bet someone already mod the wing to accept longer alerons i bet. I wont have no problem but I damn do want a fast plane. Anybody
know any faster but better aerobatic?
i would not mod the ailerons myself at speed it reacts very fast as is. For airobatic that is fast maybe try a sundowner or revolver they are rather fast
My Feedback: (94)
Fast and aerobatic. Global tequila sunrise with a GMS .32 engine.
http://www3.towerhobbies.com/cgi-bin...?&I=LXK422&P=7
WARNING, this plane is extreme high performance and not for the faint of heart, it likes to fly fast and will snap like a mo foe !!!!
But going from the F-27 stryker I think that the viper will be fast enough and aerobatic enough for you. The aerbatic capability of the viper greatly outweighs that of the stryker. I say go with a viper a .46 size engine and a 9x8 prop. Good luck.
AZ
since the stock viper wheels are garbarge what wheel do you all recommened. I just finish my viper with OS 55. Final weight was 3lb 12oz dry. Did not have to add any dead weight. Will try to take her you tomorrow, if i can find better wheels from my LHS.
For now I got foam wheels on am batling to get good wheels in my country - what prop you running on 55 Im stil experementing motor is run in now and got a 10x8 apc on and am gonna try a 8.75x7.5 w apc dont know if it wil work ?
the lanier predetor is a better choice only because the covering is much better. basically they are the same. start out with a good engine like a os46fx or ax, or the tt40 as mentioned before. get used to the speed and hot landings. upgade in the future to a jett sj50,or just add a jett muffler to your engine for more rpm. jett also sells weels for these planes, i think.
AZ
well did the madien flight today with the Viper powered by a OS 55. Flew very well and handle very smooth. I was running a 10x10 prop. Speed was ok other guys at the field say it was going about 120 mph plus. Well try diffrerent prop but don't know what yet.
AZ
Flew Viper again today and all I can say it Fast. If I can get about another 20-30 mph of her I would EXCITED. So far guys at the field say it the faster plane by far they have seen at our field. Still running the 10x10 prop
ORIGINAL: jcervantes11
Anybody have any pic of this high speed plane? Maybe pic of the inside aswell?
Some information:
http://www.nswpylon.org/Setting_Up_The_Viper.htm
http://www.rcuniverse.com/forum/m_12.../anchor/tm.htm
