I need the CG for....
RE: I need the CG for....
3.2 inchs behind the leading edge measured at the top wing center line.
http://www.theworldmodels.com/para/i...on/html/A009S/
VA
I have the manual but read on here somewhere that the CG in the manual wasn't correct. I can't remember which way or how much. I finally got mine together, (I've had it since Christmas '06) and don't want to try and maiden it without the correct CG. Thanks
3.2 works fine.
The plane can tolerate a good degree of variance.
I've flown it with the C.G. both forward and back an additional .5" and I didn't notice a difference.
