Cox Model 1/6 WACO YMF
CO
I picked up a cox model WACO YMF at a local auction and it did not have a manual with it. I need at least the CG point and the recommended throws. I found a PDF for the 1/5th, but would really like the one for the 1/5th.
RE: Cox Model 1/6 WACO YMF
I have the 1/5 model. I figure the c/g is in the same relative spot for both the 1/5 and 1/6. I can't give you a measurement on the 1/6 scale, but mine balances at a point immediately forward (<1/4") of the rear cabane mounting point on the top wing. I balanced mine by putting my index fingers against the cabane strut in that spot and lifting the plane. If it swings to a fuselage level orientation, you should be good to go. Mine flies great at that point.
