Great Planes Escapade .40 ARF
#1426
SC
RE: Great Planes Escapade .40 ARF
ORIGINAL: harryangus
Anybody here had any weight problem with the Escapade?
I installed an OS AX46 and standard servos, allat the places recommendedbut as per the CG, the plane is about 6 ounces tail heavy.
Is6 ounces inbalance anormal thing for the Escapade or any other plane? I am new to the hobby, so your advice is appreciated.
Bill
#1428
I used the tail provided by the manufacturer. I followed everything.
The only thing I did was installing the battery on top next to the receiver instead of underneath.
The reason is that battery is not flat so it interferes with the wing.
#1429
Harry with mine I did change the tail wheel, But that said I put the battery under the tank moved everything forward and then had to add 5.5 oz on the motor mount as far out as I could. It flew OK not great until I had a dead stick. It fell like a rock, Total lost! I never replaced it because I have some low wing planes that really fly great so stayed with the ones I know for me that flys great! Will I ever try another Escapade maybe but I have many thats on my list to get first. Hairy
#1430
Thanks for your help.
I will move my battery over the tank and add whatever weight I need to the firewall.
But based on all the the mails I read here, I will make sure I am very good with my PT40 before I moved to the Escapade.
There are a few guys at the field who fly them, I will also ask questions there.
The problem I notice is that eah person has solutions based on their own plane.
Thanks a lot
Thanks a lot
#1431
Yes being there is guys flying the Escapade were you fly with success find out whats working for them kind of pick their brains on the plane! There has been allot of guys that have loved this plane, I have a low winged stick that I just love to fly and if the plane does not fly half as good as it I am kind of bias about the plane! most my planes if I use the battery and move things one way or the other I rarely have to add much weight if any! Where there is that much smoke on success with the Escaped there has to be some guys fired up about them. Mine was not a fun flyer. But it was a joy to look at, They are a beautiful plane!
#1432
SC
ORIGINAL: hairy46
As new as I am, it only makes sense to me that you determine the proper CG by what the plane tells you when you're flying .......not what it says on a piece of paper.Since Great Planes recommends the Escapade for inexperienced fliers I believe they have intentionally set the starting point CG forward of what is optimum. However, I think they actually may be doing a bit of disservice.While they'll certainly prevent people from stalling on takeoff, they are also making the plane harder to land than is necessary. The Escapade forums are filled with comments of people that the plane has to be landed "hot', some are even adding flaps, etc. when it really isn't necessary. You have to make your own decision but if the CG comes out anywhere between 63 and 70mm back,I would certainly try it and see how it flies. You could always get someone more experienced to maiden it, like I did, if you're uncomfortable about it. Just my $.02 (as I get off my soap box and don my flame suit ).
Bill
#1433
Bill, I really did not have mine long enough to make the changes that might have saved it! All I know at what was recomended in the book could not have been right because mine did not feel at all right in the air! So you guys informing the new guys that the CG in the book is wrong is a step in the right direction!
#1434
SC
ORIGINAL: hairy46
#1436
Bill, Never took it as criticism of me! I do think that because some in the tread balanced out without weight and others allot of weight that its a toss up on wich one you get! But that said I am happy that many can be saved from what I went through by just changing the CG! This is good because I not only lost a plane that day but had to fix a brand new OS AX 46 and lost servos that day as well. Not the only one I lost last year, I lost a trainer when the trainy got it out to far for these eyes, That one was my fault for letting that happen and my Tiger 40 when I lost everything when the servo tray came loose, I blame me there as well! But the Escapade fell like a rock without power, Without power it just rolled over and died! So those of you that has had success I am glad you are teaching the ones that have bought them what to do to get success out of them! I wish I had mine still to try some of the new idea's that seem to be working on it!
#1437
SC
ORIGINAL: hairy46
#1438
Lots of people at this site and the guys at the hobby shop recommended the plane to me for my second plane.
I think it's a beautiful plane at a very good price for an ARF.
But no matter what price it is, if you have to crash it on the first flight, it was not a good deal.
#1439
Maybe during the summer months, Thats when I do ARF's in the winter I build kits and have three kits going right now! I am replacing the Tiger two that I lost last summer, and the Trainer I lost, also building a Top flight P-51. The Tiger two is one of my favorit it flys very nice and can do allot with it and lands like a trainer! So I had to replace it because miss flying it! Summers is where I do a few ARF"S maybe put and Escapade back on the list of things to do!
#1440
SC
ORIGINAL: hairy46
#1443
Yea Capt it is, I was kinda bumbed out about losing the grand daughter out there and the kit you sent perk me right up and I really do not even think about whats her name anymore! life has to go on as well as the building! And you did forget the glue, So I got my 80yr old mother standing out there now just in case!
#1445
My Feedback: (89)
Hi,
Nice ARF model, and I know that they FLY GREAT! One of our club members assembled his and is using a MAGNUM 52, LOTS of POWER, nice combination, smooth flying model.
Local Hobby Shop has now sold 7 more.
Ken AMA 1528
Ken AMA 1528
#1446
hairy, i saw how you inspired the posse' over on the jets forum to make sure that planes that were promised to be sent were sent so i just wanted to make sure that kit arrived as promised. i am glad to hear you'er in where it is warm, building kits. tell your mother to stay put fore i believe the truck will be passing thru around 4a.m. with the glue. i sent you this special three part epoxie that works quite well if your very carefull with the proper amounts of the mix. i heard that you live near Sky King and if that is true send my love to Penny, happy flying, capt
#1447
Yes isnt it great that he got his money back! I am glad and hardly said a word on there about it, I never have much to say about anything! I tell you its the voices that get me into trouble! Well I better take mother a apple and a depends, She hates apples!
#1448
1 Post
Lots of people at this site and the guysat the hobby shoprecommended the plane to me for my second plane.
But no matter what price it is, if you have to crash it on the first flight, itwas not a good deal.
Every single Escapade I've seen seems to come out tail heavy on the CG machine. Don't concern yourself with getting it to 63mm It will fly like a brick if you do.
I loved mine with the CG at 72mm. Needed one click of down trim and three clicks of left aileron IIRC.
We're all trying to help you have the sweetest maiden flight with this beautiful airplane.
#1449
Tim,
I will have to CG it again and I will let you know.
As for radio, I have a plain vanilla 72 Futaba. No computer and fancy stuff.
My other hobby is boating so I am broke.
Just fixed my boat and tomorrow I am heading to the ocean.
Sunday I will solo my PT40 and I hope to start flying the Escapade in a month from now when I am polished with the trainer.
Will get back to you
Thanks again
#1450
ORIGINAL: capt1597
