Great Planes Escapade .40 ARF
#1826
I just looked at mine. The right thrust is almost negligible. So try to make measurements before you start adding right thrust. Because on mine, it's very little. Hope that helps.
#1828
Thanks!
John
#1829
Avistar Right Thrust
So what I did was take a straight yardstick and drilled in the center (at 18") a 1/4" hole so that I could mount it behind the propeller. The longer length shows the right thrust better. If you notice, from the tip of the left yardstick it's 8 3/4" and on the right it's 7 3/4" , which shows the right thrust. 1.6°
#1830
Thanks Tom. Very good!
Right Thrust in Sir! How about the wing halves, did you epoxy them together? I heard some people are reinforcing the wing halves together. What are your thoughts?
John
John
#1831
Yes, I epoxied the wing halves together. My escapade fits into the back of my van, I can just keep the plane together. Added fresh, thin CA to all hinges, top and bottom. Epoxied horizontal stab and vertical stab .(also used the bolts from vertical stab to tie it all together). Created a plywood spacer, glued between forward fuselage fake cheek cowl to prevent vibration.
The Escapade was one of my fastests ARF assemblies. But do take as much time necessary to do your research and get it right.
#1832
Also made sure landing gear block was securely epoxied in. See previous posts. Use thread lock on all bolts and set screws.
#1833
MI
Mine came in on the 29th. I just started building today. I am very impressed with the quality of this arf. The covering job is perfect not a single wrinkle or blemish anywhere and it is very complete with hardware. If it fly's anywhere as good as it looks it will be my sidekick every Sunday.
#1835
MI
I've got mixed thoughts about my Escapade. I haven't flown it that much since completing the assembly, but had it out last week. With the purchase of a new Tx this last Spring, I had to bind, reset all throws and basically go over the whole plane. So I took it out, got it up in the air no problems, and got it all trimmed out. I had it flying straight and level hands off. So I was getting a real good feeling for the plane and felt that it had a good "sport airplane" feel to it. Mine balanced out with the battery mounted right over the tank with a Magnum .46. While flying I'm thinking, "this plane is fun". So I started doing a series of stall turn arounds. I just kept doing them one after the other. I was having a blast until on about the 6th one I lost orientation on the down line. Not good, I creamed it into the ground. Landing gear pulled off. That landing gear mounting plate is crap ply, even though I did add triangular stock at the joint inside. The wing ripped off breaking both nylon bolts, the wing breaking into two pieces with significant damage. The canopy has extensive cracks. Interestingly the rest of the fuselage/tail/engine/electronics were in pretty good condition with only minor MonoKote punctures. So I decided to fix it. It's very difficult to find a wing set. I was able to find a new wing set from a new friend and fellow modeler on the West Coast with one of the wings having a damaged leading edge. I'll have to fix that. I'm not going spend the money for the decal sheet with that lovely "ESCAPADE" name and Great Planes decal. Fixing the new wing set might include grafting a piece out of the crashed wing. But again to do it right I'm going to need some Orange MonoKote (that I don't have) to match the original trim. I could go on and on. Sheesh, might be easier to just get a new air frame, but wait, Tower doesn't have them and my guess will discontinue the Escapade 40. There is definitely a love/hate relationship with this plane. Sorry this was so long, and is not my intention to rant. Just general thoughts.
#1837
Well I got it back together and put 7 flights on it today. It's a little weird with that semi symmetrical wing. If you get it trimmed out at half throttle nice and level, at a higher throttle it will climb. No big deal. Mine seems to land coming in "hot". I'd like to move the CG back a little, mine's not pitch sensitive so I'm pretty sure I can move it back. Should help in slowing it down and bleeding off speed.
Fixed.
Fixed.
#1838
Almost a year later and I'm still flying the Escapade. I can do 9 ten minute flights before my Voltwatch starts showing a warning. That's a lot of flying in one day. It's a good looking and flying sport plane.
#1840
That's great! I'm glad to hear that others out there are still flying it. The Escapade was always a good looking ARF sport flyer, but out of the box needed a few areas that need attention. Yeah, I've been flying mine a lot too. Good flights to you with that new engine.
#1841
Well I finished running the NGH 9cc engine in my Escapade on the ground. I am very surprised at the oil that comes out of the exhaust. Just about the same amount as my OS 46. That was a big reason for me to go to a gas engine. Not to have to clean the plane all the time. They have you mix the gas and oil at 20:1. So maybe that should be expected. I think I'm going to convert it to an electric plane. And try to sell the NGH. You win some and you lose some.
#1842
Is that for break in only , or are you supposed to always use 20:1 ? I only ask because 20:1 sounds like a LOT of oil compared to other 2 stroke gas engines I've had experience with .
And yea , I'd expect a 20:1 mixed gas engine to slime the poor plane just like a regular glow engine would , given the ratio of oil in glow engine fuel and all .
#1843
The 20:1 mix is used all the time. These engines also have a lot less power for their weight compared to a similar sized glow. This one is 1.2 HP max verses 1.9 HP for the OS46 I was using. The only advantage I can see is using gas instead of glow fuel. Which will save some money.
#1844
GP Escapade 40 back in stock at TH
If anyone is interested, I just noticed that the Escapade .40 is back in stock on TH (as of Feb 14, 2021) for $140
Great Planes Escapade Sport .40-.55 GP/EP 52.5" ARF | Tower Hobbies
#1845
Yeah, I noticed that too. It's a good plane as long as you pay attention to some of the earlier problems. Make sure the hinges are glued properly. The landing gear mounting plate should be epoxied in securely.
#1847
Can't believe it, but yesterday I put 5 flights on my resurrected Escapade. 2020 I hardly flew anything. But it was warm with some winds yesterday and just had a nice time re acquainting myself to the Escapade. Even got a compliment from a fellow flier. Pretty good for a plane I brought back from the dead. It's a nice sport flier that I'm going try to fly the heck out of it. It renews my previous flying ability and I can relearn what I used to do. The Escapade is neat. I do have a Tower Sport 40 in the box as a replacement.
#1848
Kind of like riding a bicycle! 5 flights in a day is a good day.
The Tower Sport 46 ARF you mean? I have one of those also. I posted a question about changing the inverted engine position. I don't want to mount a glow engine inverted on that one. I'll be experimenting with it.
#1849
Yes the Tower Sport 46 ARF, I think I remember seeing your query about changing the inverted engine. If that's what you want to do, go for it. I had a Tower Hobbies Razor 3d that had an inverted engine and only had minimal problems. Just have to be careful to not flood it. But it's your plane, you can mount the engine anyway you wish. I tend to follow the manual.
