Top Flite AT6 ARF
Reply
Old 11-02-2012, 05:01 AM
  #601
jet22b
jet22b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Top Flite AT6 ARF
Dick;
You are doing the right thing by dropping the stock landing gear wire. You can have the best smooth landing and they will bend!!
Sonny
aka
jet22b
jet22b is offline
Old 11-02-2012, 10:11 AM
  #602
Capt Easy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I thought it would a good idea after reading the results of the stock struts. Do you know the diameter of the stock wire? I must be metric....
Dick
Capt Easy is offline
Old 11-02-2012, 11:05 AM
  #603
maddieone
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Gang,
I started this thread back in 2008 and am truly amazed that it is stil active. Jet22 aka Sonny, Minflyer and I had a lot of correspondence concerning this plane and yeah I had a lot of trouble with the gear, used Toms boxes and finally got tired of it and gave it away. Will say that it is a good flyer but so is my H9 T-bolt and Mustang. And they both have great gear in them, just have to make a minor modification to improve ground handling. Never had a bit of trouble with bending or the gear coming out of the wings. Good luck to you all.
Curt
maddieone is offline
Old 11-02-2012, 05:19 PM
  #604
Capt Easy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm suspicious of the 1/32" piano flap wire connectors. I haven't read any problems with it but curious if it's adequate. It sure doesn't look strong enough. Has anyone used anything a more substantial?
Dick
Old 11-02-2012, 05:22 PM
  #605
ton2di
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Those wires are enough to hold the flaps together when deployed. Mine has almost 200 flights and has not caused any problems when landing.
ton2di is offline
Old 11-02-2012, 05:31 PM
  #606
Capt Easy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay sounds good enough then. I appreciate the relpy.....thanks.
Old 11-02-2012, 07:11 PM
  #607
jet22b
jet22b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Capt;
I was out flying my AT-6 today and I can say that wire is very good. After your maiden flight and this is what I did, take they plane up high and play with the flaps. You will find they do slow this bird down!! I still may pickup another AT-6 and put it on the self just in case Top Flite stop making them. If you ever seen the full scale AT-6 do the low high speed pass and pull up in the sweeping right hand turn, this plane do the same thing. With all the short fall this arf have, she is still a keeper. Any other thing you need help on, just post. Have a great weekend my friend!!!
Sonny
aka
jet22b
jet22b is offline
Old 11-02-2012, 07:13 PM
  #608
jet22b
jet22b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: maddieone
Hey Gang,
Curt
Hey Curt,
You still have your Blue Nose P-51???
Sonny
aka
jet22b
jet22b is offline
Old 11-03-2012, 04:37 AM
  #609
maddieone
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sonny,
Never had the Blue Nose P-51, just the AT6, Thunderbolt and the Mustang.
You need to get a T-Bolt, makes the AT6 look like a chump.
Curt
Old 11-03-2012, 06:18 AM
  #610
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Plus 1 on the last post. The TF .60-size P-47 with a DLE 20 is a terrific airplane! I plan on assembling the giant scale P-47 arf this winter due to how well the smaller cousin went together and flew.
Lifer is online now
Old 11-03-2012, 07:06 AM
  #611
jet22b
jet22b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Lifer
Lifer;
I have a new in-box DLE 20 that need a home and you are right, winter is coming and I need to build or I will go nuts!!!
Thanks!!
Curt,
I have my eye on a T-bolt!!! I do like the plane!! That's right xmas will be here soon!!!
Sonny
aka
jet22b
jet22b is offline
Old 11-03-2012, 08:32 AM
  #612
maddieone
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sonny,
Make sure that it is the Hangar 9.
And don't forget the pacers at the rear of the gear boxes.
Curt
Old 11-03-2012, 08:34 AM
  #613
maddieone
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sonny,
I meant to type "spacers" not "pacers"
Curt []
Old 11-03-2012, 08:36 AM
  #614
jet22b
jet22b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: maddieone
Sonny,
Curt
Thanks Curt!! I will look for a build thread here on RCU and start reading!!
Sonny
aka
jet22b
jet22b is offline
Old 11-03-2012, 03:27 PM
  #615
maddieone
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sonny,
Already built one, just send me an Email if you have problems or questions.
curt717@comcast.net
Old 11-03-2012, 04:11 PM
  #616
jet22b
jet22b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: maddieone
Sonny,
curt717@comcast.net
Thanks, Curt. I will do that. I did find a build thread here on RCU!!!
Sonny
aka
jet22b
jet22b is offline
Old 11-06-2012, 08:29 PM
  #617
ChriCYWG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have Toms retract boxes on order...
Has anyone tried to simply swap out the supplied struts for the robart tempered ones that come with the pneumatic kit??
ChriCYWG is offline
Old 11-06-2012, 08:48 PM
  #618
Cougar429
Cougar429's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ChriCYWG, are you referring to the Robart wire gear? If so I tried a pair and although they felt a lot stronger then tended to bend almost as easily as the stock wire.
Cougar429 is offline
Old 11-07-2012, 02:58 AM
  #619
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It has been years since I addressed the issue of soft wire. Is the process for making it harder to heat then quench, or heat then allow it to cool naturally in order to harden the wire? This might be the solution.
Lifer is online now
Old 11-07-2012, 04:30 AM
  #620
ChriCYWG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I read various techniques online about heating the wire, dunking it in oil, then reheating, and dunking in water... I work for an actual airline and I'll ask one of our maintenance guys today about his thoughts on the process...
ChriCYWG is offline
Old 11-07-2012, 04:48 AM
  #621
ChriCYWG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone installed the Centuryjet retracts?
http://centuryjet.com/product_info.php/products_id/194
Those look pretty beefy.. not sure how much wheelwell "carving" would be required though...
ChriCYWG is offline
Old 11-07-2012, 05:13 AM
  #622
Cougar429
Cougar429's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ChriCYWG, we do a lot of heat treat for tooling and fixtures at work and here is my take. Oil quenching makes the part tough, while water quench makes it harder, but also extremely brittle.
Robart supplies instructions regarding heating their wire to form and if I remember correctly the process was to heat to form, then reheat and allow to slowly air cool to return to the original strength and spring qualities. This would make sense as heating and slowly allowing to cool was a traditional method for stress relieving.
Old 11-07-2012, 03:49 PM
  #623
Capt Easy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think the strength comes from the amount of carbon content in the steel but I'm not a machinist nor have background in the subject.
With regard to Robart struts - they say to heat the metal red hot; shape it then quench in water; heat again to the first color change and let cool naturally.
I was told "cold rolled steel" would be stronger than "hot rolled" so that's what I'm going to look for to replace the stock struts. I don't know if that's the same as piano wire or not - if not I'll look for some piano type wire or rod, stock. I'm confident that should work no matter. My plan is to use some short, nose wheel "oleo" struts from "RC WARBIRDS" left over from another project. Then heat the steel rod as suggested by Robart bend it, quench and cut it off to the required length anbd insert it into the oleo struts. The gear should look better and be funtional as well.....at least that's the idea.
I hope someone knows for certain what the correct steel to use please sound of....thanks.
Dick
Old 11-07-2012, 03:56 PM
  #624
TomTreese
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All of this discussion about wire strength is great but the stock struts bending takes a lot of the stress off of the gear boxes and mount area. However, this should not be a problem with the reinforcement boxes
I just wrapped copper wire around the wire in the strut loop which adds some stiffness??? I have 150 landings with no problems that I can't fix with the pliars?
TomTreese is offline
Old 11-07-2012, 06:00 PM
  #625
Capt Easy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm ready to install the wing joiners into the center section but the joiners seem excessivly sloppy to me. I'd like to use brown Gorilla Glue or Tight Bond since they both expand but not sure whether I'd have enough time. I plan on joining one side at a time, letting it cure 24 hours and then fit the remaining wing.
I also have some old 30 min epoxy but the epoxy part has thickened. It was suggesed to put it in the microwave for a few seconds and it would be okay to use.
I'm not near a LHS at all so can't get any new stuff unless throught the internet. All local stores have no 30 min Epoxy.
Thoughts or comments would be appreciated.
Dick
Reply
Display Modes
