4* 120
AZ
RE: 4* 120
I'm in the process of finishing a Flyboy with a Zenoah G26. What are you putting your G26 in? I followed the plans but had to make several modifications. The throttle was the biggest issue. Now my issue is the cowl which turns out to be plastic. I'm afraid the heat from the engine may be to much for the plastic. I can take pictures but I'm not sur how to post them here.
AZ
RE: 4* 120
The only issue you should have is the cowl. On my Fly babay I had to cut quite a bit of the cowl away to make room for the muffler and carb.
If you need the throttle linkage you can get it from B&B Specialties 574-277-0499
Larry
Larry
KS
RE: 4* 120
Thanks for all your replys. I've gone back and forth with the engine selection all I know right now is it will be a gas. Nitro's already over $30 gallon an the bigger nitro's are thirsty.
