New Black Horse Models Gilmore Lion?
Reply
Old 12-13-2009, 01:40 PM
nicoladestro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New Black Horse Models Gilmore Lion?
Hi everybody. I need some more info about the model . Do you thimk it has a solid costruction ? I 'd like to put 5 cylinder 65cc engine , but i need to know if the structure is good enough or if it needs some reinforcements. Do you know something ??
Thanks.
nicoladestro is offline
Old 12-14-2009, 05:29 AM
Kostas1
Kostas1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: nicoladestro
Thanks.
Apparently,
Nicola,
i'd like to know too about this airplane.
It's so nice, but i have searched the web and couldnt find any more info except some random ,not real, pictures.
Looked more like ad pics.
Anyway,
i'd like to see also some pictures of the inside of the fuselage!
Kostas1 is offline
Old 12-14-2009, 02:28 PM
nicoladestro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It seems , it has light landing gear . They broke with heavy landings. That's all i know for the moment.
Bye
Old 01-17-2010, 08:40 AM
Primi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys I got a 65cc radial in it. All fits nicely, there is plenty of room. I have in addition enforced the fire wall with some triangle and carbon fibre inside but not to strong because it is constructed to give if it have. Landing gear wise I can't say much, as I hope it stands up if it has to, it is quite solid with suspension and got some braces to support. It is always the same with ARF's you can't see what is inside the wing or fuse all you can is trust and see what's happen.
I repainted the fire wall with two pack and sealed the covering joints to make it fuel prove and you need this with the ASP 5 cylinder I used, fuel and oil every where.
Today I run the engine in and all looks good for the maiden next weekend.
ID:	1357869   Click image for larger version
Primi is offline
Old 01-17-2010, 10:55 AM
jd391
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like a great fit! I also have the ASP five cylinder and have been wondering about this model. Questions....How did the CG work out. Were the decals applied
All up weight? ARF quality?...........Would like to see more pics with cowel on.
jd391 is offline
Old 01-18-2010, 02:34 AM
  #31
Kostas1
Kostas1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sir you definately have a winner there!
Please keep us posted !
Kostas
Kostas1 is offline
Old 01-19-2010, 04:27 AM
  #32
Primi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jd391
the answers for your questions are:
1. the recommended CG 130mm from the LE is easy to achieve with the radial, because of the short nose it will be hard to get the CG right with a lighter engine. still I have put my batteries far in the back and also the throttle servo behind the CG. at the moment the plane is still a little bit tail heavy but this is easy to adjust with the batteries.
2. the decals were not applied as you can see from previous posted photos, but this is not a problem at all.
3. the total weight without cowl is 6.8kg therefore below the large model classification for Australia, makes it a little bit easier for the maiden flight.
4. The quality of this kit is very good, the design clever and enough glue applied. Still used epoxy to strengthen up, also the covering is nicely applied a few wrinkles but this is normal and quick removed with a iron. Of course there are a few things I would do different, the servo cover from the wing has huge cut-outs for the servo arm, could be smaller. Landing struts mount can be never strong enough, will see how this works.
5. more pic will follow very soon.
Primi is offline
Old 01-19-2010, 06:23 AM
  #33
Wonder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now available in USA!
Hobby People
http://www.hobbypeople.net/gallery/159562.asp
46 on back order
http://www.hobbypeople.net/gallery/159557.asp
John
That web site now shows both models in stock.
Tim
Wonder is offline
Old 01-20-2010, 01:31 AM
  #34
Kostas1
Kostas1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Wonder
Hobby People
46 on back order
John
Tim
Pics pics pics [>:]
Kostas1 is offline
Old 01-21-2010, 09:09 AM
  #35
asnook
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The landing gear is real weak, I have given up with this model !!
asnook is offline
Old 01-21-2010, 11:48 AM
  #36
jcw111
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are right the landing gear design is a joke.  I have posted a number of mods that have help keep everything on the wing from destroying the wing. They do help but had a hard landing in a crosswind and literally destroyed the wheel pants. The cuff and strut covers were fine because of the mods. The last straw was trying to get parts for the last three months. "Sorry we have no parts for the gear"  They have no idea when they will get any. I have since pieced together the wheel covers as best I could but have not flown it since. It has about a dozen flights with decent take offs and landings but all it takes is one hard landing and it is done
Jim W
jcw111 is offline
Old 01-21-2010, 05:47 PM
  #37
Primi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The airplane I talk about is the big brother, we have to acknowledge that the smaller version has some issues with the landing gear, but the bigger one is a lot stronger build, got suspension and struts to support loading.
Would be interested if some body has some experience with the big size of Gilmore and what he has to say about the landing gear.
Primi is offline
Old 01-22-2010, 09:16 PM
  #38
Primi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some more pics from 2nd engine test
ID:	1361877   Click image for larger version
ID:	1361878   Click image for larger version
Primi is offline
Old 01-23-2010, 03:15 AM
  #39
Kostas1
Kostas1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any more pictures ?
Looks awsome !
Kostas1 is offline
Old 01-24-2010, 04:22 AM
  #40
Primi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Today was the day I maiden the Gilmore and it was a pleasure to fly it, he got no bad habits, no trim required at all, CG at 130mm according to the manual and slow landing speed. He rolls nicely and fly's like a 1930 racer. By the way the lading gear was standing up no worries at all.
I can really recommend this plane, unfortunately I had no one to film this event but hope the next time I got some body with a camera on the field.
Primi is offline
Old 01-25-2010, 12:51 AM
  #41
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Primi!!!!
OMG, how awesome is this! Thank you for posting photos, and in particular for building this plane with the FS-400. I am convinced now, this is the plane I MUST have for my radial.
Oh yes please please get some video.
Kmot is offline
Old 01-25-2010, 01:05 AM
  #42
mike109
mike109's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
G'day all. A member of our club here in Dubbo, Australia was test flying the smaller version of this model last weekend. It flew well with an OS AX55. It was a little "tender" in the roll direction and needed a careful set of thumbs at landing time but was surprisingly fast even at half throttle. A little exponential would probably help here.
The big frontal area does mean it slows very quickly once the power is taken off but is generally a nice plane to fly and looks great in the air.
Our field is pretty rough but the landing gear handled it well for several take offs and landings.
Several people are talking about the larger version as they were very impressed with the small one.
mike109 is offline
Old 01-25-2010, 06:22 AM
  #43
Kostas1
Kostas1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh and find some pictures of the smaller one....
Kostas1 is offline
Old 05-26-2010, 04:02 PM
  #44
Americo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!!!.This is my Red Lion.Motorized with a CRRC PRO
GF50I engine.It Is more that sufficient for this plane.Tower pro MG946R servos and futaba ff7 2.4 Ghz.The Gilmore flies very, very well.Regards.
Americo.
ID:	1442962   Click image for larger version
ID:	1442963   Click image for larger version
ID:	1442964   Click image for larger version
Americo is offline
Old 05-27-2010, 10:49 AM
  #45
SteelersRule!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know in the past BH landing gear and wheel pants have come under scrutiny. I would think that the lading gear can be beefed up well enough, (?) but does it make sense to get the wheel pants made out of fiberglass? It seems most manufacturers take the easy way out and use crappy plastic not caring that these will be broken sooner than later and then we go on an Eater egg hunt trying to find replacements. Has anyone had the pants made by someone or knows where you can send the originals to get good ones made?
SteelersRule! is offline
Old 05-27-2010, 11:51 PM
  #46
Primi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi SteelersRule
That's what happen to me I managed to break the pants and could not find any replacement at this time, which forced me into make my own in fibreglass and carbon. This time I got also the colour right background is cream not white.
http://www.rcuniverse.com/forum/m_97...tm.htm#9738897
Primi is offline
Old 10-23-2010, 03:23 AM
  #47
ian51291
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys,what is the diameter of inside the cowl,thinking of putting a CRRC50 twin in it,wondering whether it would fit .
ian51291 is offline
Old 10-24-2010, 05:23 PM
  #48
dan4466
dan4466's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ian51291
It is 12 in or 30.48 centimeters for you. I think the pic tells you it would cover just about any engine.
dan4466 is offline
Old 10-24-2010, 06:26 PM
  #49
Avaiojet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I scratch built the Gilmore years ago. I'm not sure who's plans, I'd have to dig them up. 25%
You can see the framed and covered fuselage with tail feathers in my old shop. It's the one standing on it's nose to the left. The white one.
I can get other photos if there's interest. I'd sell it.
Avaiojet is offline
Old 06-04-2012, 06:09 PM
  #50
wiccaman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anybody tried an evolution 33cc 7 cylinder radial in the small gilmore red lion (121) cause I have both and they fit together perfectly.It certainly looks stunning but will it be way over powered ????
Promise pictures if I persue this combo.....
wiccaman is offline
Reply
Display Modes
