Top Flite Cessna 182 ARF
Reply
Old 12-25-2017, 11:20 AM
  #1376
WarrenDD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I was contemplating the Sierra gear, but at $270 or so (according to their website), that's kinda steep for just a nose gear. Seems like someone would have come up with something (as you said) thicker material-wise that would work as well or better. Perhaps I just need to break out my tools and machine up something from 316 stainless... (please don't get me started fabricating...again...)
WarrenDD is offline
Old 04-18-2018, 03:24 PM
  #1377
jeep36
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just got a new one of these last night and have spent most of the day reading this whole thread. I will incorporate the mods posted in this forum. Thanks to all who have contributed to this forum. except for a few wrinkles in the monokote mine seems perfect. The funny thing is I don't even like Civil aircraft but I could not pass up a good deal for one over on RCGroups site. Putting a magnum .91 in it for power.
jeep36 is offline
Old 08-09-2018, 10:22 AM
  #1378
AustinLonghorn
Originally Posted by MFIGHT43 View Post
Getting there..... Saito FG-21 looks like it will fit using the stock motor mounts... Flaps are sloooooow using Futaba Sbus to program the servo speeds individually. Adding more lights too, like strobes and more incandescent landing lights in the wing and cowl.
MFIGHT43 - so did you have any problems with the FG-21 overheating using that adjustable mount included with the ARF?
The Saito manual encourages the use of their included metal mount as a kind of heatsink (haven't measured it yet, but I think the Saito mount is a tad shorter than the included mount).
AustinLonghorn is offline
Old 08-11-2018, 08:37 PM
  #1379
gixer47
gixer47's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm currently building one also, just received my Saito FG-21 and ordering a turbo header for it. I'll be using the stock mount not the saito one. I may glue a deflector on top of the cowl to push the air down on the carb or something like that seeing that there are heating issues.
gixer47 is offline
Old 08-17-2018, 08:26 AM
  #1380
MFIGHT43
MFIGHT43's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Unfortunately I never did finish the model. Sold the engine off and then the airframe. Not much help to you, sorry.
MFIGHT43 is offline
Old 08-17-2018, 10:27 AM
  #1381
ForcesR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the FG90R3, FG60R3, FG36, FA100, FG20 and two FG21's, if you do not use the Saito engine mounts you will have constant overheating issues with the FG21 or any other Saito engine if the included engine mount is not used.
ForcesR is offline
Old 08-22-2018, 11:07 AM
  #1382
AustinLonghorn
OK, thanks for the replies on the FG-21, folks. I'm leaning toward using the metal Saito mount - just cringing at adding a bunch of extra wood/epoxy on the firewall to get to the correct distance
Has anyone else had trouble with the holes for the wing bolts lining up properly? It seems like the left side on mine is quite a bit off, despite having the wing lined up flush with the fuselage lip at the trailing edge of the wing. I'd post a photo of it, but I don't have enough posts yet to add any attachments.
Old 12-27-2018, 06:28 AM
  #1383
rowdog_14
rowdog_14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking for to reading all the pages and getting all the tricks and tips for this plane. Should be picking up a new one in a few hours. I have a saito 90ts I might put in it.
rowdog_14 is offline
Old 12-27-2018, 07:11 AM
  #1384
elmshoot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have several of the FA100 and haven't used the Saito Motor mounts and never had an issue even coweled. Looking at the list that one appears to be the only normal 4 stroke the remainder are conversions from another glow motor. Gas does make them run hotter and getting the heat off the engine is enhanced by using a metal engine mount.
The Saito .90 will be a very nice combination on this airplane it will fly on the wing. As i have posted in the past. This airplane has a weak Nose gear. If you are low level experience this will be a problem. A intermediate pilot you must lean to land it on the Main landing gear or you will learn to make repairs. There are several tips on how to make it stronger n the pages above.
Sparky
elmshoot is offline
