Reload this Page >
Stripped wing covering during snap roll 4*60
Old 03-24-2009, 01:00 PM
wjcalhoun
Default Stripped wing covering during snap roll 4*60
Hi all:
This is a question, not a complaint about Sig Mfg. I have a 4*60 powered by OS AX 75 turning a 13x7 prop. Great aircraft. Been flying it about 6 months.
The other day, I was doing some snap rolls, medium speed (~55-60mph, 2/3 throttle), and the top surface covering came loose from the wing structure, except at the inboard end at the trailing edge of the L wing. It flailed like a kite tail - lots of drag - but I was able to land the plane successfully without additional damage. I had no loose covering, gapped joints, etc on the preflight inspection.
The repair is straightforward, but I would prefer not to have something like this happen again!
Has anyone else had a similar situation? What are underlying causes that I should be looking for? Does a snap stress the airframe / covering of a 4* too much? Flying too fast?
I would appreciate any suggestions or thoughts.
Old 03-24-2009, 01:41 PM
MinnFlyer
MinnFlyer's Avatar
Default RE: Stripped wing covering during snap roll 4*60
This is why ARF manufacturers tell you to iron down all of the covering - it's often the first step in the manual - and if it's not, do it anyway!
