New Funtana 125
Reply
Old 10-04-2011, 03:23 AM
  #1276
mbritt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New Funtana 125
Well I would suggest looking into a 6s / 7s setup with the Hacker A50-12L or something similiar. on 8s and a power 110 the plane is way to heavy. Prepair to get a light servo for the elevator halves 38g or less prefered. obviosly that depends on the motor you choose and how you place things in the fuse. I would sugest getting your ESC and BEC on the firewall. BEC on side and ESC on bottom for good airflow.
mbritt is offline
Old 10-04-2011, 03:27 AM
  #1277
mbritt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Slow and Steady
I have also found this plane will easiy handle a 15 MPH wind. But on landing it will not stall on a cross wind until almost at a stop. Sometimes I will put in a click of down elevator when landing, which helps force it to settle in. A fellow at our field does every type of 3d with a DLE 20 and it has plenty of pull out, though I don't know what prop he is using.
Strongly recommend reinforcing the gear and upgrading to Carbon Fiber gear.
the CF is 2oz lighter so they may need to see how the craft balances first. I cant go to the CF or Im afraid it wont balance. Im at 9.4 lbs and have trimed everything I can and have the batteries pushed all the way against the firewall. I may get a larger BEC just for the weight and put it on the firewall. I will get some pics out soon. I think 9.4 is about as lite as an electric as I have seen. Anyone else got their plane lighter? If so how?
mbritt is offline
Old 10-04-2011, 03:29 AM
  #1278
mbritt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How does it compare with the stock as far a height and weight?
mbritt is offline
Old 10-04-2011, 03:39 AM
  #1279
mbritt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I went ahead and kept the Hitec 7775 MG (0.10sec/60°&125oz/in on 6v | weight 49g) on the Aileronsand rudder asthese have turned out to be pretty good servos even when running them with a crappy DX7. Cant afford the JR DS9411 and with the weight I can afford to put another 7775 in the tail so I put in a pair of Hitec 5245 MG servos (0.12sec/60°&76 oz/in on 6v | weight 32g) in the tail last night (running everything on 6.5v) and bam. Nice response with no jitter and good centering even with a 2oz weight laying on the surface (I do this to see how they will hold under lode). I have been running a 18x10 xoar but also want to try running a 19x8 as Im doing mostly 3d and thing the 19x8 might give me better air movement across the surfaces in hover and slower manuvers.
mbritt is offline
Old 10-04-2011, 08:16 PM
  #1280
Slow and Steady
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used the Graph Tech gear, which I believe was around $50. Its an excellent fit - made for the Funtana. Handles rough landings and as would be expected, holds its shape.
Slow and Steady is offline
Old 10-05-2011, 07:19 AM
  #1281
mbritt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ya been looking at that, would help shave another few ounces.
mbritt is offline
Old 10-05-2011, 07:39 PM
  #1282
Slow and Steady
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I really don't know if its much of an improvement on weight, but it is very well made and has held up very well. Will likely buy one for my EF Yak.
Old 10-09-2011, 06:07 PM
  #1283
sugarlando
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi, Funtana 125 with os 120 pumped 4 stroke AR 7000 rx and servos is for sale at local hobby shop.  Asking $450.  Do you think this is a good deal, so make an offer?  The plane seems in excellent shape at the shop. Thanks in advance!
sugarlando is offline
Old 10-09-2011, 06:16 PM
  #1284
Scooterpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A new Funtana 125 is $309.00. If it's in good condition and has good servo's that's a fair deal.
Scooterpilot is offline
Old 10-10-2011, 04:25 AM
  #1285
mbritt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got the funtana back in the air this weekend for about 7 flights. since I couldnt get the darn thing to balance very well without adding 2 ounces of lead to the nose I ended up going with a 7s setup (3s & 4s zippy 5000 in series) and a xoar 18x8 on it. Also moved rudder out of the tail and made it a pull-pull. Im getting around 2200 watts using the logging in the ICE 100 to measure.
Components:
~ Hacker A50-12L
~ 10 amp castle BEC @6.5v
~ RX AR7000
~ Rudder & Ailerons 7775MG & 5245MG on elevator (53 degrees throw)
~ Castle ICE 100 (Settings are at Med timing advance (5)(default) and 12khz for the pwm.)
~ Xoar 18x8 (Now I think it would do much better with a 18x10 but I couldnt find one so I will have to order.)
~ 7s setup(3s & 4s zippy 5000 in series 20c)
~ 85 amps at WOT - 2200 watts
~ weight 9.6lb
Now that I have a position where it will fly neutral maybe I can get a 6s setup back in it to cut that 4oz of extra weight. Overall the plane did really descent 3D. I am going to go ahead and grab the carbon fiber LG. I would also like to find a source for some good nylon bolts for the LG and SFGs etc. So if anyone knows where to get 3 & 4 mm nylon bolts I would love to know. (socket head prefered but not really holding my breath).
mbritt is offline
Old 10-25-2011, 09:52 PM
  #1286
darylm44
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lost my Funtana Sunday. Don't know whether I will get another one or something else.
darylm44 is offline
Old 10-26-2011, 04:04 AM
  #1287
mbritt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW, what did you hit a bus! Thats kinda bad. Well I will say the funtana is a chore to get setup right but once you do it does fly really well. I finally did get mine flying real nice where I want it and its right at the 9.5x Lb mark with the SFG's which are 2oz.. Nuetral CG for me was just forward of the 6.5 cg mark. 6 3/8 is nose heavy so you just have to get it close and play with the batteries to get the nuetral. If you arent going to get another Funtana, If I can make a recomendation. The Extreme Flight 60" Edge is also a great plane. Probably my favorite of all the planes in my hanger. However I have so much time invested in getting the funtana figured out I would have to probably replace mine as its just now getting really fun to do low rollers and hovering etc. (not that I would ever buy another hanger 9 aircraft, im just saying I have this one where I want it so I would just replace it.)
Funtana Components:
~ Hacker A50-12L
~ RX AR7000
~ Rudder & Ailerons 7775MG & 5245MG on elevator (As much throw as possible)
~ Castle ICE 100 (I did play with the settings after updating to the new firmware version. New firmware seemed to help with the output power)
~ Xoar 20x10 (Seems to fly well on 6s with both the 19x10 and 20x10.)
~ 6s setup(2 -3s zippy 20c 5000mah in series)
~ weight 9.6lb
~Graphtech
Landing gear.http://www.graphtechrcshop.com/product.sc?productId=43&categoryId=6
Gives better ground clearance on the larger props (over 18) andhandles the harder landings better in my opinion. same weight within a few grams of the aluminum. 160 grams I believe.
mbritt is offline
Old 10-28-2011, 05:16 PM
  #1288
darylm44
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No Bus, just mud. I was on my final when another flyer called out dead stick. I hesitated trying to decide whether to go ahead and land or go around. Lost air speed and stalled. When I noticed it start to stagger I gave it power but it was pointed down by the time the engine took hold.
darylm44 is offline
Old 10-28-2011, 05:33 PM
  #1289
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How many of the parts of a 125 Funtana willfitor work on a 100X Funtana? I would like to keep my 100x Funtana going as long as possible !!! Thanks
Capt,n
captinjohn is offline
Old 10-30-2011, 04:35 PM
  #1290
gade600sdi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anybody have any DLE 20 install pictures. I am trying to figure out the bolt hole pattern using H9 Alum. Motor Mounts, the choke setup, and also the throttle servo positioning. I would like to use the stock tank also.
Cutting hole in firewall for carb? Mounting of servo throttle arm and choke?
gade600sdi is offline
Old 10-31-2011, 05:57 AM
  #1291
w1nd6urfa
w1nd6urfa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: gade600sdi
Motor mount: used plastic, DLE thread suggests against H9 alum
Choke: pushrod to front just rear of propeller, mounted to plastic motor mount
Throttle servo: stock position in fuse, used nyrod with ball links
Tank: 8oz from a .50 ci ARF - will fly 15 mins hrd 3D and still be 1/2 full !
Photos:
ID:	1680932   Click image for larger version
ID:	1680933   Click image for larger version
w1nd6urfa is offline
Old 11-02-2011, 09:28 AM
  #1292
gade600sdi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the pics W1nd....
A little more info if you don't mind.
1. If you put the throttle servo in its stock position, looks like you crossed the pushrod over to the other side inside the fuse?
2. What is the reason for no Alum mount use plastic instead?
3. I was thinking the same on the choke, bend around the engine or a possible bellcrank
4. Only thing I didnt like on yours was the hard looks like almost 90 degree bend on the fuel line, isnt that problematic for you? THere definately isnt much clearance to the firewall to work with fuel line.
Old 11-02-2011, 10:40 AM
  #1293
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Funtana owners...I need a right side wing for a 100X Please help me find one. Thanks Capt,n
Old 11-02-2011, 11:36 AM
  #1294
w1nd6urfa
w1nd6urfa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, no problem there if using flexible nyrod
Plastic mount absorbs modt of DLE20 vibration, alum transfers it to airframe
You can mount the engine 1 cm further forward, and also move the cowl further forward. It looked dubious to me too, but never had any problem - been flying it for past 9 months
Old 11-03-2011, 05:25 AM
  #1295
gade600sdi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, thanks for the input. Did you use any lead on the nose?
Old 11-03-2011, 08:13 PM
  #1296
darylm44
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: captinjohn
Funtana owners...I need a right side wing for a 100X Please help me find one. Thanks Capt,n[img][/img]
All I have left is the left wing.
darylm44 is offline
Old 11-03-2011, 09:40 PM
  #1297
w1nd6urfa
w1nd6urfa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's the last thing I would ever do, especially on a 3D machine. I would rather sell it !
With the lighter carbon gear and 8oz tank full CG is aft of recommended range, flies somewhat nose-high at low speeds which takes some getting used to but its not supposed to fly in straight lines is it?
Old 11-04-2011, 10:11 PM
  #1298
kochj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a pair..(left and right wing)
Mind you, they had some CA added to keep some strength, and one side has some damage. covering is off on that wing... to fix it...
I believe the covering could be heated up and restuck w/o issues... The damage is minor... but it is getting hangar rash in the garage...
I can PM you the wings with detailed picts....
I was about to throw them away...Too much clutter in my garage...
kochj is offline
Old 11-05-2011, 07:19 AM
  #1299
krop
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I do have one RIGHT WING for the Funtana 100 X.
Checked it over and looks good. I acquired it from someone else and it appears to have not
been in any accidents.
Can send photos by private E-mail.
krop
krop is offline
Old 11-06-2011, 12:00 PM
  #1300
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: kochj
I sent you a PM. Thanks Capt,n
Reply
Display Modes
