New Funtana 125
#1351
RE: New Funtana 125
By the way, I went to their site and they have two listed, but both appear identical. I would order the 1203, which is the newest. I believe that is the one I used.
#1352
NC
RE: New Funtana 125
I have an EVO 26GT fitted to Funtana 125; using Pitts-style muffler. Would like to use tuned pipe/silencer system for this engine; make it a bit quieter. Has anyone used this silencer with this engine on Funatana? If so, were you able to get a header that would drop down from the exhaust port so tuned pipe could be mounted under the fuse, or did you simply mount the tuned pipe on the side of the fuse?
Any help would be appreciated.
Happy Flying!
Ken
#1353
MN
RE: New Funtana 125
ORIGINAL: chepenik
Happy Flying!
Ken
I had a Funtana 100X that I used a Evo26gt with eveo 26gt pipe......
I mounted the engine on a downward angle so the pipe would come out at the bottom of the plane...
Let us know how it turned out..
#1354
RE: New Funtana 125
I use the DLE 20 with a Xoar 17-6 and I beat the plane like a government mule. The 20 hauls ***** and one guy watches me fly and he is sorry he already bought the 30 for his. Well over 100 flights hard tumbles and gyroscopic hooligan type moves and its solid as day 1, the plane is as tough as a waffle house steak.
#1355
RE: New Funtana 125
ORIGINAL: gade600sdi
#1356
RE: New Funtana 125
I don't fly my Funtana much anymore; my main plane for the last year and a half has been a 50cc Extreme Flight Yak and just recently started flying their 50cc Extra. Great planes! But if i take up the Funtana again (it is sitting in my garage) I may change to the DLE 20. Based on the Hangar 9 video and manual, it seams like this plane was designed for a 20 gasser.
#1357
RE: New Funtana 125
I have been running the SYSSA 20cc gas engine on my Funtana 125 for a year + now. Great combination. however, I think a 20cc would fly it great. Mine is overpowered, but I love it.
#1359
My Feedback: (21)
RE: New Funtana 125
ORIGINAL: Slow and Steady
#1360
RE: New Funtana 125
ORIGINAL: Luchnia
I have a Funtana with a Saito 1.25 and I don't fly it much either as I have some more favorite planes that I prefer to fly. It was collecting dust so I finally decided to sell the airframe to a fellow that has a DLE 20cc from a crashed plane which I believe would be a perfect combo.
#1361
My Feedback: (21)
RE: New Funtana 125
Luchnia, your saying you have more favorite planes than this? Wow I have 15 planes and this Funtana I keep going back to. Not my biggest, but my funnest to fly. I would love to hear what you like better than the F125.
ORIGINAL: Luchnia
#1364
RE: New Funtana 125
Hi all, was just at my LHS and they have a funtana 125 there for a really good price. Then i started reading about it and came across this thread, i see they have problems with there covering yellowing! Anyone know if this has got resolved? As well as a weight & balanceissues..... was planning on putting in a dle 20 i have. So the hs7775mg are the servos you guys are running with the dle20? As well with running those servos are you moving your rudder to a pull pull style? Thanks for your in put
#1365
RE: New Funtana 125
Unless somthing I'm not aware of has changed, they don't consider the yellowing a problem....
I would buy another if it were not for that issue. Refuse to support that mentality.
Mine was a DLE 30, but it was so overpowered I would put a 20 in the next one. The loss of power easily offset by the loss of 8 ounces difference in weight one engine vs. the other.
Weight was an issue? I always felt these were right in there?
Balance is on you with a plane like this. There's a wide range it (and others like it) will fly well in. Start at suggested, then start moving it back to suit your skill level/flying style?
I'm not touching servo questions, but will say I would highly recommend metal gears. This plane easily capable of speeds where flutter is a major issue. Metal will resist/help protect against resulting damage best possible. note: I watched one of these blow it's wings right off due to flutter one day. Turned the fuse into a big lawn dart. Spectacular!
Pull pull vs. tail mounted rudder servo would depend on balance requirements. No other 'druthers on my planes.
#1366
RE: New Funtana 125
Thanks for your inputs. To bad they have not done anything about the yellowing. I heading to my lhs tomorrow, see if they still have it
there. Was on sale for $225. Kind of hard to pass up, as i do need a home for my dle20, that I just took out of my reactor bipe. It was just to much
for that plane. Was starting to tear in apart.
I read that the funtana has had some problems with flutter as well. Thanks for the advise, I will go with metal gear servos not sure what
ones yet. They should have at least 100oz torque right?
What did you use for hinges? Thinking I should get some robart hinges. As i read some of the ailerons have ripped off at the hinge.
#1368
RE: New Funtana 125
ORIGINAL: livefast_livefun
#1369
RE: New Funtana 125
Glad to hear it only yellows when left in the sun. I dont leave my planes out unless i'm flying them.
Never fly at a club, just at the paved runway at work where we fly our airtractors out of. So the plane will
be in the hanger the rest of the time.
As far as the Spektrum telemetry, what do you use this for? voltage? I'm still on the newer side
of the gas. And like i said never been to a club. Sure would be nice to see what other ppl are using. Just
dont have alot of time to.
Looking at the hitec HS-7954SH for the rudder, maybe all controls if the balancing lets me. Or
is that to much of a servo for this? I may have to move the rudder to a pull pull.
#1370
RE: New Funtana 125
I am using Futaba 3305 servos all around. 4.8 volt NiCad battery pack for receiver, 4.8 vold NiMah for the ignition. The telemetry that I have is: cylinder head temp, rpm, receiver battery voltage, battery pack voltage, air speed, Gforce X,Y,Z indicator, GPS tracker. Check out the HH web site for telemetry items. All of the telemetry info comes back to the Transmitter and to my iphone with the STI module plugged in. I can then email the info to myself and track with Google Earth as well as some software that displays all flight infor from a flight session.
#1371
RE: New Funtana 125
hello guys.
I got myself a Funtana, after reading this thread. a successful model, but with some problems. as equipment: equipment that I will use the extra electron was namely:
- GF26I V2 26cc engine
- 4 Power ATLAS DIGITAL MG-BB 20 UMD HYPERION (ailerons and elevators)
- 1 Power HD servo (rudder)
- 1 DS8411 servo (throttle)
- Ubec HiModel 8A for servo and ignition Ubec for 3A
- 2S 2200mA receiver pack / ignition 2S 1600mA
after 4-5 flights I have not managed to finalize the center of gravity. model is difficult to handle. Because of this, the landing, the smallest gust of wind it up.
Another problem is the tail wheel system that after each landing must be directed. I ordered another skid from Dubro. The film has not yellowed yet, but because screen printing is extremely difficult to spread. practically holding back a screen printing ink.
if you can advise me how to solve the problem LP's, I would be grateful
#1372
MD
RE: New Funtana 125
Hi Allen,
Have about 30 flights on my funtana. Rally enjoy it. My CG was about in the middle of the suggested range, any like you experience, as it slows for landing, she will pitch up. Made me almost wet myself a couple times. Moved the battery foward in mine to adjust the CG forward and it lands great now. I use about 30 degrees of flap mix on light wind days and clean with with 10 mph of wind or more. Less aerobatic with forward CG, but much more manageable on landing. This is a beautiful flying AC so move the CG aft slowly. Also, wiped the gear off mine landing in the grass a bit fast. Used some CF rods to strenthen the gear for aft loads. No problems since. I guess it was not ment to land on grass, so be aware and good luck
Mark
Mark
#1373
RE: New Funtana 125
Hello Mark.
thanks for the information. Meanwhile I flew Funtana and I'm starting to learn with this model. Indeed, I think it was designed for straight tracks, not grass. to our grass runway airfield was rebuilt special sports and now everything is OK.
I have one piece of advice, namely, front on the flight, check and reinforced landing gear panel. It stuck superficial and the landings older one force, jumped altogether.
https://www.facebook.com/media/set/?...0941689&type=1
#1374
RE: New Funtana 125
If all of you that are flying the Funtana AC (S90,100x,125) want to have some real fun, try flying with the Eagle Tree 2d/3d flight stabilizer installed. I ordered one and installed it in my second Funtana 125 which is running a Saito 1.25 4s. Spektrum DX8 trans with a AR7000 receiver. Have 2d/3d mode setup with the flap switch. What a hoot to fly. I take off with the stabilizer turned off, but have the 2d mode on for landing. Makes landings a piece of cake. 3D mode will let you knife edge and torque roll with a lot eaiser controll.
#1375
RE: New Funtana 125
I removed the yellowing with painters tape about a year and a half ago. My method is low tech but it works and requires about a half role of tape. Apply about a 10" peice of tape to the white/yellow area (do not apply to colored areas) of the plane and then peal it off. The yellow will come off with the tape. It took about an hour to make the plane look new again. While I have since sold the plane, I see it regularly and it continues to look new.
By the way, I had a 30cc gas engine on it and it was too much torque and power. If I were to do it again, I would go with a DLE 20. A fellow at our field flies with this set up and he can do most any 3d menuever with it. Kind of makes sense, being that it was designed for a 20 gasser.
