If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 18 of 18 FirstFirst ... 8161718
Results 426 to 437 of 437
  1. #426
    tailskid's Avatar
    Join Date
    Nov 2001
    Tolleson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: *Hangar 9 New Pulse 125*
    Got mine 95% completed...just put on the canopy and purchase and install a 6V flight battery...
    I figure with both batteries against the firewall, it should balance without any additional weight....but we will see.
    We are here on earth to do good unto others. What the others are here for, I have no idea.
    ~ WH Auden
  2. #427
    Join Date
    Jun 2007
    Freedom, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Keep in mind that H9 C/G as shown in there manuals is a bit conservitive, I wouldent worry too much about getting it dead on, half inch is close enough, of course, don't go too far aft! And NO up trim at all on maiden!
  3. #428
    tailskid's Avatar
    Join Date
    Nov 2001
    Tolleson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I will keep that in mind! Thanks for the advice.....
    ~ WH Auden
  4. #429
    VictoryRoll's Avatar
    Join Date
    May 2008
    Norfolk, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was thinking about buying the Pulse 60 for my new Saito FA100 GK.   So, in looking at threads for the 60, which also has the tripping problem due to LG, you may want to look at this video and see if this is a option for all of you Pulse 125'rs....
    [youtube]http://www.youtube.com/watch?v=-6-LSJxlsCQ[/youtube]
    Any thoughts on a Pulse 60 w/ Saito FA100 vs. Escapade .61-.91 or Revolver 70" or any other suggestions, I have a post on ARF forum, and I would appreciate any and all recommendations/suggestions...    http://www.rcuniverse.com/forum/m_11326726/tm.htm
    Thanks !
    Don
    Club Saito Member #691
    H9 Pulse XT Brotherhood #4
  5. #430
    tailskid's Avatar
    Join Date
    Nov 2001
    Tolleson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well over 2 dozen flights on mine so far....GREAT flying bird!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    ~ WH Auden
  6. #431
    Join Date
    Feb 2010
    Canberra, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've got a Saito FG-14, 4 stroke gas (equivalent to about an 82 size Saito nitro)in my Pulse 60. Plenty of power for this style of plane. I've had 100s of flights on the stock plane and landing gear and can't recall ever having a tip, or even coming close to one, so this talk of tipping always mystifies me. Maybe I fly mine a little tail heavy or something.
  7. #432
    grosbeak's Avatar
    Join Date
    Dec 2010
    Ottawa, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: fishingships
    I was thinking about buying the Pulse 60 for my new Saito FA100 GK. * So, in looking at threads for the 60, which also has the tripping problem due to LG, you may want to look at this video and see if this is a option for all of you Pulse 125'rs....
    Any thoughts on a Pulse 60 w/ Saito FA100 vs. Escapade .61-.91 or Revolver 70'' or any other suggestions, I have a post on ARF forum, and I would appreciate any and all recommendations/suggestions... * *http://www.rcuniverse.com/forum/m_11326726/tm.htm
    Thanks !
    Don
    I saw the video and tried the mod - the angle of the 125's gear is much greater than the 60's and it didn't look right at all.
    I tried it with the stock gear on a riser block.
    Photo credit: Simon Nadler 2012
    It was WAY too tippy. Full up elevator would work if the plane was pointed upwind and moving, but getting it moving often made it tip
    I went with TNT landing gear...
    Photo credit: TimeCapsules Photography 2012
    But I like the look of the stock gear much better - so over the winter I'll move it forward an inch or two as others have done.
    MAAC 83386
    Stetson Flyers, Ottawa
    G-RSBK
  8. #433
    Join Date
    Nov 2011
    kamloops , BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    video of my pulse xt 125 with a saito 125 and a APC 16 x 4w prop and the landing gear has been moved forward and a 5mm spacer under it
    battery is up against the engine fire wall with only 1/2 oz of weight to balance, it has unlimited vertical and is a dream to fly I LOVE THIS PLANE
    Ben
    https://www.youtube.com/watch?v=i-G-INnLQSI&feature=g-crec-u
  9. #434
    Join Date
    Jan 2011
    SorrentoBritish Columbia, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I moved my landing gear forward ..I used the original bolt holes from the front gear holes and put the back gear bolts in moving the gear ahead about an inch..then I put backing in and drilled new holes and put new blind nuts in for the front gear bolts...I hope this makes sense..It is much easier than it sounds and works great...I did not like the way it looked with the gear turned around ..I ordered a gear from TNT and while I was waiting I wanted to Fly so I came up with this..It works so well when I got my TNT gear I have never switched over...I like how this looks...It completly solved the tripping problem and it is very easy..There is one former that you need to work around...Thats it...
    Ken , Biker BC Cub Brother #6 Ultra Sport Brother # 100 Tiger Club # 7 Pulse Brother # 1 Sig Brother # 58 Top Flight Brother # 9
  10. #435
    Join Date
    Jan 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have personaly seen bsovermars Pulse fly off a grass field and it performed very well Great plane and pilot...
  11. #436
    grosbeak's Avatar
    Join Date
    Dec 2010
    Ottawa, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've been discouraged with the Pulse because I had a hard time landing without bouncing all over the place. This winter I will move the stock gear forward. In addition I'll be replacing the stock ring in my DLE-20 with a Bowman ring, and I'll polish the reed block. All of this should breathe new life into her!
    MAAC 83386
    G-RSBK
  12. #437
    tailskid's Avatar
    Join Date
    Nov 2001
    Tolleson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wow, a new ring? I'm pushing over 8500 RPM/s on mine right now and it takes the Pulse 125 up, up and away without any problems. As far as bouncing goes (I fly off hard dirt), I land two wheels with a bit of power. If I try a three point landing, it will bounce - and the gear is in the stock location.
    ~ WH Auden
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
