Seagull PC-9 Prop? (O.S .46 AX)
G'Day all i'm driving about 4 hours soon to my LHS to pick up seagull PC-9, i will be putting an O.S .46 A in it and wondered what prop i should try?
I was thinking along the lines of a 10 X 6 MA or maybe 11 X 5 APC. I'm not after top speed, just reasonably torque and acceleration for a rough grass strip, i also plan on doing a hell of a lot of knife edge flying. I have found APC props to be superior on my seagull boomerang but damn they are ugly and would prefer to use NA screw if possible.
Any suggestions?
Stix
Any suggestions?
Stix
AB, CANADA
RE: Seagull PC-9 Prop? (O.S .46 AX)
I was running the 11x5 apc on mine with the 46 and was quite satisified...not too fast and could pull some good vertical and large outside loops
flynte
flynte
I have found great results with a 10x7 for speed, and 11x6 for aerobatics.
Props are cheap.......
I like apc, but actually prefer the lighter evolution props from horizon for the smaller nitro stuff. they are woth a try
good luck
871
good luck
871
