Larger Revolver
#3801
RE: Larger Revolver
Just built my first Revolver 70, placed a OS 120 FS surpass on her. Now the fun part , the CG. I have to just about sit on her tail to get it to 5 1/2 "
has anyone else built one with an os120fs and how did you get the CG right. i am considuring moving the elevator servo's to the rear. I have already moved the battery to behind the servo tray. Thanks in advance
#3802
My Feedback: (47)
NY
RE: Larger Revolver
vnvringo - I am planning on swapping out a YS 140 currently in my Rev 70 for an OS 120 4s (the YS is WAY overpowered and I can utilize it better elsewhere). Will let you know how my 120 4s install goes. I'm thinking of using an APC 16x7 prop (for starters - will see if that hits the sweet spot or not). Do you know what prop you're going to use?
#3803
RE: Larger Revolver
You had a 140 on this thing? I'll never really understand the whole overpowering thing I guess. Santa is coming early this year. I ordered a new plane to replace the EF Extra 300 I totaled at the beginning of the season. A Pilot RC Sbach 342 25% (30cc) should be at my house in a few days. I"m a sucker for blue & white planes like the Revolver but I just couldn't do it on the Sbach. They have a orange\purple scheme that looks like the visibility will be better than the blue\white scheme. I love the looks of the R70 on the ground and in the sky on a sunny day. But wow, when it is cloudy it gets hard to see real fast. I have a little 41" Edge 540 from 3DHS that is pretty much all orange. I could almost fly that thing at night it is so bright!
Speaking of bright, who all has tried night flying with micro LED's on their plane?
#3804
RE: Larger Revolver
I am going to start with 14x11 than try 15x10 and i do have 1 16x6 as well I used the pumped version 120 III it is heavy at 35oz thought th CG was ok but after adding thorttle servo it feel off the chart. Dont get it but I must have screwed up when I checked the cg the first time.
#3805
FL
RE: Larger Revolver
vnvringo,,,,,
Ido not have the engine you installed on your revolver but when I unstalled the OS 95AX 2S on mine it was very nose heavy and I also had to move the battery to behind the servo tray. But she was still nose heavy. So I added some led right behind the battery which is already behind the servo tray. It is a little trick getting in there but with some patience and some long tip plyers I mananged to CA it in there with a plywood tray to hold the led in place with glue. I first turned the revolver around and balanced her while placing the led on her belly while she was backwards. When I got the right CG, then i turned her right side up and inserted the tray and led eight about where I placed the led on the outside. As I said, its a little trick getting in there but I think its bertter then having to move your servos back. Godd luck !!
#3806
My Feedback: (47)
NY
RE: Larger Revolver
DonE - yeah, I tend to overpower my planes, or, at least, compared to the recommended power. Love having that extra power when I want it, though the YS 140 WAS a bit MUCH.
I think the DLE 20 is the perfect engine for the Rev 70, and I've read that's got more power than an OS 120 4s.
Funny, I've never had to add weight to the Rev 70, even with the big honkin engines I've bolted on. Though, if needed, I have mounted the battery back, behind the servo, on a little platform I build back there.
#3807
My Feedback: (48)
MI
RE: Larger Revolver
#3808
RE: Larger Revolver
ORIGINAL: tande
I have the 36% version of this same plane (orange/purple/white)....Keep us posted! ...
#3809
RE: Larger Revolver
vnvringo
I had an OS AX 1.20, and my R70, version 1, was quite nose heavy. I think there is every reason to move the elevator servo(s) back - you are using dual servos, right? - for shorter links and tighter control.
Interestingly (at least for me), my R70, version 2 with DLE20 was slightly tail heavy. I have the GC now at 5.75", and it is just about perfect for me. I might move it aft 1/8" or so, but she flat spins beautifully, both upright and inverted with the CG just aft of book.
#3810
My Feedback: (48)
MI
RE: Larger Revolver
ORIGINAL: DonLEmmel
What are your thoughts on the build quality of this plane? The Pilot RC arfs seem to offer alot that the more expensive Extreme Flight kits didn't. The carbon spinner, carbon landing gear, cowl ring, and aluminum hub wheels were all huge selling points. I had the EF Extra 300 78'' ARF and it was almost $100 more delivered. Do you have any pics or videos of your Sbach?
ORIGINAL: tande
Ed
#3811
RE: Larger Revolver
Wow, that really is a gorgeous plane! The pics on ChiefAircraft's website weren't very good. The angle of your picture is exactly what I wanted to see.
#3812
SC
RE: Larger Revolver
I just finished a 30cc version of the Goldwing RC Yak 54. Got the kit/engine combo at Troy Built. Have not had a chance to maiden her yet. The kit was one of the finest I have ever built as far as quality goes.
#3815
RE: Larger Revolver
He said it was the 36% version of the plane I ordered which means that baby has a 107" wingspan. The DLE sticker on the plane leads me to believe he is using a DLE-111???
#3816
My Feedback: (48)
MI
RE: Larger Revolver
ORIGINAL: DonLEmmel
He said it was the 36% version of the plane I ordered which means that baby has a 107'' wingspan. The DLE sticker on the plane leads me to believe he is using a DLE-111???
Tande - beautiful plane! What's the wingspan, and what engine are you using?
(btw - no offense, buy you don't look ANYTHING like I imagined...
#3817
RE: Larger Revolver
Spent the morning out at the field today - the weather was great. It may be the last good warn day till spring. The Revolver 70 flew perfectly and I got many comments on how well it flies. One of the guys just bought one based on eyeing mine all summer. A second one is considering it. It has a Magnum 91 FS which is plenty of power. So far that engine has performed as well as the more expensive ones. I love the plane.
Bruce
Bruce
#3819
My Feedback: (47)
NY
RE: Larger Revolver
I finally got the part needed to rebuild my YS 140, and so got that back together last night and reinstalled in the Rev 70. Went flying this morning. Coulnd't understand why the engine was dying on throttle up, until I discovered that I had reveresed the throttle fuel feed and engine pulse lines! As Rick Perry would say, "ooops." SO got that straightened and the engine ran great, with some tweaking. The plane flies fantastically - started to do some hovering today, but just for a few secs. Will try that again soon and put more effort into it. The only problem I have with this engine now is that it leaves LOTS of fuel residue on the plane. I tried leaning it but the engine didn't like that. Am thinking of putting this YS 140 into my Super Stearman and that planes' OS 120 4s into the Revolver. But I'm not crazy about the fuel residue. Anyone else here running a YS 140 or 120? Do they NEED to run very rich, creating lots of fuel spillover?
Also am about to start rebuilding (from scratch) my other Rev 70, and reinstall the DLE 20. (the old Rev died due to a crash after a very untimely engine stall).
#3820
RE: Larger Revolver
Hi Mike
In your hovers, is your R70 stable; mine has plenty of pull, but unless nearly vertical, she has significant wing rock. My 1/4 scale extra 260 has much less wing rock.
Bill
Bill
#3821
My Feedback: (47)
NY
RE: Larger Revolver
wjcalhoun - haven't done it enough to tell. I'll work on the hover next time and have something to report. The Rev70 isn't a 3D plane, so I'm not surprised that your 260 is more stable. The only hovering I've really done is with the Yak 54 3D on Real Flight, which I'm actually pretty good at. All to play for whether that will translate into real-world ability.
How long can you hold the hover? What engine and prop are you using? I'm using an APC 16x8 with the YS 140.
#3822
RE: Larger Revolver
ORIGINAL: iflywhenican
#3823
RE: Larger Revolver
@tande - How is the Sbach for 3D? I'm not really doing 3D yet but I'd like to. A flat spin is about the most complex thing I can do at the moment. The inverted flat spin eludes me for some reason but the KE spin is darn close. I don't know if high alpha knife edges count as 3D but I can do them as well....with rolls back into KE. I'm learning that a properly set up plane is 75% of being able to do a maneuver. That being said my Revolver needs some CG tweaks. My MXS had a fair amount of mixes I didn't need because my CG was off a bit. Well, alot actually. The knife edge mixes I have in my Revolver will probably go away, or at least be reduced, if I fix my CG problems.
#3824
My Feedback: (48)
MI
RE: Larger Revolver
ORIGINAL: DonLEmmel
Later
Ed
