Larger Revolver
#3951
My Feedback: (47)
NY
RE: Larger Revolver
Update after flying - the newly-mounted OS 120 Surpass 4s ran very well this morning - and the Rev 70 flew great, though hard to tell, exactly, as it was windier than the 10mph projected on weather.com. Had one issue - when I pulled the throttle down to idle quickly for landing it stalled a couple of times - looks like I need to tweek the low end. Other than that it ran perfectly.
Agree with wjcalhoun - the DLE 20 is probably the best engine for this plane - light, lots of power and speed, and cheap fuel. And, mounted inverted, no visible holes in the cowl. Also very easy to start. (and no fuel clean-up...).
I'm about to rebuild my 2nd Rev 70 from NIB - I'll remount my DLE 20 in that plane.
#3952
RE: Larger Revolver
ORIGINAL: microdon2
MetallicaJunkie - the 120AX 2s should be an awesome engine for this bird. I'm about to head out to the field now to fly my Rev 70 with an OS 120 Surpass 4s for the first time - swapped out the engine from another plane. I was running a YS 140 - just a tad overpowered, and never did use WOT, so I''m trying the OS.
btw - when you say, ''flying wires'' - do you mean to support the rudder \ elevator? If so, they're not needed on this plane.
#3953
RE: Larger Revolver
ORIGINAL: wjcalhoun
Metallica
I had the OS AX 1.20 in my first R70. It was a great combo. Quite nose heavy, even with dual aft elevator servos. I had to move the batteries aft of the rudder servo, which I set up as a pull pull system. I finally got the CG to the forward edge of the recommended location.
My new R70 has a DLE 20. By comparison, the DLE20 is stronger, better vertical. It was easier to hit the CG correctly. My current airframe has the CG about 1/2'' aft of the first one. Flat spins are MUCH better with the DLE20 combo, probably due to the more aft placed CG. The 1.20AX provides plenty of pull. It sounds like the mods you plan are the common, and experientially necessary upgrades for reliability. The LG plate is weakly mounted, the wing servo boxes can come loose, and hinges are suspect, particularly when the airframe is pushed, as yours will be.
Happy flying.
Metallica
Happy flying.
#3954
My Feedback: (47)
NY
RE: Larger Revolver
MettallicaJunkie - I've seen that happen on a Youtube vid, but that plane was a Rev 59 and doing over 150mph - was an electric plane. Very cool vids, btw. Once that tail went it was all over in about .2 seconds. Airraptor also does some amazing work souping-up his Rev 59 plane and uses Nitro engines - I think he's got an OS 120AX in a Rev 59. Not sure how fast he does, but it must be around 130mph. And close to the ground. Pretty impressive to watch. I think this link is correct: www.youtube.com/watch?v=_TRgyqgiPtQ
Neither of these pilots used wires, so I'd think you wouldn't need it, either. On the other hand, nothing wrong with experimentation, and I'd love to see pics and hear about your installation. Personally I don't like wires, as they tend to get in the way (though I realize on some builds they're required).
#3955
RE: Larger Revolver
ORIGINAL: microdon2
the tubing i bought was K&S Streamlined/Airfoiled http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXR853 ... ill prolly put em on to be safe, i know ill be tempted to go WOT on a spit S, or a dive plus ill need tail weight... any usable weight weight is better than lead i prolly post some pics..... i ordered it sunday evening and its "still being packed", ill get it after Christmas, and hopefully fly it before next year!
#3957
RE: Larger Revolver
ORIGINAL: microdon2
So you'll use that solid tubing instead of wire? How do you attach the tubing to the rudder and elevators?
i crimp the ends and use 2-56 screws and nuts.... i got the idea from a flying buddy.... i have an Ultra Sport ARF "clone" that had an old 70s era 51 that flew it around ok.... i slapped a Rossi 45 and it fluttered like crazy on a high speed pass... lukily it happened right in front of me....if i wouldnt have chopped the throttle i wouldve lost it.... the elev stab cracked in a couple of places
#3958
RE: Larger Revolver
Hi Flyboy0608,
I'm deciding between an OS 95AX and a 75AX. Did you have issues balancing the plane with the larger engine on your Revolver? Also, do you think the it's worth it to upgrade to this engine? Thanks.
JC
JC
#3960
RE: Larger Revolver
Thank you Microdon2. Is this what you have in your Revolver? Also, I was just checking out the FS-95 4stroke. What do you think about this engine on the Revol 70?
#3962
RE: Larger Revolver
Mine has a 75 AX and will do unlimited knife edge. 95 AX will allow for a bigger prop and better breaking on the down line, or more pitch and speed. Just my 2 cents.
#3964
My Feedback: (47)
NY
RE: Larger Revolver
Prelude - I have two Rev 70's - one with an OS 120 Surpass 4s and the other with a DLE 20cc gasser. Both excellent engines, though the DLE 20 has more kick. I used to have a YS 140 in one, but that was just a TAD going overboard. I tend towards the overpowering end of the spectrum. But with a 95 AX and the right prop this plane will move nicely. (I can't recommend a prop, though, as I don't have that engine).
#3966
RE: Larger Revolver
i'm flying this bird with a os 91 fx 2 stroke using an apc 14x8 prop burning 15% wildcat fuel. this setup will slow way down for landing while having been clock by radar three times at 109 mph. the 95 ax is probably going to better that by a nose. merry chistmas everyone, capt p.s. my plane wieghs 9.0 lbs, my question is - what do the gas burning planes wiegh.
#3967
RE: Larger Revolver
ORIGINAL: prelude92
Bruce, how do you think that would compare to an OS 95AX 2 stroke. All these engine are in the same price range.
jc
jc
Bruce
#3969
RE: Larger Revolver
Yes, similar to that except that you can not see the muffler. I used a 80 degree adapter and routed the muffler down and out the bottom so that from the side you only see the exhaust tip of the muffler coming out the bottom. The combination works very well and I am quite happy with it.
Bruce
Bruce
#3970
SC
RE: Larger Revolver
Yeah, I started to do the same as you, but I opted for the side exhaust, hoping I would get less "slime" on the fuse. Turned out, that it probably didn't matter.
#3971
RE: Larger Revolver
My exhaust is only sticking out about a 1/2 inch and is in the middle of the air flow exiting the cowl for cooling. As such I get all most zero slim on the plane. I lucked out in placement because of the the air flow around the Revolver cowl and its mixing with exit air keeps the slim away from the plane.
Bruce
Bruce
#3972
NY
RE: Larger Revolver
plug one of the tubes on the pitts muffler your not getting enough pressure in the tank with both tubes on that pitts muffler being open
ORIGINAL: Kaos 61
Hi Guys,
Sorry to bust in but I need a little of your expert advice on stall out. I have a OS .61FX 2 stroke in my large Revolver. When I tilt the plane nose down in excess of 30 degrees the engine leans out and quits. At full throttle it takes about 5 seconds and it takes up to 15 seconds at lowest throttle. It doesn't matter how I set the mixtures. The engine runs fine in all other attitudes. I've taken careful note of the clunk action in the tank and it isn't folding the pickup tubing and thus starving the engine. I notice though, that the stock tank height dimension isn't awfully big compared to the tanks' length. I suspect the clunk pickup is becoming uncovered. Thing is, this happens even when the tank is full! I'm hooked to a Pitts muffler for pressure. Anyone else experience this or can suggest a cure? I haven't flown this bird yet because of this and I'm just itch'n but I've lost planes in the past over stall-outs at the wrong moment....
Hi Guys,
#3973
RE: Larger Revolver
Warbird addict,
I've heard of this problem with the OS 55AX. One suggested solution was to insert some sort of metal tubing in both exhuasts. Can you explain how to plug one of the exhausts, as you mention, as well as the other solution?
#3974
RE: Larger Revolver
capt
My R70/DLE20, dual aft elevator servos, pull-pull rudder, 2100mAh LiFe battery weighs 9#11oz all up, dry.
On a Xoar 16x8 she makes at least 14# static thrust, and is not yet broken in. Plenty of T:W ratio for me.
Bill
Bill
