If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 232 of 323 FirstFirst ... 132182222230231232233234242282 ... LastLast
Results 5,776 to 5,800 of 8054
  1. #5776
    Join Date
    Dec 2006
    STEWARTSTOWN, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    It's closer to 40oz if you compute it using the 22.5 lbs weight someone projected since GP is a bit conservative in their weight estimates. You would almost certainly hit that weight or higher if you need to add a canister muffler. By way of comparison the Extreme Flight Yak (88") has a wing loading of about 29oz and it is a highly capable 3D plane. The Revolver 90 will probably still float pretty well at that weight. It will still be more of a sport flyer like the R70.
  2. #5777
    Join Date
    Dec 2008
    League City, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    We are also dealing with scaling issues - wing loading is not constant across scale, but rather increases; a 40 size plane will have lighter wing loading than an otherwise identical 120 size plane. The metric that normalizes for scale is the cubic wing loading; i have a calculator, but have not yet plugged in the numbers. Having said that, by inspection, the R90 will have higher cubic wing loading than the 89" 3DHS or Eflight birds.
    And, i think most of us who may buy this plane will want at least a 60cc, and perhaps a 75cc up front, which will further increase the wing loading and cubic wing loading.
    But, as ahicks said, the R70 flies beautifully with 'robust' wing loading for her size, so it will be hard to predict the flight characteristics of the R90. Has anyone yet clicked 'buy'?
  3. #5778
    Join Date
    Dec 2008
    League City, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    OK Guys, here are the numbers
    R59 || R70 || R90
    Wt 7# || 9.5# || 21#
    Area 563 || 832 || 1303
    WS 59" || 70" || 90"
    WL 28 || 26.3 || 37.1 oz/sf
    CWL 14.5 || 10.9 || 12.3 oz/cubic ft
    Stall speed 26.5 || 25.4 || 30 mph
    [sorry about the poor table formating]
    Wing loading WL is high, but again this is a relatively big bird.
    Cubic wing loading CWL suggests flying feel between the R59 and R70. R90 is a bigger plane, higher stall speed, but not dramatically so.
    Obviously the numbers will be a bit different depending on how they build. My R70 is 9#11oz dry, so is a bit heavier than this table. I picked the heavy end of the wt range from the tower data. I think the CWL demonstrates why the R70 seems to be a little better behaved airframe than the R59.
    I dont think she will fly like a warbird at all. I may be wrong.
  4. #5779
    lopflyers's Avatar
    Join Date
    Jun 2010
    Orlando, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    Awesome comparison. See the stall speed od the R59 is higher than the R70.
    Thats why is more difficult to land
    Hopefully the R90 isn't going to fly like a warbird. I try to stay away from those.
    Keep your wings level
    A nose heavy airplane flies bad, a tail heavy flies once.
  5. #5780
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    wjc - I've put my hat in the R90 ring (it's in my shopping cart). Not saying I can afford to pull that trigger right now...
    btw - you made me Google "Cubic Wing Loading" and I found this thread here on RCU. It ain't so straight-forward - lots of discussion about the meaning and merit (ex - whether it is only a valid measure for planes of the same size and type). But certainly interesting.
    http://www.rcuniverse.com/forum/m_11...tm.htm#1176152
    And here's a wing cube load calculator: http://www.flyrc.com/tools/calculator.html
    The R90 produces a CWL of 11.8 (using 1,300 sq in and 320 oz (20 lbs).
  6. #5781
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    I just plugged in the Rev70 into the Wing Cube Loading calculator - ends up with an 11.5. Very close to the Rev 90.
    btw - has anyone else noticed that this thread POPS right up now?? Maybe RCU did a database cleanup \ disk defrag??
  7. #5782
    markhamregular's Avatar
    Join Date
    Nov 2010
    Pembroke Pines, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    Does anyone has a O.S.120AX 2 strokes in this plane? I just received my kit and I am considering either the 95AX or the 120AX. I am more inclined to install a 120 but I am wondering about modification. Will I need to modify anything in order to install the OS120AX? If yes, how about the 95AX?
    Harry
    What\'\'s rudder?
  8. #5783
    Join Date
    Dec 2008
    League City, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    1.20AX is a great engine for this plane. My first R70 has that combo and it was spirited. No substantive mods needed.
  9. #5784
    Join Date
    Jul 2012
    , MT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    +1 on the 1.20ax
    I currently fly my Revolver with the 1.20ax, I used the muffler extension and it fits perfectly.
  10. #5785
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    1.20 AX guys - what prop are you using? Just saw that it puts out 3hp at 9,000 rpm - that's more hp than the DLE 20 (which is PLENTY for the Rev 70!). On my Rev 70 \ OS 120 4s I just moved from an APC 16x8 to an APC 15x10 and I like the added quickness.
    With the 1.20 AX can you get 9,000 RPM on a 15" prop?
  11. #5786
    Join Date
    Jul 2012
    , MT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    I started with a 16x6 now Im using a 15x8 and like it better.  I think you could go with the 15x10 or even a 15x12.  On the OS page they list the recommeded props as15x10-12 and 16x8-10.  I'd be interested in seeing how the 15x12 preforms, looks like its time to go visit the LHS......
  12. #5787
    Join Date
    Dec 2008
    League City, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    My view is that the RPM power band for the glow engines is quite a bit higher rpm than for the gasser. My AX 1.20 flew best on a 16x6, and seemed over loaded at 16x7 or 16x8, whereas the DLE20 turns the 17x6 and 16x8 pretty well.
    I have come to like high pitch props on the R70; might think of a 14x10, rather than 15x10, to allow the engine to rev a bit.
  13. #5788
    chandley43231's Avatar
    Join Date
    Apr 2010
    columbus , OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    15x10 gits it with authority i put on my 95ax an had lower my prop size  is could get the rpm  1.20 ax was built for this beast have a pits sulivent muffler an popped to hole in the top of the cowl to connect  an remove the muffler and it will balance perfect withthe battery just under the wing tuben i also put a screw on the top of the cowl  at the fire wall due to the vibration of the engine quiets the beast down  good luck
    CORSAIR BROTHERHOOD #85
  14. #5789
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
  15. #5790
    Join Date
    Apr 2010
    columbus , OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    microdon hope u dont have a problem an have only have good intentin withthe ***** comment
    how old are you 5??
  16. #5791
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    Chandley - sorry, was being a wisenheimer. Comment deleted.
  17. #5792
    Join Date
    May 2009
    Fort Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    Someone admitted they were wrong and apologized. I tip my hat to Microdon!!
  18. #5793
    Luchnia's Avatar
    Join Date
    May 2009
    Amelia, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    ORIGINAL: Slow and Steady
    + a million! I will be one of many to admit the spelling and grammar bugs the you know what out of me sometimes!
  19. #5794
    Join Date
    Dec 2011
    shreveport, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    Flew my revolver again today. Very fun. THE Garmin GPS was onboard and it clocked max speed at 120 mph. I don't believe I should go to 14 x 12 prop. I was using the 15 x 10 prop today. It was coming in fast for landing and I damaged landing gear plate. It is now fixed. I was flying plane at a cotton field and tried to land plane on 8 foot wide runway for the cropduster
    AMA # 982277
    Carden Extra 300 Pro, almost done building it (DA 200 with KS cans)
    Carden Extra 300 Pro, in the works (DA 150 with KS 1090 tuned pipes)
    Dalton Extra 300 SP, finished and crashed, RIP
    Dalton Extra 300 ML, DA 200
    Dalton Yak 54, DA 200
    Great Planes Matt Chapman Eagle Cap DA 120
    Top Flite Gold Edition Giant P51 DA 85 (in the making!!)
    Extreme Flight YAK 54 91" DA 70
    Extreme Flight Extra 300 91" DA 85
    Extreme FLight Extra 300 78" DA35
    JETI is the only way!!!!
  20. #5795
    Join Date
    Aug 2008
    Waterford, Mi/Citrus Springs, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    Geez, 8'? Seems like a crop duster is several times the size of a Revolver. If he can make it ok ......
  21. #5796
    Join Date
    Sep 2002
    Stillwater, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    Noticed the R90 on Advantage Hobby for $417 and free shipping.
    Neil
  22. #5797
    Join Date
    Dec 2006
    STEWARTSTOWN, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    It's only $380 on TowerHobbies if you are a super saver club member. I think shipping would only be $10-15.
  23. #5798
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    Orthobird - 120mph with an APC 15x10?? Sounds awesome - what engine? I flew this morning with my Rev 70 \ OS 120 \ APC 15x10. I'm liking the 15x10. Might have to test a 14x12.
    My newest move - nothing earth-shattering, but still fun - is a low, slow-as-possible inverted pass. 3-4 feet off the deck, on a high idle. This plane is SO stable, even inverted, at low speeds. Specially with a 7mph headwind.
  24. #5799
    Join Date
    Dec 2011
    shreveport, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    hi. i found it there for 430, and i am in that super saver club. where did you find it for 380?
    ORIGINAL: Sbach342Guy
    AMA # 982277
  25. #5800
    Join Date
    Dec 2011
    shreveport, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Larger Revolver
    saito 125 4 stroke 15% nitro
    if you can do that, you are a great pilot. ive tried that before, but outcome was not good.
    ORIGINAL: microdon2
    AMA # 982277
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
