Reload this Page >
Larger Revolver
Larger Revolver
Old 05-17-2014, 12:41 PM
  #7326
el_xero
yup the I've used the 120 AX, very nice!
Old 05-18-2014, 09:34 PM
  #7327
Chris Nicastro
Chris Nicastro's Avatar
Anyone use an OS 160 on this plane?
Ive flown my buddies with a DLE 20 and Im interested in more speed but less weight.
Old 05-18-2014, 11:03 PM
  #7328
Sloviper
Ok guys does anyone have any pictures on where to install the throttle servo? The specified location doesnt line up with the cut outs or am i doing something wrong?
Old 05-19-2014, 01:15 AM
  #7329
Dreamtime
Hi Sloviper. What engine are you using? For the DLE 20 see my post #7290 -- one of the photos shows what I did and this works perfectly with an unobstructed straight run.
Old 05-19-2014, 03:39 AM
  #7330
Sloviper
Dreamtime im using a saito 125.
Old 05-19-2014, 03:53 AM
  #7331
ahicks
This is about as simple an install as you can get. Apologies to the person originally posting the pic. I didn't note your name! -Al
Name:	DLE 20 install1.jpg
Old 05-19-2014, 11:41 AM
  #7332
Sloviper
Thanks Ahicks but i rotated the carb and didnt wanna bother rotating it back so i just drilled a hole in a firewall. Was able to mount a servo as per manual.
Old 05-19-2014, 08:41 PM
  #7333
Sloviper
I just noticed the right wing doesnt line up with the fuselage completely. Is it only me again or is this a common thing
Old 05-20-2014, 01:40 AM
  #7334
Dreamtime
Common thing -- no problem
Old 05-20-2014, 02:56 AM
  #7335
superduke1
Hi Sloviper, I also had issues with the RH wing having a gap at the leading and trailing edge. I have noticed that its hard to carry out a good knife edge with the revolver as it requires a lot of opposite aileron has anyone else experienced this or is it just my technique.
Old 05-20-2014, 03:10 AM
  #7336
ahicks
I love messing around on knife edge. Revolver doesn't "lock in" once rolled onto it's side, but I've never flown anything that really did? I will say that if the CG isn't trimmed for a neutral/flat elevator, it's going to pull towards the canopy or the gear, but that's pretty normal in my experience as well?
Old 05-20-2014, 08:01 AM
  #7337
Sloviper
Ive been reading about a lot about the lg issues and how to beef it up. Actually its the only thing left to do on mine besides the tail gear which i ordered from tower. I will mount a sullivan tail gear. Do the latest revolvers still have lg issues or have they finally fixed this?
Old 05-20-2014, 12:08 PM
  #7338
ahicks
Not fixed.Fixing the issue would admit that there IS an issue, and they haven't even gotten to that point yet...
Old 05-20-2014, 12:38 PM
  #7339
Sloviper
That's ridiculous its been five years since it came out i would have thought they would do something about it.
Old 05-20-2014, 09:03 PM
  #7340
Dreamtime
Hi Superduke. I was flying yesterday with an IMAC pilot who commented that I was using a fair bit of opposite aileron in knife edge. I ran out of fuel, but will set up a mix next time. He commented that the Revolver should be easy to set up for pretty much hands off KE with rudder as master. Once that is set it looks like I will need a bit of up elevator mixed in as well.
Old 05-20-2014, 09:06 PM
  #7341
Dreamtime
Hi Superduke. I was flying yesterday with an IMAC pilot who commented that I was using a fair bit of opposite aileron in knife edge. I ran out of fuel, but will set up a mix next time. He commented that the Revolver should be easy to set up for pretty much hands off KE with rudder as master. Once that is set it looks like I will need a bit of up elevator mixed in as well. I say it again every time -- this is a fantastic plane, and loving the DLE, just leaves a grin every time I take it out and never does it not get comments from someone.
Old 05-21-2014, 06:06 AM
  #7342
Stone17
How do you guys balances this plane?
I maked the wing at
5 1/2" and it needs alot of nose weight (added picture of the wing mark) . I move both my battery up front and it works out.
Alot of you guys have a battery in the tail. What is that for?
Here a couple of picture of my plane. I have a DLE-20.
ID:	1997171   Click image for larger version
ID:	1997172   Click image for larger version
Old 05-21-2014, 06:39 AM
  #7343
ahicks
Are you looking for the CG for your test flight? You can safely fly in back of the suggested CG once you get a couple of flights under your belt. How far back will depend on your skill level, and what you're expecting from the plane?
Old 05-21-2014, 06:58 AM
  #7344
Stone17
Yes, I would like the plane to be on the correct CG 5" 1/2. I really don't care to fly a tail heavy plane.
I have not flown the plane yet. CG is the only thing I have left to get the plane ready.
Old 05-21-2014, 09:32 AM
  #7345
Stone17
I was wanting to know why people have battery in the tail of the plane.
Old 05-21-2014, 10:01 AM
  #7346
ahicks
You do what you need to do to balance. Don't think too much about what others are doing in that respect. Makes no difference regarding YOUR plane? That said, with your elevator servos mounted mid ship like yours are, surprised your batteries need to be so far forward. Others building DLE 20 powered ships have chosen to move the elev. servos to the back, for CG purposes, as well as to keep the push rods as short as possible. Allows room to install pull-pull rudder as well. -Al
Old 05-21-2014, 11:08 AM
  #7347
mach2
mach2's Avatar
Starting at the recommended cg is good, but as most of us have found it to be nose heavy like this. I like cg at about 6.25". It is not tail heavy at 6.25". And it does fly nice and slow like that. It makes landings much better. At the recommended cg, it comes in real fast on landings.
With the DLE 20, and all the servos in the standard locations, I placed the life battery behind the elevator/rudder servo tray...
Old 05-21-2014, 11:13 AM
  #7348
mach2
mach2's Avatar
Just a note, looking at the throttle servo picture that Al posted, I noticed a metal rod being used. I know other guys have used them with no problems, but metal rods are not recommended this close to the ignition. I personally use Sullivan golden rods (nylon rods). They work great, are easy to set up, and won't act as an antenna that would send out noise from the ignition.
Just my thoughts on that set up...
Old 05-21-2014, 12:33 PM
  #7349
ahicks
That's regarding one of "those" old rules we needed to follow, prior to 2.4mhz? And then, the concern would be more valid if the engine end were going through a metal arm. With the pictured setup, with no metal to metal contact that might allow rattling, there's really nothing to set up RF. That's my understanding anyway. FWIW
Old 05-21-2014, 12:39 PM
  #7350
Stone17
I did the same thing. I cant find a picture with it done.
