Reload this Page >
has anyone flown the new 50cc size black horse corsair
Old 05-30-2014, 08:16 PM
  #551
dmyers0403
My Feedback: (48)
I tried the ziroli canopy and it is a bit to large, so I agree that the Hanger 9 or TF may be a close fit.
Old 07-12-2014, 04:20 PM
  #552
pattnut
I recently replaced my BH Corsair canopy with a Hanger 9 canopy; it is a perfect fit, and it's more scale!
Old 07-12-2014, 09:08 PM
  #553
dmyers0403
My Feedback: (48)
Great news
Old 09-04-2014, 04:33 AM
  #554
tim750r
A bit late in the day, but we finally managed to get 2 decent flights and landings out of this 'bird'!
Here's the first, unfortunately we didn't trust trying to get the wheels up until after this flight...
http://www.youtube.com/watch?v=-TNNa_X6RLo
Old 09-04-2014, 04:59 AM
  #555
aghost
My Feedback: (13)
aghost's Avatar
Nice flight, nice landing. Looks it slows down well. Thanks for the video.
Old 09-04-2014, 06:11 AM
  #556
soco32
Nice! I flew mine about 3 weeks ago - ASP 400 Radial and Lado retracts. All went well but I was concerned about the amount of flying time on the fuel tank. I had a 16 oz tank, but since I did not use the Air Retracts I have since piggy-backed a second 10 oz tank. What size tank did you use -- looked like you were up about 6 minutes.
Old 10-08-2014, 04:40 PM
  #557
Heli-NuBee
Here are a few pictures of my UMS Evo 7-77 radial engine powered BH Corsair in action at our annual War Bird event this last Saturday. It is not as pretty anymore after the major damage done last year but at least it is back in the air.
Best wishes and good safe flying.
Heli-NuBee (AKA Roger the redial rabbit)
Old 10-14-2014, 10:56 AM
  #558
vasek
vasek's Avatar
I would like to know who has success with the supplied retracts ? I'm debating if I should leave them in as any alternative will be very costly. I will change the valve and tubing to Robart tho. Thanks
Old 10-14-2014, 11:35 AM
  #559
wphilb
My Feedback: (10)
If you are flying off a paved or other hard surfaced runway you might give it a go. If you are on a grass runway I would seriously consider replacing.
You will love this plane, it's one of the best flying Corsairs I ever owned, really bummed they are no longer in production, another one would be on order!
Whit
Old 10-29-2014, 02:33 PM
  #560
vasek
vasek's Avatar
Has anybody fitted the H9 drop tanks to their plane ? Is there enough ground clearance with the original/supplied struts installed ? Thanks
Old 01-24-2015, 02:48 AM
  #561
mazdaspeed6
Originally Posted by pattnut
Finally "finished" my BH Corsair project, and got four flights on it. Flies GREAT. DLE 55 is PLENTY of power. I modified the airplane with: Robart retractable tailwheel, Dynam Bal Zirolli full cockpit kit w/"Pappy" Boyington figure, Top Flite Corsair dummy motor, LADO electric retracts (witch have performed flawlessly). The markings represent a Marine Corsair out of Okinawa, spring, 1945.
Hi which robart retract you fitted in the tail? and you had to add a lot of weight in front for it cause of CG? Thanks looking forword to buy one!
Old 01-24-2015, 06:01 AM
  #562
wphilb
My Feedback: (10)
Im sorry sorry but it's no longer in production.
Let us know if you find any source of new old stock!
Whit
Old 09-09-2015, 03:48 AM
  #563
Jim Cattanach
Jim Cattanach's Avatar
Back in 2011, I purchased this model. It was a great flyer, but the landing gear was rubbish. I eventually sold it on, but always wanted another one. Unfortunately production stopped.
I recently noticed production had restarted with a re-designed version 2.
I ordered one & it arrived last week. Very good build quality. Many changes to the design. Wings are plug in with two alum tubes. no separate belly pan, it is part of the fuz now. A nice cockpit & pilot is supplied.
The main difference is the landing gear. it looks much more robust. No plastic parts.
I am looking forward to the build. I am installing a Saito FG84R3 radial with Keleo exhaust. This will just fit inside the cowl.
Price was 649 Euros & delivery from Hobbyfly Germany to Cyprus was 71 Euros.
They & many others have them in stock.
Old 09-09-2015, 04:53 AM
  #564
dmyers0403
My Feedback: (48)
Would like to see new photos and assemble shots. I also have the older version which is a great flyer. Currently in rebuild due to engine out which caused some damage to wings and retracts from rough landing in field.
Old 09-09-2015, 07:30 AM
  #565
Jim Cattanach
I will take a few photos & post them.
All surfaces except rudder are factory hinged. The supplied fuel tank is around one liter. I threw away the factory tank bung & tube assembly & made up my own with brass tubing.
The rudder is hinged to the tail using a one piece alum rod. The rudder push pull cables are attached to the tail wheel & the rudder is attached to the tail wheel wire with two allen screws.
The tail plane is plug in like the wings & can be removed.by slackening two screws..
The gear doors are operated by a servo on each wing & the door bay will accept four inch wheels. I used ESM alum wheels as they look better than the supplied ones.
As I said, photos to follow.
Old 09-09-2015, 09:22 PM
  #566
Jim Cattanach
Just started the build. here are some photos of my version 2 Corsair. Excuse the dust on everything. We have had a dust storm from the Sahara desert over the past couple of days.
ID:	2119144   Click image for larger version
ID:	2119145   Click image for larger version
ID:	2119146   Click image for larger version
ID:	2119147   Click image for larger version
Old 09-09-2015, 09:27 PM
  #567
Jim Cattanach
Some more.
ID:	2119149   Click image for larger version
ID:	2119150   Click image for larger version
ID:	2119151   Click image for larger version
ID:	2119152   Click image for larger version
Old 09-10-2015, 04:40 AM
  #568
dmyers0403
My Feedback: (48)
Lot of very nice improvements over older model. Stab looks to be removable, is it??? I have not seen a supplier in the USA yet.
Old 09-10-2015, 05:19 AM
  #569
Jim Cattanach
Stab is removable. Just one screw to loosen.
Lots of dealers in Europe stock it. You may get a good deal on shipping from Hobbbyfly. I only paid 71 Euros to Cyprus.
http://www.hobbyfly.de/rc-flugzeuge/...bsmodelle.html
Old 09-14-2015, 06:09 PM
  #570
dmyers0403
My Feedback: (48)
Any assemble updates?? Photos??
Old 09-15-2015, 03:31 AM
  #571
Jim Cattanach
I have installed the rudder with pull pull wire & elevators with servos.
I spent a whole day trial fitting the Saito FG84 radial. There is only about 3mm between the rocker covers & the cowl, so has to be exact. This was further complicated by allowing for right hand & down thrust.
I cannot fit the engine, until the exhaust arrives from Keleo in the USA. It is on its way & should be here later this week according to the tracking info.
Also waiting on other bits from the UK.
I will post some more photos when I fit the engine.
Old 09-21-2015, 09:25 PM
  #572
Jim Cattanach
Some more photos. The head on photo of the engine is not quite head on & makes the engine look to one side, but it is perfect.
I had to remove the engine mounting box & make up a new mounting arrangement, in order to fit the Keleo exhaust ring,
The model balances perfectly, without any additional lead.
I used 2 x 2. 2amp Rx Lipos & 1 X 3.3 amp ignition Lipo. A Powerbox ignition spark switch will be fitted later today.
As the gear doors are servo operated, I fitted a Jet Tronic door sequencer & a double action electronic valve for the gear operation.
ID:	2121713   Click image for larger version
ID:	2121714   Click image for larger version
ID:	2121715   Click image for larger version
Old 09-21-2015, 09:33 PM
  #573
Jim Cattanach
Some more.
ID:	2121718   Click image for larger version
ID:	2121719   Click image for larger version
Old 09-22-2015, 04:38 AM
  #574
dmyers0403
My Feedback: (48)
Looking very good. Glad they brought this one back to market especially with the changes. Expect it to fly as before but keep us posted on maiden and how the retracts hold up. Are those the stock wheels with spokes?
Old 09-22-2015, 06:58 AM
  #575
Jim Cattanach
The stock wheels were ok, but I had a spare set of ESM alloy wheels & tyres which look much better.
