Top Flite's Giant Scale P-40 Warhawk ARF
#51
RE: Top Flite's Giant Scale P-40 Warhawk ARF
I have a Zenoah G-62 - no electronic ignition.
Would this engine fit the cowl of the Top flite Giant P-40 warhawk?
Is it going to be overpowered?
#52
I have a Zenoah G62 - magneto type. Does it fit in the cowl of a P-40 Giant scale?
What about power, is it going to be overpowered?
#56
Wilbur, when installing the G-62 is the original air intake of the P-40 the only existing air intake? Did you need to make any hole or adaptation to the cowl? Is the engine fully concealed in the cowl?
I believe the pictures will show it.
#61
FL
It's a bit of a handful to land but looks great in the air.
http://www.youtube.com/watch?v=j7_vZkrTsjU
#64
My Feedback: (13)
Got a few flights on my P40 after Christmas. On the Last flight 3 prop bolts broke on my DLE 55. I was able to land with no damage.We should add TIGHTEN PROP BOLTS every 15-20flights as part of maintenance. I saw this happen on an F4U ( with DLE55) and all 4 bolts broke.It was ugly!
#67
WV
Hi
Has anybody put a lighting kit in this bird and are the retracts from robart a straight drop in or do they require some modification ?
Also how does the quality of TF ARF's compare to the aeroworks warbird planes ? I realize that aeroworks planes are high to begin with just not sure about the construction aspect between the two or the flying characteristics...
thanks
scott
thanks
scott
#68
My Feedback: (13)
Hi
thanks
scott
thanks
scott
#69
I've got 2 of the TF Giant Scale P-40's. Both have DLE 55's, J-Tech mufflers, and Robart gear for the mains and the tailwheel. The plane is designed for this equipment and all are a drop-in fit. The cowl has plenty of room for a bigger engine if you desire.
I fly off a grass field that is a little bit rough so I used some Fourmost product shims to angle the gear 3 degrees more forward and have had no noseover issues.
Build the plane as laid out in the manual, balance at the rear of the recommended range, and do all the flying on the low-rates detailed in the manual. With this, you will have a nice flying plane. A 22x10 2-blade or a Xoar 20x10 3-blade are the props I recommend. DO NOT try to land this plane like a trainer. If you habitually land your planes at a full stall and drop like a primary trainer you will make Tower rich buying replacement parts. This plane needs speed to land. My belief is that you should study all the videos on Youtube you can find and watch how this plane handles. It's not hard to fly but is definitely not for beginners. If you need an entry-level giant scale fighter, try Top Flite's P-47.
The Top Flite offerings are for flyers. They are not museum scale planes.
#71
My Feedback: (13)
#75
IL
