If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 29 of 36 FirstFirst ... 192728293031 ... LastLast
Results 701 to 725 of 880
  1. #701
    Tseres's Avatar
    Join Date
    Oct 2008
    elwood, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RedWing MX2 Build
    Q8. I picked up on two things between what you said and what I see in the pictures.I don't see any Zip tie on your fuel line. You need to Zip tie everywhere that the fuel line ends. Weather its at the tank or inside the tank o the carb.
    You said that you replaced the exhaust gasket. You need to throw the exhaust gasket away and use some high temp Silicone gasket material. The Exhaust gasket starts to leak shortly after you start running it. That is where I think your mess is coming from. Chances are that the muffler would fall off completely with the factory gasket.
    Old Tom
  2. #702
    Join Date
    Mar 2010
    bayan, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    teseres all fuel lines were zip tied, i took everything off to check on the lines and the tank itself so i will re zip tie them again tomorrow before i go flying. regarding the exhust gasket yeh i was shocked when i opened the exhust and so that it went from elastic to plastic form. i used silicon and re tight it up.
    thank you teseres will update you guys tomorrow. its bed time here in kuwait wishing u all a pleasent day back in usa and ceecrb in spain
    adios
  3. #703
    Join Date
    Oct 2006
    winston, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'd fly with out the cowl, I've seen it a hundred times with the cowl curing the problem, BUT I'm still wondering how good you are drawing fuel and if your not a touch lean
  4. #704
    Join Date
    Mar 2010
    bayan, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    moning guys.
    this is from a guy in FG forums Name aussiesteve<script type="text/javascript"> vbmenu_register("postmenu_1401398", true);
    "As the others have mentioned, Check the tank lines, especially check that the clunk line is not hitting the back of the tank. IF all that is good, Get a D10 WAT carb kit and change the pump diaphragm (the one under the cover with a single screw on it) to the blue one that comes in that kit. then set the needels to 1 3/4 turns open and try tuning the engine again. About 80% of the JC 28's I received to sell needed the pump diaphragms in the carb changed out"
  5. #705
    T3beatz's Avatar
    Join Date
    Oct 2007
    St. Louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    He is right, about the tank line... if it's to close to the back of the tank you will starve the engine of fuel and it will die.  You have to get some video of the engine running if you can so we can hear the transition to full throttle.
    hopefully your day will be good and you can get the engine operating the way it should.
    Build em Fly em Crash em!!!
    www.Redwingrc.com
  6. #706
    Tseres's Avatar
    Join Date
    Oct 2008
    elwood, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Aussiesteve knows a lot about engines and was the importer of JC engines in Australia. If you still can't get it running with what we said then do what Steve told you about the diaphragm. I have heard of faulty diaphragms even when they were new.
    Old Tom
  7. #707
    AirTech's Avatar
    Join Date
    Jan 2004
    Peru, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just my penny in the cup. It seems with all that sand down there there may be a possibility of FOD ingestion into the carb. When the engine fuel/air mix problem is solved some kind of carb air filter and a fuel line filter may help in preventing another more serious problem.
  8. #708
    Join Date
    Mar 2010
    bayan, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    it rarely rains in the deserts. now when i want to test my plane its raining daaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaamn my luck
  9. #709
    ceecrb1's Avatar
    Join Date
    May 2008
    Valencia, SPAIN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Blue skys and zero wind here
    Goldwing MX2 & DLE 30 + Harris smoke pump
    Seagull Super Tucano 91 & DLE 20
    Trex 500
  10. #710
    ceecrb1's Avatar
    Join Date
    May 2008
    Valencia, SPAIN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    quick question.
    I have been using a 2200mah 3s lipo to power this plane (rx and ignition).
    Iยดm wanting to split it to 2 batteries for the RFI issues when connecting ignition power to RX...
    Would you all think a 2450mah 2s lipo (rx) 1300mah 2s lipo (ignition), would be enough for a decent days flying with reserve?
    Trex 500
  11. #711
    T3beatz's Avatar
    Join Date
    Oct 2007
    St. Louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: ceecrb1
    quick question.
    I´m wanting to split it to 2 batteries for the RFI issues when connecting ignition power to RX...
    With that setup you should be able to get 5-6 flights before recharging, depending on how hard you fly.
    www.Redwingrc.com
  12. #712
    AirTech's Avatar
    Join Date
    Jan 2004
    Peru, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: ceecrb1
    quick question.
    Are you running a voltage regulator for the receiver and a separate ignition regulator for the ignition. I am not so clear on your installation, since a 3S LiPo produces 11.1 Vdc you need a regulator supplying 6 Vdc to the RX. And is not such a good idea to use the same power supply both the ignition and the Rx unless you use an isolated (optically) regulator i.e. a UBEC or an IBEF. In any case if you go to a 2S LiPo they will produce 7.4 Vdc and you still need a voltage regulator. Be aware that RFI can be produced by a faulty spark plug, a defective hi-voltage wire or its connection and a loose ground wire.
  13. #713
    ceecrb1's Avatar
    Join Date
    May 2008
    Valencia, SPAIN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: AirTech
    Yes I know all about needing regulators etc..
    I have an 8A regulator on the RX and a 3A on the ignition.. but all fed by the same 3s 2200mah lipo.
    I know. Not great. Thats what I had at the time I bought the plane.. now I have more cash again I want to fix it up better.
    Trex 500
  14. #714
    ceecrb1's Avatar
    Join Date
    May 2008
    Valencia, SPAIN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: T3beatz
    ORIGINAL: ceecrb1
    quick question.
    Ok which would you "beef up" to gain more flight time? what would others recomend.
    Trex 500
  15. #715
    ceecrb1's Avatar
    Join Date
    May 2008
    Valencia, SPAIN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    also can the power HD ds090mยดs and futaba fasst take direct supply from 2s A123's/LIFE (6.6v) without a regulator?
    Trex 500
  16. #716
    Join Date
    Mar 2010
    bayan, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    my servos are all power HDs ds090 and HD 9150 powerd by 2 1100 MAH A123 NOregulator so my answer is yes
  17. #717
    Join Date
    Mar 2010
    bayan, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My update:
    Went to the field today fired the plane up without the cowl took off and flown it for 15 min no problem at all. But i didnt have the time to fly it with the cowl on so i will try that tomorrow.
    things been done to it so far:
    loop on the vent line like teseres picture
    all fuel line been changed
    sparkplug been changed to the same model but a new one
    all engine bolts been re tightened except the two ones T.J told me not 2
    Tomorrow will fly with the Cowl on and update you guys
    Thank you
    Fahad
  18. #718
    ceecrb1's Avatar
    Join Date
    May 2008
    Valencia, SPAIN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Q8, sounding like things are going good!
    In the end today I ordered 2x 2s 2100mah A123's (1 plus a spare). and a 2s2p 2100mah lipo for ignition. well over juiced.. but i'd rather pay for weight with the low low low chances of powerloss mid-flight.
    Just going to put some capacitors into the system to add redundancy incase of a "noisy" on off switch...
    These are the capacitors used to prevent brownouts.. they will also remove blackouts caused by a switch which is going bad due to engine vibrations... so will get me some next time iยดm in the electronics shop for work.
    Trex 500
  19. #719
    Join Date
    Mar 2010
    bayan, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yup ceecrb thing going well need to check how is it going to be with cowl on tomorrow hope it will work out.
    ceecrb regarding you subject why don't you get 2 1100 mah with wolverien switch or a batshare and IBEF system? most of the experienced guys i asked regarding airplane setup told me that 2 battries RX setup will give much better chance to survive a bad battery than just one. also i really likes the IBEF( thanks Airtech for recommanding it) it will save you the weight of a new battery + an engine cut off and last extra battery to charge. the choise is urs but am just saying
    Good luck ceecrb
    T.J i forget to tell you i noticed a complete change in C.G while taking the Cowl off damn hahahaha
  20. #720
    T3beatz's Avatar
    Join Date
    Oct 2007
    St. Louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    wow, how much of a change? I've done it before on a few planes and I've only needed a few clicks of trim to correct.
    www.Redwingrc.com
  21. #721
    Join Date
    Mar 2010
    bayan, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    T.J as soon as i took off and got her to a decent lvl to check the engin i left the trim and my airplane went mad i had to trim it alot just to keep it leveled up. also it became tail heavy when i took the cowl off
  22. #722
    T3beatz's Avatar
    Join Date
    Oct 2007
    St. Louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm not understanding you said you had to trim it a lot to keep it leveled up (nose heavy) then you said it was tail heavy with the cowl off?... You must have had some other problem, if your plane went mad with that cowling off.... it is a light cowling and should not throw the cg off by that much. (or your CG was slightly to the rear to begin with).
    If you do a 45* up-line and go inverted your plane should nose over ever so slightly, if it wants to push toward the sky your cg is aft and if it keeps a strait line you have a more neutral CG.  (also it should fly strait and level when upright before doing this test).
    www.Redwingrc.com
  23. #723
    Join Date
    Mar 2010
    bayan, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: T3beatz
    If you do a 45*up-lineand go inverted your plane should nose over ever so slightly, if it wants to pushtowardthe sky your cg is aft and if it keeps a strait line you have a moreneutralCG. (also it should fly strait and level when upright before doing this test).
    hi T.J
    as soon as i took off and left the elevator stick to lvl the plane, it started to drop instantly, i had to trim it alot to lvl it it up. when i fly her inverted and with a 45 degree incline it will keep climibing up for ever. case was not like that with the cowl on and still i didnt had the chance to fly her with cowl on
    T.J is it true on the aurora 9 to set expos you need to set them with negative values not positives like the DX7 ?
  24. #724
    T3beatz's Avatar
    Join Date
    Oct 2007
    St. Louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: AvatarQ8
    ORIGINAL: T3beatz
    hi T.J
    If you take off and go to fly level and the nose drops that means your nose heavy for the most part ( or your elevators were not level and had down trim in them).
    even then if they were level and you go inverted in a 45 incline, (after adding the up trim when you were flying upright) the plane should not keep climbing because of the up trim that you have in the elevators the plane should want to arch over.
    what makes your plane go up or down is not just the wieght of the tail, but the elevator postion.... when you turn your plane on how much up or down trim does it have when balanced?
    When I turn my plane on right now my elevators are just about center with 1 or 2 clicks of up in the radio. And I fly with a pretty nutral CG.
    www.Redwingrc.com
  25. #725
    T3beatz's Avatar
    Join Date
    Oct 2007
    St. Louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    zachfeen ,
    any updates? did you get the plane fixed?  BTW how did the motor perform?
    www.Redwingrc.com
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
