If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 36 of 36 FirstFirst ... 26343536
Results 876 to 880 of 880
  1. #876
    T3beatz's Avatar
    Join Date
    Oct 2007
    St. Louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RedWing MX2 Build
    If I'm not mistaken it has been changed...
    Build em Fly em Crash em!!!
    www.Redwingrc.com
  2. #877
    Join Date
    Jul 2009
    North Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Are you using a single bold prop adapter, if yes, which one? The extent to which you engine protrudes from the front ofthe cowl appearstobe, in addition to you not cutting the firewall, afunction of the adapter. The adpater I am using this this one http://www.valleyviewrc.com/estore/d...er-dle-30.html
    DaleD
  3. #878
    Join Date
    Mar 2005
    Haines City, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nope i'm not using a single bolt adapter.. heck didn't even know one existed..
    My DLE30's are all stock as they came from towerhobbies where i have bought all 3 i have. And like i said before the only mod i did for this plane is that in the inside part of the firewall before the fuel tank i placed a square [kinda] of 1/4 plywood inside plus the ususal reinforce of lite fiberglass.
    And the engine sticks out 1 1/4 out from the cowling as you saw on the picture.
    If it got fixed well guess on later production models cause mine came like that, and don't like weakening the firewall by cutting it.
    I did notice that the plane [at least mine] the engine and back spinner end up correctly if you used a DLE 30 side carb [which are no longer made] but since i have one i tried it and found the plane was designed around a side carb and not the rear carb like the manual says.
    But at least i fixed the problem and the plane is flying perfectly as of now. only has 50 flights in..
    Ona side note did notice better performance with a falcon 20x6 prop than the 19x8 i use normally on my 30's..
  4. #879
    Join Date
    Mar 2005
    Haines City, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi everyone:
    Had a minor mishap with my MX2.. and been trying to figure otu which is the correct Red covering for this plane...
    Is it True Red, Missile red, flame red??? Which red is it??
    I'll greatly appreaciate the help
  5. #880
    Join Date
    Jul 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ultracote True Red
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
