RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   50CC REVOLVER!! (https://www.rcuniverse.com/forum/arf-rtf-75/11231968-50cc-revolver.html)
srt10 10-21-2012 10:07 AM
RE: 50CC REVOLVER!!
I'de love to make this into a 12s speed burner! :D
Slow and Steady 10-21-2012 10:27 AM
RE: 50CC REVOLVER!!
I also have an inline filter and a filter in the gas can, but you may find, as I have that some kind of lint builds up in the internal filter. It may be from the alcohol in the gas. Maybe something in the fuel crystalizes. Has appeared in differenct planes; and only in the internal filter.
Chief also offers the replacement parts for Pilot planes for the cost of postage, via the manufacturer. I broke the engine box off of my EF Yak and luckily a friend had one from the Yak he had crashed. Trying to get the alignment right using ply stock would have been a challenge. With Pilot's program, it would have been a relativley easy fix.
thepamster 10-21-2012 12:59 PM
RE: 50CC REVOLVER!!
Do the wood screws that come with those metal control horns secure the horns well?
</p>
edwal07 10-21-2012 05:45 PM
RE: 50CC REVOLVER!!
Yes the screws secure the horns well. ALWAYS drill the holes, insert the screws, add 2 drops of thin CA, and let harden. Then reinsert your screws. Not only does is make the ply or hardwood insert harder it also hardens any balsa below and helps secure the insert also. I have yet to have one pull out. This is hardware from an Aeroworks 50cc Ultimate.
Spridal 10-22-2012 08:07 AM
RE: 50CC REVOLVER!!
ORIGINAL: edwal07
Thanks for the update. I too think the landing gear would look better painted. I have some white appliance epoxy that will do the trick. Can you post a photo of the gear. I think that may make it stand out even more.
Here ya go... http://imageshack.us/a/img688/3727/20121021205507.jpg
Spridal 10-22-2012 08:08 AM
RE: 50CC REVOLVER!!
Tail wheel...
http://imageshack.us/f/685/20121021205530.jpg/
edwal07 10-22-2012 09:17 AM
RE: 50CC REVOLVER!!
ORIGINAL: Spridal
ORIGINAL: edwal07
YEP! Gonna have to paint mine also! Looks Nice! We are at the same stage on the build.
Spridal 10-22-2012 09:21 AM
RE: 50CC REVOLVER!!
Ed,
What are you doing for the choke? Iplan on going with a manual choke. Ijust have to figure out how to route the rod.
jet22b 10-22-2012 04:51 PM
RE: 50CC REVOLVER!!
Spridal;
Is that the DLE 55RA you have on the nose?? If so, will the stock muffler fit without mod to the engine box?? I am going with that set up on my R90!!
Thanks for the info!!
Sonny
aka
jet22b
Spridal 10-22-2012 08:13 PM
RE: 50CC REVOLVER!!
ORIGINAL: jet22b
Spridal;
Sonny
aka
jet22b
Yes,
That's a DLE 55RA up front. The muffler and stand-offs fit perfect with no mods. Once the cowl is installed, the exhaust protrudes slightly and is hardly seen. All in all a very good fit.
<br type="_moz" />
airborne2.4 10-23-2012 01:57 AM
RE: 50CC REVOLVER!!
ORIGINAL: Spridal
Yes,
<br type=''_moz'' />
Do you have any pictures with the DLE 55RA and cowl installed?:)
edwal07 10-23-2012 06:11 AM
RE: 50CC REVOLVER!!
ORIGINAL: Spridal
Ed,
I got the cowl on last night, no linkage yet but was looking at the choke to see where it could go. I will do some more tonight and that is one of the things I was planning on doing.
The DLA 56 pitts muffler fit OK however I had to cut some clearance on the side. Wish I had the 55RA and that would have solved that problem.
Will post a pic once I figure out how the manual linkage will work. I used a 4 point servo arm with 2 arms cut off to act like a bellcrank and the rod exited on the bottom of the cowl on the Ultimate, will have to see if that will work on this one.
Spridal 10-23-2012 07:47 AM
RE: 50CC REVOLVER!!
ORIGINAL: edwal07
ORIGINAL: Spridal
Ed,
Ed,
I decided to use the method Ilearned from AeroWorks. Simply run the choke rod to the front of the cowl. Makes things simple and effective. See page 53 of the Aeroworks 50cc Edge Manual. I also setup my throttle the same way as suggested in thier manual.
http://www.aero-works.net/upload/man...ualrevised.pdf
Spridal 10-23-2012 08:24 AM
RE: 50CC REVOLVER!!
ORIGINAL: airborne2.4
ORIGINAL: Spridal
Yes,
<br type="" />
I will post a pic of the cowl installed later today.
jet22b 10-23-2012 01:46 PM
RE: 50CC REVOLVER!!
Spridal;
Thanks again for the info. Can not wait to see your pictures. Like I said before, I am going with the same setup. My R90 may not fly untill spring, because the weatherman is calling for snow here in the Great Northwest starting tomorrow![:o] Old man winter is on its way!!!
Thanks again!!!
Sonny
aka
jet22b
Spridal 10-23-2012 02:16 PM
RE: 50CC REVOLVER!!
ORIGINAL: jet22b
Spridal;
Thanks again!!!
Sonny
aka
jet22b
What is this thing you call snow? LOL...
Super08 10-23-2012 02:42 PM
RE: 50CC REVOLVER!!
1 Attachment(s)
ORIGINAL: Spridal
It is the garbage that just dumped all over my truck yesterday. It was worse than this before it finally stopped. We got a good 6". Far too early for this stuff.
Spridal 10-23-2012 03:23 PM
RE: 50CC REVOLVER!!
ORIGINAL: Super08
ORIGINAL: Spridal
You think you have it tough. Look what Ihave to deal with http://www.rcuniverse.com/forum/js/f.../cry_smile.gif
<h2 class="sb_h3 cttl"><font color="#0044cc">Weather in Palm Springs, California</font></h2><p class="sb_meta catr"><cite><font color="#388222">bing.com/weather</font><span class="sb_meta"> &middot; <font color="#5077bb">Data from AccuWeather</font></span></cite></p><p class="cfct"><font color="#0044cc">Hourly</font> &middot; <font color="#0044cc">Monthly Averages</font> &middot; <font color="#0044cc">Radar &amp; Maps</font></p><div class="crch"><div class="w_rch">
</p><div class="w_capgn"><div class="w_lft"><table border="0" cellspacing="0"> <thead> <tr class="w_hdr"> <td class="w_lan"><span class="sb_meta"><font color="#737373">Now</font></span></td> <td class="w_nr"><span class="sb_meta"><font color="#737373">Tue</font></span></td> <td class="w_nr"><span class="sb_meta"><font color="#737373">Wed</font></span></td> <td class="w_nr"><span class="sb_meta"><font color="#737373">Thu</font></span></td> <td class="w_nr"><span class="sb_meta"><font color="#737373">Fri</font></span></td> <td class="w_nr"><span class="sb_meta"><font color="#737373">Sat</font></span></td> </tr> </thead> <tbody> <tr class="w_sin"> <td class="w_bgcc"> <div class="w_cur_tb">79&deg;</div> <div class="w_con_txtn" title="Sunny (Clear)">Sunny (Clear)</div> <div>&deg;F | <font color="#5077bb">&deg;C</font></div> </td> <td class="w_fcr"><font color="#5077bb">http://www.bing.com/s/weather/66x62/31.jpg</font> <div class="w_fc_tn"><span class="sb_meta"><font color="#737373">80&deg; / 57&deg;</font></span></div> </td> <td class="w_fcr"><font color="#737373">http://www.bing.com/s/weather/66x62/29.jpg</font> <div class="w_fc_tn"><span class="sb_meta"><font color="#737373">83&deg; / 59&deg;</font></span></div> </td> <td class="w_fcr"><font color="#737373">http://www.bing.com/s/weather/66x62/31.jpg</font> <div class="w_fc_tn"><span class="sb_meta"><font color="#737373">85&deg; / 62&deg;</font></span></div> </td> <td class="w_fcr"><font color="#737373">http://www.bing.com/s/weather/66x62/31.jpg</font> <div class="w_fc_tn"><span class="sb_meta"><font color="#737373">85&deg; / 62&deg;</font></span></div> </td> <td class="w_fcr"><font color="#737373">http://www.bing.com/s/weather/66x62/31.jpg</font> <div class="w_fc_tn"><span class="sb_meta"><font color="#737373">85&deg; / 60&deg;</font></span></div> </td> </tr> </tbody></table></div><div class="w_lft fv_day"><span class="fv_dayc"><font color="#0044cc">Next 5 days</font></span></div></div><p class="w_capn"></p><div class="w_capp"></div></div></div>
Super08 10-23-2012 04:38 PM
RE: 50CC REVOLVER!!
That hurt.....
jet22b 10-23-2012 05:02 PM
RE: 50CC REVOLVER!!
ORIGINAL: Spridal
ORIGINAL: Super08
ORIGINAL: Spridal
It is the garbage that just dumped all over my truck yesterday. It was worse than this before it finally stopped. We got a good 6''. Far too early for this stuff.
You think you have it tough. Look what I have to deal with [img][/img]
<h2 class=''sb_h3 cttl''>http://<font color=''#0044cc''><b>We...ifornia</font></h2><p class=''sb_meta catr''><cite><font color=''#388222''>bing.com/weather</font><span class=''sb_meta''> · http://<font color=''#5077bb''>Data ...Weather</font></span></cite></p><p class=''cfct''><font color=''#0044cc''>Hourly</font> · <font color=''#0044cc''>Monthly Averages</font> · <font color=''#0044cc''>Radar & Maps</font></p><div class=''crch''><div class=''w_rch''>
</p><div class=''w_capgn''><div class=''w_lft''><table border=''0'' cellspacing=''0''> <thead> <tr class=''w_hdr''> <td class=''w_lan''><span class=''sb_meta''><font color=''#737373''>Now</font></span></td> <td class=''w_nr''><span class=''sb_meta''><font color=''#737373''>Tue</font></span></td> <td class=''w_nr''><span class=''sb_meta''><font color=''#737373''>Wed</font></span></td> <td class=''w_nr''><span class=''sb_meta''><font color=''#737373''>Thu</font></span></td> <td class=''w_nr''><span class=''sb_meta''><font color=''#737373''>Fri</font></span></td> <td class=''w_nr''><span class=''sb_meta''><font color=''#737373''>Sat</font></span></td> </tr> </thead> <tbody> <tr class=''w_sin''> <td class=''w_bgcc''> <div class=''w_cur_tb''>79°</div> <div class=''w_con_txtn'' title=''Sunny (Clear)''>Sunny (Clear)</div> <div>°F | <font color=''#5077bb''>°C</font></div> </td> <td class=''w_fcr''><font color=''#5077bb''>[img][/img]</font> <div class=''w_fc_tn''><span class=''sb_meta''><font color=''#737373''>80° / 57°</font></span></div> </td> <td class=''w_fcr''><font color=''#737373''>[img][/img]</font> <div class=''w_fc_tn''><span class=''sb_meta''><font color=''#737373''>83° / 59°</font></span></div> </td> <td class=''w_fcr''><font color=''#737373''>[img][/img]</font> <div class=''w_fc_tn''><span class=''sb_meta''><font color=''#737373''>85° / 62°</font></span></div> </td> <td class=''w_fcr''><font color=''#737373''>[img][/img]</font> <div class=''w_fc_tn''><span class=''sb_meta''><font color=''#737373''>85° / 62°</font></span></div> </td> <td class=''w_fcr''><font color=''#737373''>[img][/img]</font> <div class=''w_fc_tn''><span class=''sb_meta''><font color=''#737373''>85° / 60°</font></span></div> </td> </tr> </tbody></table></div><div class=''w_lft fv_day''>http://<span class=''fv_dayc''><font...</font></span></div></div><p class=''w_capn''> </p><div class=''w_capp''> </div></div></div>
Yes that do hurt!!!![&o][&o]
Sonny
aka
jet22b
microdon2 10-23-2012 05:02 PM
RE: 50CC REVOLVER!!
Poor sot - must spend a FORTUNE in sunscreen....
lopflyers 10-23-2012 05:07 PM
RE: 50CC REVOLVER!!
I can't complain about the temp here in the sunshine state but this wk we had 20 mph winds.
Spridal 10-23-2012 06:18 PM
RE: 50CC REVOLVER!!
1 Attachment(s)
ORIGINAL: Spridal
Yes,
<br type="" />
Here's the pics. Remember, these pics were taken while kneeling below the aircraft. While standing or even from a distance the engine and muffler are pretty much hidden from sight.
jet22b 10-23-2012 07:56 PM
RE: 50CC REVOLVER!!
Thanks Spridal for the pictures!!!
Sonny
aka
jet22b
airborne2.4 10-24-2012 02:49 AM
RE: 50CC REVOLVER!!
Nice pictures Spridal.
