Need some prop guidance
So this isn't exactly dealing with a plane but hoping I can still find help. I'm gonna be trying to pu an rc hovercraft together and I know nothing about eletric motors and props. In short Im looking for a thrust combo for one that would be hope 5 lbs or under
I'm currently looking at a 6x4 3 blade pusher prop on tower hobbies. I can't link it iPod won't let me paste the link
My question is am I better off with a high kv motor or some for like a 1/8th car since it will be heavy with a good amount of friction. I'm trying to keep this fairly low budget also so keep suggestions on the curdler side lol
Also what's the diff between in runner and out runner I'm new to the brushless thing but I read they far surpass brushed
RE: Need some prop guidance
This article may help with one of your several questions:
http://www.rcuniverse.com/magazine/a...rticle_id=1344
Thx that was helpful so what gather is I should be looking at out runners which if my brain is working today will probally be higher kv motors. Due to less rotational mass? Correct me if I'm wrong. Which makes sense more speed more thrust I'm just unsure about over working the motor.
Moderator
You may do better setting up with a ducted fan instead of a prop. If I understand hovercrafts right, it's all about moving air to maintain pressure, right? Props are really rotary wings the produce lift in addition to moving air. That's a very simplified explanation of course, but if the point is to simply move air the ducted fan will be much more efficient.
