Ask the Expert Sal - Electric Airplane Advice Here is your chance to ASK SAL, the expert for all your electric flight related questions. If you are not Sal, please do not answer questions in this forum.
Batter/ESC compatibility
Reply
Old 08-19-2017, 11:39 AM
thomasrpp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Batter/ESC compatibility
I am trying to get into a 40 size electric motor set up. I bought 2, 50c 2200mAh lipo batteries that I was going to use together to make a 4400mAh with a 60amp Esc and a 4240 turnigy motor that the plans for the plane suggested. Just curious if the 50c batteries could damage the esc.
thomasrpp is offline
Old 08-19-2017, 06:19 PM
aymodeler
aymodeler's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The batteries won't damage the ESC by themselves, but the prop/motor/battery combination could. Ultimately, it is the amount of current that the motor tries to draw that is the issue. If the prop/motor combination try to draw more than 60 amps, and the batteries are capable of supplying it, then the ESC will fry. Of course, if the motor itself is rated at less than 60 amps, then it will fry first.
There really is not enough information to tell if the combination will work or not. What motor are you using, with what prop? What is the KV rating and current limit of the motor. Also, are you using 3S or 4S battery packs?
aymodeler is offline
