help my battery started smoking
IN
hey well i pluged my 2 cell 11.1v lipo battery into my electryfly C-12 esc the battery started smoking i had only the battery pluged into the esc the motor and the recivor were not pluged in. is my battery still good. thanks i hope it is still good.
RE: help my battery started smoking
If it was smoking, I doubt if it is still good. Most likely you have plugged the battery into the speed control with reverse polarity. This would result in a destroyed speed control also. So, first check to see if your ESC is any good. The next is to examine the abttery, if it is puffeed, its pretty much NG. If the battery looks physically good, look to see where the smoke came from. If it's from the wiring, it may be salvagable. If the smoke was from the cells themselves, please dispose of the battery in a safe manner.
