Ultrafly Bae Hawk
Ultrafly Bae Hawk
I have the Ultrafly Bae Hawk.I've tried to hand launch it five times all ready and every time it just wants to nose straight down into the ground and breking the fuse in half every time.I've tried to hand lauch it severl different ways.The prop has the numbers facing inwards so you can't see the numbers on the prop.It seems like the plane doesn't have enough power to take off.And plus I've got the better brushless motor on the plane.The plane is balanced right and I've done a rage check every time.Unless the prop needs switched around.ANd any info would be great I would love to see this jet fly bye the vidios its seems like a cool plane.
NY
RE: Ultrafly Bae Hawk
Hey man! Can't really know for sure, but do you have your elevator reversed? If so, trying to pull up would put you into the ground. As for the prop, make sure the ailfoiled side is forward and the thrust is correct. ie: the motor is turning the right way. Good luck!
