Carbon fuselage and reception
I have a very small electric pylon racer that I can fit, barely, a GWS 6 channel naro with horizontal pins. This has the short antenna and hangs out the rear about 14-15" after going through the fuse 14-15". The fuse is carbon fiber. I am getting a max of 30 feet or so with the antenna down. This reciever works great in other airplanes.
What are my options? Have the antenna routed externally? Is there another reciever the same physical size that would give me better range? Any recommendations? Links? Any help would be very much appreciated. |
RE: Carbon fuselage and reception
Since carbon fiber conducts electricity it acts as a faraday cage and as such will impede the reciever reception. I had a problem running my antenna next to two carbon pushrods, I can't imagine how bad yours must be. The only option I see is adding an external antenna. I have seen some that are maybe 6 inches and go vertical to the fuse out a hole with a few bolts holding it in place (Kind of like what you see on cop cars, but much smaller).
ATCme [sm=tongue_smile.gif] |
ORIGINAL: evan-RCU I have a very small electric pylon racer that I can fit, barely, a GWS 6 channel naro with horizontal pins. This has the short antenna and hangs out the rear about 14-15" after going through the fuse 14-15". The fuse is carbon fiber. I am getting a max of 30 feet or so with the antenna down. This reciever works great in other airplanes. What are my options? Have the antenna routed externally? Is there another reciever the same physical size that would give me better range? Any recommendations? Links? Any help would be very much appreciated. |
Thanks for the ideas, I have used base loaded antennas before and would rather not on this if possible.
Antenna collapsed all the way, I should get at least 100 feet, I normally do with this reciever and my 9C Futaba in an ordinary airplane. I'll check out the specs for the Berg and see if it'll fit in the tiny space I have. |
The Berg is very small and this should give you the range you need.
