PT Gyro Servo Size
PT Gyro Servo Size
The Flyingbalsa website recommends Hitec HS81MG for the PT Gyro Kits. Is it for the small one or PT 25 or both?
I never used the HS-81 on anything bigger then a .15 size gyro.
Wahid
Wahid
RE: PT Gyro Servo Size
Hi Wahid,
We recommended the HS81MG for the 1/2a PT Gyro.
For the PT Profile and the PT25, we recommend the HS225MG or equivalent.
The PT Gyro Team
The PT Gyro Team
Nylon gears will work fine as far as flight loads.
They will strip when you have a few tip overs or ground strikes with the main rotor.
I do not have any experience with the JR composite gears.
Hitec advertises their "Karbonite" composite gearsets as "four times stronger than nylon".
Hope this helps,
John
Hope this helps,
John
