Go Back  RCU Forums > RC Helicopters > AutoGyros
Reload this Page >
GT17 in the fog
AutoGyros All about autorotational flight, sport and scale autogyros! User friendly!
GT17 in the fog
Old 09-29-2006, 10:27 PM
Scotth
Default GT17 in the fog
Got to the field, the fog had set in. Just keep it close.....
htt p://s58.photobucket.com/albums/g250/scotth1972/?action=view&current=GT17intheFog.flv
Old 09-29-2006, 11:20 PM
Scotth
Default RE: GT17 in the fog
Comments would be great....
Old 10-01-2006, 12:04 PM
ottogiro58
Your gyroplane looks really cool, fog or no fog !!! The prerotator works well, and it seems to be a very nice flying machine. How slow can it be flown ?? Thanx for posting the video. Charlie Anderson
Old 10-02-2006, 09:46 AM
Scotth
Pretty slow. The horizontal stab makes it hard to do high alpha flight. The elevator control gets real mushy. With my other model, without a horizontal stab, I can hover it with the slightest breeze. Just point the nose up, and it slows to a crawl.
Scott
Old 10-02-2006, 02:17 PM
ottogiro58
Hi Scott, Sounds pretty good. Gyros are a blast to fly. I have flown twin rotor gyros for nearly 20 years. My model will fly @ 3 to 5 MPH in no-wind conditions, with the nose at 45 degrees or more. Steering becomes sensitive at the acute angle. It can also flat-spin. I like making nearly vertical approaches, with lots of back stick and throttle. I am looking forward to building a single rotor machine sometime soon. They are much more realistic. Simpler to build, too !! Thanx for the info. Charlie Anderson
Old 10-02-2006, 03:29 PM
Scotth
Thanks. I would have you check out Mickey Nowell's designs. Single rotor, direct head control. The difference, he uses a a fixed pitch heli head to control the gyro. The flybar maintains stability, and steers the model. Works great! No load on the servos, and can be controlled at all airspeeds. I would suggest a tractor for a 1st model, the pusher is "James Bond", but a tractor is much easier to fly.
Old 02-09-2015, 06:56 AM
shakeelsid
shakeelsid's Avatar
Here is another foggy flight
this was a test flight for this plane
https://www.youtube.com/watch?v=WIHjHhl6hk0
